debian sarge's zm.deb dependences
MK
Post by MK »
Hello everybody!
I tried to install zm with maximums zm.deb for debian stable sarge!
but i can get it work becauce of a pb of dependences with
liblame0 and libavcodec2.
How can I fix this? Is there some deb sources I can add to my apt/source.list to get it pretty??
i have tried using dselect but when solving pb of dependences whith some else packages, the pb always exists with these two!
thank you all for help!
mk
cavaughan
Post by cavaughan »
Set up your sources.list to read:
deb ftp://ftp.us.debian.org/debian/ sarge main non-free contrib
deb-src ftp://ftp.us.debian.org/debian/ sarge main non-free contrib
deb http://non-us.debian.org/debian-non-US sarge/non-US main contrib non-free
deb-src http://non-us.debian.org/debian-non-US sarge/non-US main contrib non-free
deb ftp://ftp.nerim.net/debian-marillat/ testing main
deb http://www.spic.net/zoneminder/debian ./
deb-src http://www.spic.net/zoneminder/debian ./
deb http://security.debian.org/ sarge/updates main contrib non-free
tim@pcs-alaska.com
Re: debian sarge's zm.deb dependences
Post by tim@pcs-alaska.com »
MK wrote:Hello everybody!
How can I fix this?
You can install the packages you need:
# apt-get install liblame0 libavcodec2 libavcodec2-dev
You man not need the libavcodec2-dev.
MK wrote:Is there some deb sources I can add to my apt/source.list to get it pretty??
You may need to have a working apache, php4 environment before using the packages from:
Good luck,
Tim
Tim Jordan
ZoneMinder 1.22
Debian Sarge
P4 1.7Ghz, 512MB, 160GB HD
(3) Panisonic KX-HCM10 Network Cameras
yeager
Post by yeager »
I get this error when trying to install the zm-package:
zm: Depends: phpapi-20020918
E: Broken packages
Daniel
(CISSP)
yeager
Post by yeager »
I forced the package to be installed since phpapi-20020918 is just a virtual package, I got this error when accessing the webpage
Warning: main(zm_wav.php): failed to open stream: No such file or directory in /var/www/zm/zm.php on line 162
Fatal error: main(): Failed opening required 'zm_wav.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/zm/zm.php on line 162
Daniel
(CISSP)
yeager
Post by yeager »
Well, after a few minutes on Google, I found the problem.
Recently upgraded to PHP5..
PHP5 has no more the mysql_pconnect function. That has been replace by the mysqli_connect.
Daniel
(CISSP)
yeager
Post by yeager »
I fixed it.
Now running Zoneminder 1.21.3 on Debian unstable with MySQL 5.0.11beta3 and PHP 5.0.4.
Just add to your /etc/apt/sources.list
deb http://people.debian.org/~dexter php5 sarge
apt-get update
apt-get install php5.0-common php5.0-mysql php5.0-cgi
This should do the trick.
Daniel
Daniel
(CISSP)
maximum
Post by maximum »
hi MK, sorry for the late answer but my adsl connetion has suffer a damage and now i' m connected by wardriving. I hope that tomorrow all works fine.
I have realized that the zm package is not enougth to install in a stabel sarge, because some important components from marrillat reposity is needed. So tomorrow, i will repack the debian packages on my zm-box and i will send them you if you want.
I think that is better to have a stable reposity for ZM and all dependences.
Some one can hosts a couple of .deb?
best,
MaX
best,
MaX
MK
Post by MK »
ok! I am waiting for it.
thank you
mk
maximum
Post by maximum »
MK wrote:ok! I am waiting for it.
thank you
Hi MK, i'm sendig you by email, all the components necessary for ZM in Debian/Stable (5 MB).
below the list of debs:
ffmpeg_20050427-0sarge0.1_i386.deb
libavcodec2_0.4.9-pre1-0.4_i386.deb
libavcodeccvs_20050427-0sarge0.1_i386.deb
libfaac0_1.24-0.3_i386.deb
libfaad2-0_2.0.0-0.5_i386.deb
libogg0_1.1.2-1_i386.deb
libsdl1.2debian_1.2.7+1.2.8cvs20041007-4.1_i386.deb
libvorbis0a_1.1.0-1_i386.deb
libvorbisenc2_1.1.0-1_i386.deb
libx11-6_4.3.0.dfsg.1-14_i386.deb
libxvidcore4_1.1.0-beta2-0.0_i386.deb
zm_1.21.3-3_i386.deb
If something is missing please let's me know
best,
MaX
seb3s
does the package contains a compiled zm with libpcre ?
Post by seb3s »
Hi maximum,
I've used the debian package to install on debian/sarge stable.
However, when I tried to use a Trendnet TV-IP100W, the webcam froze after a few seconds.
I already met this case when I was using the LiveCD, but this was solved when I checked the ZM_NETCAM_REGEXPS option. Under my new debian install, checking this option does not make any changes.
Then I found in the forum that this option requires the libpcre module to be compiled with zm (not sure what this means)
So my question.
TIA,
Sebastien.
maximum
Re: does the package contains a compiled zm with libpcre ?
Post by maximum »
seb3s wrote:Hi maximum,
So my question.
TIA,
Sebastien.
tomorrow i will try to recompile ZM with libpcre3-dev installad.
best,
MaX
seb3s
Any progress ?
Post by seb3s »
Hi maximum,
Did you get a chance to have a look into this ?
Thanks,
Sebastien.
maximum
Re: Any progress ?
Post by maximum »
Thanks,
Sebastien.
i got it!
please send me a mail so i'll send you the package just recompiled
best
MaX
