debian 4.0 HOWTO installation
marculin
Post by marculin »
Hello, I have download a debian 4.0 and your manual of installation!
The server apache and module php work (with phpinfo() it's ok) but zoneminder it's not work under apache.
I think because this file not exist
Type vi /var/www/zm/zm.php
Find setcookie by pressing ESC and typing :?setcookie
Create a new line under the setcookie statement by pressing ESC and o
Add the following line under setcookie (press ESC and i to insert) :
	setcookie (“cookies”,$cookies);
Anyone have any idea?
Lee Sharp
Post by Lee Sharp »
How did you install zoneminder? Compiled, or from the packages in the debian repositories?
marculin
Post by marculin »
from repository unstable!
I have download debian 3.1 and I go to try with this!
marculin
Post by marculin »
I restart installation!
-I have installed Debian 4.0
-edit /etc/apt/source.list with unstable version
-apt-get update
-apt-get install zoneminder
Lettura della lista dei pacchetti in corso... Fatto
Generazione dell'albero delle dipendenze in corso... Fatto
I seguenti pacchetti verranno inoltre installati:
  apache2-mpm-prefork apache2-utils apache2.2-common ffmpeg liba52-0.7.4
  libapache2-mod-php5 libapr1 libaprutil1 libasound2 libavcodec0d
  libavformat0d libc6 libc6-i686 libconvert-binhex-perl libdate-manip-perl
  libdbd-mysql-perl libdbi-perl libdc1394-13 libdirectfb-0.9-25 libexpat1
  libgsm1 libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl
  libio-stringy-perl libjpeg62 libkeyutils1 libkrb53 libmailtools-perl
  libmime-perl libmysqlclient15off libnet-daemon-perl libogg0 libplrpc-perl
  libpq5 libraw1394-8 libsdl1.2debian libsdl1.2debian-alsa libsqlite3-0
  libsvga1 libsysfs2 libtimedate-perl liburi-perl libvorbis0a libvorbisenc2
  libwww-perl libxml2 libzzip-0-12 locales mysql-client-5.0 mysql-common
  mysql-server mysql-server-5.0 php4-common php5 php5-common php5-mysql psmisc
  svgalibg1 tzdata
Pacchetti suggeriti:
  php-pear libasound2-plugins glibc-doc dbishell krb5-doc krb5-user
  libcompress-zlib-perl libraw1394-doc libio-socket-ssl-perl tinyca
Pacchetti raccomandati:
  libhtml-format-perl xml-core
I seguenti pacchetti NUOVI (NEW) saranno installati:
  libavformat0d libconvert-binhex-perl libdate-manip-perl libdbd-mysql-perl
  libdbi-perl libdc1394-13 libdirectfb-0.9-25 libexpat1 libgsm1
  libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl libio-stringy-perl
  libjpeg62 libkeyutils1 libmailtools-perl libmime-perl libmysqlclient15off
  libnet-daemon-perl libogg0 libplrpc-perl libpq5 libraw1394-8 libsdl1.2debian
  libsdl1.2debian-alsa libsqlite3-0 libsvga1 libsysfs2 libtimedate-perl
  liburi-perl libvorbis0a libvorbisenc2 libwww-perl libxml2 libzzip-0-12
  mysql-client-5.0 mysql-common mysql-server mysql-server-5.0 php4-common php5
  php5-common php5-mysql psmisc svgalibg1 zoneminder
I seguenti pacchetti saranno aggiornati:
  libc6 libc6-i686 libkrb53 locales tzdata
5 aggiornati, 56 installati, 0 da rimuovere e 100 non aggiornati.
à necessario prendere 58,4MB/59,4MB di archivi.
Dopo l'estrazione, verranno occupati 130MB di spazio su disco.
Continuare [S/n]?
at term apt-get apache and zoneminder start automatically
If I go to http://IP it redirect to http://IP/apache2-default/ and it print "it works!".
-ln -s /etc/zm/apache.conf /etc/apache2/conf.d/zm.conf
-/etc/init.d/apache2 reload
-http://IP/zm
okay it work...very well!
If you want use this like howto!!
Still one problem.
View image (with livecd it work very well with this configuration)
How I can find a problem?thank you
marculin
Post by marculin »
If I put
chmod 777 video0
it work (but not ip camera).
What is a correct permission for video0 (default is 660)?
ip camera because don't work?
thank
marculin
Post by marculin »
in /var/log/messages
 WAR [Unable to use netcam regexps as not compiled with libpcre]
I have
-dpkg --purge zoneminder
-apt-get install libpcre3 libpcre3-dev
But problem not solved...ip camera not work
thank you
PeterHoward
Post by PeterHoward »
marculin wrote:in /var/log/messages
I have
thank you
OK. My bad for not building the debian package with pcre.
Are you familiar with the debian BTS? If so can you generate a bug there? It will remind me to do this.
Regardless, I'll try to resolve this for you by the end of the week.
PJH
marculin
Post by marculin »
I don't know debian BTS :(
Thank you but I don't think which libpcre it's my problem because
-with mandriva live cd and option
ZM_OPT_REMOTE_CAMERAS not checked
ZM_NETCAM_REGEXPS not checked
my ip cam work
instead with debian 4.0 (zoneminder by repository) with same config don't work.....I don't find a solution!
with "ZM_NETCAM_REGEXPS not checked" not have the error in /var/log/messages but it don't work
what of tasks?
marculin
Post by marculin »
SOLVED :lol:
debian:/tmp# more /proc/sys/kernel/shmmax
33554432
debian:/tmp# cat /proc/sys/kernel/shmall
2097152
debian:/tmp# echo 134217728 >/proc/sys/kernel/shmmax
debian:/tmp# echo 134217728 >/proc/sys/kernel/shmall
Still a problem of permission video0!
How I can change perm at boot for /dev/video0 (and what?)?
thank you
wilso027
Post by wilso027 »
On Ubuntu systems which is based on Debian you can add your user to the video group in /etc/groups and that should get it. You may also want to check
/etc/udev/rules.d
directory and see if you can modify the settings there.
Allan
PeterHoward
Also, do a search on "zmfix" in the forums. IIRC I saw someone integrate that into startup.
John Williams
Post by John Williams »
zmfix did not work for me. creating a video group and adding www-data user to that group worked and persists across reboots. chmoding the /dev entry works but only until the next reboot.
John
marculin
Post by marculin »
I add user to video and work ;) thank!
