Console Stopped,Events OK no Live image V1.22.3
Hi All,
Console says stopped and will not start. All processes running normally.
there are NO errors even with debug level=9. I can play back recorded events (modetect,record etc) ,I can define zones all seems well ,but the monitor name is not a link,source links are red and there is no Cycle/montage link.
As a result there are no "live" monitors.
Any help would be appreciated.
We really need more info to be able to help.
See this post: http://www.zoneminder.com/forums/viewtopic.php?t=6427
Thanks for the reply.
I have read read all required material. Several times
Here's more info.
As you can see I have one capture daemon running
4132 ? S 0:01 /usr/bin/perl -wT /usr/local/bin/zmdc.pl startup
4161 ? S 1:09 \_ /usr/local/bin/zmc -d /dev/video
4165 ? S 0:00 \_ /usr/local/bin/zmf -m 3
4169 ? S 0:22 \_ /usr/local/bin/zma -m 3
4175 ? S 0:00 \_ /usr/bin/perl -wT /usr/local/bin/zmfilter.pl
4180 ? S 0:00 \_ /usr/bin/perl -wT /usr/local/bin/zmaudit.pl -c
4185 ? S 0:01 \_ /usr/bin/perl -wT /usr/local/bin/zmwatch.pl
4189 ? S 0:00 \_ /usr/bin/perl -w /usr/local/bin/zmupdate.pl -c
There are no errors in the logs. Really
I can access the db obviously since I can replay events ,change preferences etc.
I have disabled SeLinux,
increased my shared memory (no more shmget errors),
Almost everything works except LIVE video
Name -No Link
Function - Green (Record,Modect etc)
Source - Red /dev/video
Events to Zones all functional links
Works with xawtv
Here's more info.
Name -No Link
Works with xawtv
Using Fedora compiled ZM ver 1.22.3
Cordel.Unfortunately I do not have a public IP so SSH cannot happen.
Thanks for the offer.
Hi
I was able to get the montage/name links activated. I can now view all mon itors and the montage. I had to "hack" the php code so this is not a real fix.
console still stuck on STOPPED but all processes are running.
currently have 5 cams on 2 cards (type 77,type 9) all working.
Still would like to be able to change states from the console.Any help would be appreciated.
@Fibi
From your logs messagesThis is SeLinux doing its job, unfortunatly there are no rules for ZM so it has to be disabled. I disabled it in your machine so all should work now. I could not verify everything since you didn't send the info for the web interface and only sent ssh.
Feb 25 19:03:52 slivenec kernel: audit(1172426632.119:32): avc: denied { ioctl } for pid=31796 comm="zmdc.pl" name="error_log" dev=dm-0 ino=449425 scontext=user_u:system_r:httpd_sys_script_t tcontext=root:object_r:httpd_log_t tclass=file
Feb 25 19:03:53 slivenec kernel: audit(1172426633.733:33): avc: denied { write } for pid=31796 comm="zmdc.pl" name="zmdc.sock" dev=dm-0 ino=245878 scontext=user_u:system_r:httpd_sys_script_t tcontext=root:object_r:tmp_t tclass=sock_file
Feb 25 19:03:53 slivenec kernel: audit(1172426633.807:34): avc: denied { ioctl } for pid=31800 comm="zmdc.pl" name="error_log" dev=dm-0 ino=449425 scontext=user_u:system_r:httpd_sys_script_t tcontext=root:object_r:httpd_log_t tclass=file
Feb 25 19:03:55 slivenec kernel: audit(1172426635.330:35): avc: denied { write } for pid=31800 comm="zmdc.pl" name="zmdc.sock" dev=dm-0 ino=245878 scontext=user_u:system_r:httpd_sys_script_t tcontext=root:object_r:tmp_t tclass=sock_file
Feb 25 19:03:55 slivenec kernel: audit(1172426635.402:36): avc: denied { read } for pid=31803 comm="uptime" name="utmp" dev=dm-0 ino=409611 scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:object_r:initrc_var_run_t tclass=file
Feb 25 19:03:55 slivenec kernel: audit(1172426635.403:37): avc: denied { read } for pid=31803 comm="uptime" name="utmp" dev=dm-0 ino=409611 scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:object_r:initrc_var_run_t tclass=file
Feb 25 19:04:17 slivenec kernel: audit(1172426657.128:38): avc: denied { create } for pid=31831 comm="zmfix" scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:system_r:httpd_sys_script_t tclass=unix_dgram_socket
Feb 25 19:04:17 slivenec kernel: audit(1172426657.133:39): avc: denied { dac_override } for pid=31831 comm="zmfix" capability=1 scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:system_r:httpd_sys_script_t tclass=capability
Feb 25 19:04:17 slivenec kernel: audit(1172426657.133:40): avc: denied { dac_read_search } for pid=31831 comm="zmfix" capability=2 scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:system_r:httpd_sys_script_t tclass=capability
Feb 25 19:04:17 slivenec kernel: audit(1172426657.146:41): avc: denied { create } for pid=31831 comm="zmfix" scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:system_r:httpd_sys_script_t tclass=unix_dgram_socket
Feb 25 19:04:17 slivenec kernel: audit(1172426657.180:42): avc: denied { ioctl } for pid=31832 comm="zmdc.pl" name="error_log" dev=dm-0 ino=449425 scontext=user_u:system_r:httpd_sys_script_t tcontext=root:object_r:httpd_log_t tclass=file
Wrong topic for this...
cordel wrote:@Fibi
From your logs messagesThis is SeLinux doing its job, unfortunatly there are no rules for ZM so it has to be disabled. I disabled it in your machine so all should work now. I could not verify everything since you didn't send the info for the web interface and only sent ssh.Code: Select all
Feb 25 19:03:52 slivenec kernel: audit(1172426632.119:32): avc: denied { ioctl } for pid=31796 comm="zmdc.pl" name="error_log" dev=dm-0 ino=449425 scontext=user_u:system_r:httpd_sys_script_t tcontext=root:object_r:httpd_log_t tclass=file Feb 25 19:03:53 slivenec kernel: audit(1172426633.733:33): avc: denied { write } for pid=31796 comm="zmdc.pl" name="zmdc.sock" dev=dm-0 ino=245878 scontext=user_u:system_r:httpd_sys_script_t tcontext=root:object_r:tmp_t tclass=sock_file Feb 25 19:03:53 slivenec kernel: audit(1172426633.807:34): avc: denied { ioctl } for pid=31800 comm="zmdc.pl" name="error_log" dev=dm-0 ino=449425 scontext=user_u:system_r:httpd_sys_script_t tcontext=root:object_r:httpd_log_t tclass=file Feb 25 19:03:55 slivenec kernel: audit(1172426635.330:35): avc: denied { write } for pid=31800 comm="zmdc.pl" name="zmdc.sock" dev=dm-0 ino=245878 scontext=user_u:system_r:httpd_sys_script_t tcontext=root:object_r:tmp_t tclass=sock_file Feb 25 19:03:55 slivenec kernel: audit(1172426635.402:36): avc: denied { read } for pid=31803 comm="uptime" name="utmp" dev=dm-0 ino=409611 scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:object_r:initrc_var_run_t tclass=file Feb 25 19:03:55 slivenec kernel: audit(1172426635.403:37): avc: denied { read } for pid=31803 comm="uptime" name="utmp" dev=dm-0 ino=409611 scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:object_r:initrc_var_run_t tclass=file Feb 25 19:04:17 slivenec kernel: audit(1172426657.128:38): avc: denied { create } for pid=31831 comm="zmfix" scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:system_r:httpd_sys_script_t tclass=unix_dgram_socket Feb 25 19:04:17 slivenec kernel: audit(1172426657.133:39): avc: denied { dac_override } for pid=31831 comm="zmfix" capability=1 scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:system_r:httpd_sys_script_t tclass=capability Feb 25 19:04:17 slivenec kernel: audit(1172426657.133:40): avc: denied { dac_read_search } for pid=31831 comm="zmfix" capability=2 scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:system_r:httpd_sys_script_t tclass=capability Feb 25 19:04:17 slivenec kernel: audit(1172426657.146:41): avc: denied { create } for pid=31831 comm="zmfix" scontext=user_u:system_r:httpd_sys_script_t tcontext=user_u:system_r:httpd_sys_script_t tclass=unix_dgram_socket Feb 25 19:04:17 slivenec kernel: audit(1172426657.180:42): avc: denied { ioctl } for pid=31832 comm="zmdc.pl" name="error_log" dev=dm-0 ino=449425 scontext=user_u:system_r:httpd_sys_script_t tcontext=root:object_r:httpd_log_t tclass=file
