ubuntu 9.04 desktop with zoneminder 1.23.3
Posted: Fri Nov 19, 2010 7:40 pm
I am getting memory error in my logs and i added the kernel.shmmax and kernel.shmall with 33554432 as im running 512 megs of memory.
Here are my logs.
root@camera-pc:~# tail /var/log/messages
Nov 19 01:36:20 camera-pc zmdc[2427]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:36:20, pid = 3581]
Nov 19 01:36:20 camera-pc zmwatch[2468]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:36:20, pid = 3581]
Nov 19 01:36:20 camera-pc zmc_dvideo0[3581]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 01:36:20 camera-pc zmc_dvideo0[3581]: INF [New Debug Level = 0, New Debug Log = /tmp/zm_debug.log.03581]
Nov 19 01:36:30 camera-pc zmwatch[2468]: INF [Restarting capture daemon for FrontDoor, shared memory not valid]
Nov 19 01:36:30 camera-pc zmdc[3684]: INF ['zmc -d /dev/video0' started at 10/11/19 01:36:30]
Nov 19 01:36:30 camera-pc zmdc[2427]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:36:30, pid = 3684]
Nov 19 01:36:30 camera-pc zmwatch[2468]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:36:30, pid = 3684]
Nov 19 01:36:30 camera-pc zmc_dvideo0[3684]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 01:36:30 camera-pc zmc_dvideo0[3684]: INF [New Debug Level = 0, New Debug Log = /tmp/zm_debug.log.03684]
root@camera-pc:~# tail /tmp/zm_debug.log.03684
11/19/10 01:36:30.804853 zmc_dvideo0[3684].INF-zm_debug.c/305 [New Debug Level = 0, New Debug Log = /tmp/zm_debug.log.03684]
11/19/10 01:36:30.813352 zmc_dvideo0[3684].ERR-zm_local_camera.cpp/162 [Failed to setup memory: Invalid argument]
root@camera-pc:~#
root@camera-pc:~# zmu -q -d /dev/video0 -v
Video Capabilities
Name: Hauppauge WinTV PVR-150
Type: 7
Can capture
Can tune
Does teletext
Video Channels: 5
Audio Channels: 0
Maximum Width: 720
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 0 - Unknown
Colour Depth: 0
Brightness: 32896
Hue: 32896
Colour :33026
Contrast: 33026
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 1
Channel has a tuner
Type: 1 - TV
Format: 1 - NTSC
Channel 1 Attributes
Channel: 1
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel 2 Attributes
Channel: 2
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel 3 Attributes
Channel: 3
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel 4 Attributes
Channel: 4
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
root@camera-pc:~#
root@camera-pc:~# tail /tmp/zmwatch.log
11/19/2010 01:46:39.273503 zmwatch[4389].INF [Restarting capture daemon for FrontDoor, shared memory not valid]
11/19/2010 01:46:39.747202 zmwatch[4389].INF ['zmc -d /dev/video0' starting at 10/11/19 01:46:39, pid = 4649]
11/19/2010 01:46:49.749450 zmwatch[4389].INF [Restarting capture daemon for FrontDoor, shared memory not valid]
11/19/2010 01:46:50.231208 zmwatch[4389].INF ['zmc -d /dev/video0' starting at 10/11/19 01:46:50, pid = 4651]
11/19/2010 01:47:00.233471 zmwatch[4389].INF [Restarting capture daemon for FrontDoor, shared memory not valid]
11/19/2010 01:47:00.711218 zmwatch[4389].INF ['zmc -d /dev/video0' starting at 10/11/19 01:47:00, pid = 4653]
11/19/2010 01:47:10.713459 zmwatch[4389].INF [Restarting capture daemon for FrontDoor, shared memory not valid]
11/19/2010 01:47:11.179215 zmwatch[4389].INF ['zmc -d /dev/video0' starting at 10/11/19 01:47:11, pid = 4655]
11/19/2010 01:47:21.181515 zmwatch[4389].INF [Restarting capture daemon for FrontDoor, shared memory not valid]
11/19/2010 01:47:21.651355 zmwatch[4389].INF ['zmc -d /dev/video0' starting at 10/11/19 01:47:21, pid = 4657]
root@camera-pc:~#
root@camera-pc:~# tail /var/log/syslog
Nov 19 01:56:47 camera-pc zmc_dvideo0[5044]: ERR [Failed to setup memory: Invalid argument]
Nov 19 01:56:47 camera-pc zmdc[4360]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Nov 19 01:56:57 camera-pc zmwatch[4389]: INF [Restarting capture daemon for FrontDoor, shared memory not valid]
Nov 19 01:56:57 camera-pc zmdc[5046]: INF ['zmc -d /dev/video0' started at 10/11/19 01:56:57]
Nov 19 01:56:57 camera-pc zmdc[4360]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:56:57, pid = 5046]
Nov 19 01:56:57 camera-pc zmwatch[4389]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:56:57, pid = 5046]
Nov 19 01:56:57 camera-pc zmc_dvideo0[5046]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 01:56:57 camera-pc zmc_dvideo0[5046]: INF [New Debug Level = 0, New Debug Log = /tmp/zm_debug.log.05046]
Nov 19 01:56:57 camera-pc zmc_dvideo0[5046]: ERR [Failed to setup memory: Invalid argument]
Nov 19 01:56:57 camera-pc zmdc[4360]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
root@camera-pc:~#
Not sure how else to fix it. Im thinking i may not have enough memory in this pc for zoneminder to run with my cameras. Any help would be appreciated.
thanks
Here are my logs.
root@camera-pc:~#
Video Capabilities
Type: 7
Can capture
Can tune
Does teletext
Video Channels: 5
Audio Channels: 0
Maximum Width: 720
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Colour Depth: 0
Brightness: 32896
Hue: 32896
Colour :33026
Contrast: 33026
Whiteness: 0
Channel: 0
Flags: 1
Channel has a tuner
Type: 1 - TV
Format: 1 - NTSC
Channel: 1
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel: 2
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel: 3
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel: 4
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
root@camera-pc:~#
root@camera-pc:~#
root@camera-pc:~#
thanks
