Upgrade Problem from 1.22.1 -> 1.22.3
postfux
Post by postfux »
When i did a zmupdate.pl -version=1.22.1 i got:
Upgrading database to version 1.22.3
Database successfully upgraded from version 1.22.1.
ERROR 1064 at line 36: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'DEFAULT CHARSET=latin1' at line 6
Output:
Command 'mysql -hlocalhost -uroot -ptrito120404 zm < /install/ZoneMinder-1.22.3/db/zm_update-1.22.2.sql' exited with status: 1
and when i try then zmpk.pl start
i have in the logfile:12/13/06 22:00:52.597968 zmpkg[10977].ERR [Unable to run "su www-data --shell=/bin/sh --command='/usr/local/bin/zmfix'", output is ""]
Can somebody help me?
seb3s
this is a MySQL version pb
Post by seb3s »
Hi I had this as well.
It was due to the version of MySQL (Phil has probably upgraded his SQL in the meantime).
I just changed the "ENGINE=MyISAM" by "TYPE=MyISAM" in zm_update-1.22.2.sql and it went ok after.
You may need to remove the beginning of the script coz it won't run twice (coz of alter table statement).
Cheers,
Sébastien.
postfux
Post by postfux »
Thx for the help
I needet also to remove the DEFAUL CHARSET=latin1 statement cause i got also an error.
Ok now the DB is updated, but i still cant start the Zoneminder
I turned debug on and got in the log:
12/14/06 19:07:18.833375 zmpkg[8072].INF [Command: start]
12/14/06 19:07:18.834192 zmpkg[8072].DBG [Testing valid shell syntax]
12/14/06 19:07:18.834432 zmpkg[8072].DBG [Testing "sudo -u www-data true"]
12/14/06 19:07:18.838527 zmpkg[8072].DBG [Test failed, '']
12/14/06 19:07:18.838676 zmpkg[8072].DBG [Testing "su www-data --shell=/bin/sh --command='true'"
12/14/06 19:07:18.848256 zmpkg[8072].DBG [Test ok, using format "su www-data --shell=/bin/sh --command='<command>'"]
12/14/06 19:07:18.848439 zmpkg[8072].DBG [Command: su www-data --shell=/bin/sh --command='/usr/local/bin/zmdc.pl check']
12/14/06 19:07:19.012716 zmpkg[8072].DBG [Output: stopped]
12/14/06 19:07:19.012898 zmpkg[8072].DBG [Removing shared memory]
12/14/06 19:07:19.012968 zmpkg[8072].DBG [Checking for shared memory with 'ipcs -m | grep '^0x7a6d20'']
12/14/06 19:07:19.019740 zmpkg[8072].DBG [Command: su www-data --shell=/bin/sh --command='/usr/local/bin/zmfix']
12/14/06 19:07:19.037278 zmpkg[8072].ERR [Unable to run "su www-data --shell=/bin/sh --command='/usr/local/bin/zmfix'", output is ""]
then i installed sudo and got:
12/14/06 19:09:40.953001 zmpkg[8141].INF [Command: start]
12/14/06 19:09:40.953819 zmpkg[8141].DBG [Testing valid shell syntax]
12/14/06 19:09:40.954055 zmpkg[8141].DBG [Testing "sudo -u www-data true"]
12/14/06 19:09:40.998872 zmpkg[8141].DBG [Test ok, using format "sudo -u www-data <command>"]
12/14/06 19:09:40.999058 zmpkg[8141].DBG [Command: sudo -u www-data /usr/local/bin/zmdc.pl check]
12/14/06 19:09:41.161229 zmpkg[8141].DBG [Output: stopped]
12/14/06 19:09:41.161392 zmpkg[8141].DBG [Removing shared memory]
12/14/06 19:09:41.161476 zmpkg[8141].DBG [Checking for shared memory with 'ipcs -m | grep '^0x7a6d20'']
12/14/06 19:09:41.168192 zmpkg[8141].DBG [Command: sudo -u www-data /usr/local/bin/zmfix]
12/14/06 19:09:41.181921 zmpkg[8141].ERR [Unable to run "sudo -u www-data /usr/local/bin/zmfix", output is ""]
The old Version (1.22.1) functions and the 1.22.3 not anymore
What i did now was to replace the new zmfix with the old one
it is starting but i get errors in the zmdc what is i think logical cause it is from an other version. But what is wrong with the zmfix?
Here the log:
12/14/06 19:26:31.059418 zmdc[8241].ERR ['zma -m 1' exited abnormally, exit status 255]
12/14/06 19:26:31.062432 zmdc[8241].ERR ['zmf -m 1' exited abnormally, exit status 255]
12/14/06 19:26:38.026497 zmdc[8241].INF ['zmc -d /dev/video1' starting at 06/12/14 19:26:38, pid = 8454]
12/14/06 19:26:38.049234 zmdc[8241].ERR ['zmc -d /dev/video1' exited abnormally, exit status 255]
12/14/06 19:26:48.191117 zmdc[8241].INF ['zmc -d /dev/video1' starting at 06/12/14 19:26:48, pid = 8458]
12/14/06 19:26:48.202548 zmdc[8241].ERR ['zmc -d /dev/video1' exited abnormally, exit status 255]
12/14/06 19:26:58.385419 zmdc[8241].INF ['zmc -d /dev/video1' starting at 06/12/14 19:26:58, pid = 8463]
12/14/06 19:26:58.393813 zmdc[8241].ERR ['zmc -d /dev/video1' exited abnormally, exit status 255]
Thx in advance for you help!
Markus
postfux
Post by postfux »
Hi
So now my ZM is running.
I needet also to do a 'zmupdate.pl -f'
see also:
http://www.zoneminder.com/forums/viewtopic.php?t=6196
I didn't find anything about this in the Documentation not even that ther is a '-f' option for zmupdate.pl, maybe you wil have to mention this in the docu.
Markus
