On the fly palette changes?
pete_c
Post by pete_c »
Is there a way utilizing ZM cgi command lines to do "on the fly" palette changes?
I utilize ZM with some touchscreens and while most of my cams are color I still utilize a "grey" palette.
Is there a way via command line that I could switch from a color to a grey or vice versa palette?
Or maybe just a means of using a cron job such that I could switch the cams to a grey palette at sunset and a color palette at daybreak?
Zoneminder User
Box #1 and # 2 - Intel Ubuntu 14.04 64 bit server - Most current beta 1.28 - XX HD IP cams
Box #3 - AMD Ubuntu 14.04 64 bit server - Most current beta 1.28 - XX HD IP cams
Moved rest of analogue cams to Axis Servers and Grandstream cams.
