can't get streaming images
maniacul
Post by maniacul » Fri Jun 09, 2006 10:21 am
how did you do that?
just wanting to know if the problem appears again
sorry for the shor outage, my mox got pretty busy and needed a reboot :(
Respect,
Dr.Septimiu Suciu
cordel
Post by cordel » Fri Jun 09, 2006 10:25 am
NP, in options under the paths tab, I changed the path for zms from /cgi-bin/nph-zms to /cgi-bin/zms
That's all.
Glad to get ya going :D
Cheers,
Corey
maniacul
Post by maniacul » Fri Jun 09, 2006 10:29 am
but the default installation is:
/cgi-bin/nph-zms
I just checked another box with ZM working
do you have any adeea why was this a problem on this particular box?
Respect,
Dr.Septimiu Suciu
cordel
Post by cordel » Fri Jun 09, 2006 10:35 am
I wish I did know :lol:
I haven't yet got that one figured out.
Corey
jameswilson
Post by jameswilson » Fri Jun 09, 2006 10:45 am
people on the other distro have reported that removing the nph- helps, so maybe its a debain/apache thing etc as i dont have this on fedora, mandrake/riva or pclos
James Wilson
maniacul
Post by maniacul » Fri Jun 09, 2006 10:49 am
but I run Slackware and everything i'm installing is from tarballs
i like to compile myself on the system i'm going to use the software
so it isn't a pachage problem
i'm going to think about this and let you know if i come up with any ideea
Respect,
Dr.Septimiu Suciu
jameswilson
Post by jameswilson » Fri Jun 09, 2006 10:57 am
no i didnt mean that i mean like a setting somewhere that i dont have but you do, the problem will be finding it!. Also if its developed and tested on fedora, then there are so many variables for all the different distros out there. Im glad i only use 4 and they are based on 2 so i onl;y really need to know 2! God it is fun isnt it lol
James Wilson
maniacul
Post by maniacul » Fri Jun 09, 2006 2:27 pm
it's fun allright...especially that the first testing machine I had it up and running in a day, and the production box I got it up in a week :))
I chose slackware because it's the closest to unix and it has been there about 10 now and i think it's the most mature
the funiest thing about the issue that u just solved is that on my testing machine where i installed ZM for the first time it's working fine
it was a bit chanllenging until I realized that I could only see streaming images only with cambozola (tried all options there at the images tab)
the tesint machine is a:
P4 1.4Ghz, 384 RAM 20Gb HDD slak 10.2 and acustomized 2.6.13 kernel
perhaps You could tell me where to find any change in the variables so we can debug it?
Respect,
Dr.Septimiu Suciu
jameswilson
Post by jameswilson » Fri Jun 09, 2006 2:46 pm
sorrymate wish i could but i know that apache can be built in many different ways, and as i have never built zm nor apache from source then im not best placed to help
James Wilson
maniacul
Post by maniacul » Fri Jun 09, 2006 5:56 pm
ok, no problem
I just wanted to help the comunity
by the way! i just installed zm on another slackware 10.2 box and I got the same problem
solved it by changing the path nph-zms to zms
best regards to you all & MANY thanx
Respect,
Dr.Septimiu Suciu
Users browsing this forum: No registered users and 33 guests
