How do I set up an Axis camera?
Anyone know the url to use, etc. I have tried many things but it just shows a black square... no picture.
Axis 2100 camera setup
- zoneminder
- Site Admin
- Contact:
Re: Axis 2100 camera setup
Hi Jeff,
Congratulations on being the first poster! (apart from me).
I had a setup with an Axis 2100 which was on someone elses system. I think the path component of the URL, which I assume is what you need, was
/axis-cgi/jpg/image.cgi?resolution=320x240
or
/axis-cgi/jpg/image.cgi?resolution=640x480
depending on resolution you have.
ZoneMinder only works at present by sampling the stills and does not interpret the Motion JPEG stream.
Hope this helps.
Phil,
or
Hope this helps.
Phil,
Great!!! That's waht I was missing.
Now on with my testing :)
J_
J_
I am able to view live video, but when i go into recordings i cannot see the video, any help please.
There are some neat network cameras out there (Axis 205) which I have installed but otherwise regular video cameras may be cheaper and more versatile, especially for low light or outdoors. I notice you mentioned 802.11b, what would you do with that?
faris
Users browsing this forum: No registered users and 7 guests
