view camera connect to windows machine
oc666
Post by oc666 » Thu Apr 19, 2007 4:59 pm
Hello, buddies
I need to view camera, which connect to window machine, from my zoneminder, which installed on Gentoo machine. Is it possible?
Thanks a lot
freddy99
Re: view camera connect to windows machine
Post by freddy99 » Thu Apr 19, 2007 8:23 pm
oc666 wrote:Hello, buddies
Thanks a lot
You need to setup an http server on your LAN. I suggest to use Dorgem (just google for it). It is simple and open-source. Then under the Source tab of your monitor configuration, you put IP address of your Windows PC, Port # used for http streaming and image filename (IMAGE.JPG for Dorgem).
Hope this helps.
Frederic
oc666
Post by oc666 » Sat Apr 21, 2007 12:43 pm
I need to install http server on the camera host for that & I prefer not to install http server for broadcast the cam. Is there any other way to that?
oc666
Post by oc666 » Sat Apr 21, 2007 1:06 pm
OK. I realized that I don't need install http server on the camera host. I just need to install the Dorgem program & configure it to broadcast to the zoneminder server.
Thanks a lot, freddy99
Users browsing this forum: No registered users and 14 guests
