ubuntu 9.04 desktop with zoneminder 1.23.3
I am getting memory error in my logs and i added the kernel.shmmax and kernel.shmall with 33554432 as im running 512 megs of memory.
Here are my logs.
root@camera-pc:~# tail /var/log/messages
Nov 19 01:36:20 camera-pc zmdc[2427]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:36:20, pid = 3581]
Nov 19 01:36:20 camera-pc zmwatch[2468]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:36:20, pid = 3581]
Nov 19 01:36:20 camera-pc zmc_dvideo0[3581]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 01:36:20 camera-pc zmc_dvideo0[3581]: INF [New Debug Level = 0, New Debug Log = /tmp/zm_debug.log.03581]
Nov 19 01:36:30 camera-pc zmwatch[2468]: INF [Restarting capture daemon for FrontDoor, shared memory not valid]
Nov 19 01:36:30 camera-pc zmdc[3684]: INF ['zmc -d /dev/video0' started at 10/11/19 01:36:30]
Nov 19 01:36:30 camera-pc zmdc[2427]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:36:30, pid = 3684]
Nov 19 01:36:30 camera-pc zmwatch[2468]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:36:30, pid = 3684]
Nov 19 01:36:30 camera-pc zmc_dvideo0[3684]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 01:36:30 camera-pc zmc_dvideo0[3684]: INF [New Debug Level = 0, New Debug Log = /tmp/zm_debug.log.03684]
root@camera-pc:~# tail /tmp/zm_debug.log.03684
11/19/10 01:36:30.804853 zmc_dvideo0[3684].INF-zm_debug.c/305 [New Debug Level = 0, New Debug Log = /tmp/zm_debug.log.03684]
11/19/10 01:36:30.813352 zmc_dvideo0[3684].ERR-zm_local_camera.cpp/162 [Failed to setup memory: Invalid argument]
root@camera-pc:~#
root@camera-pc:~# zmu -q -d /dev/video0 -v
Video Capabilities
Name: Hauppauge WinTV PVR-150
Type: 7
Can capture
Can tune
Does teletext
Video Channels: 5
Audio Channels: 0
Maximum Width: 720
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 0 - Unknown
Colour Depth: 0
Brightness: 32896
Hue: 32896
Colour :33026
Contrast: 33026
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 1
Channel has a tuner
Type: 1 - TV
Format: 1 - NTSC
Channel 1 Attributes
Channel: 1
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel 2 Attributes
Channel: 2
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel 3 Attributes
Channel: 3
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel 4 Attributes
Channel: 4
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
root@camera-pc:~#
root@camera-pc:~# tail /tmp/zmwatch.log
11/19/2010 01:46:39.273503 zmwatch[4389].INF [Restarting capture daemon for FrontDoor, shared memory not valid]
11/19/2010 01:46:39.747202 zmwatch[4389].INF ['zmc -d /dev/video0' starting at 10/11/19 01:46:39, pid = 4649]
11/19/2010 01:46:49.749450 zmwatch[4389].INF [Restarting capture daemon for FrontDoor, shared memory not valid]
11/19/2010 01:46:50.231208 zmwatch[4389].INF ['zmc -d /dev/video0' starting at 10/11/19 01:46:50, pid = 4651]
11/19/2010 01:47:00.233471 zmwatch[4389].INF [Restarting capture daemon for FrontDoor, shared memory not valid]
11/19/2010 01:47:00.711218 zmwatch[4389].INF ['zmc -d /dev/video0' starting at 10/11/19 01:47:00, pid = 4653]
11/19/2010 01:47:10.713459 zmwatch[4389].INF [Restarting capture daemon for FrontDoor, shared memory not valid]
11/19/2010 01:47:11.179215 zmwatch[4389].INF ['zmc -d /dev/video0' starting at 10/11/19 01:47:11, pid = 4655]
11/19/2010 01:47:21.181515 zmwatch[4389].INF [Restarting capture daemon for FrontDoor, shared memory not valid]
11/19/2010 01:47:21.651355 zmwatch[4389].INF ['zmc -d /dev/video0' starting at 10/11/19 01:47:21, pid = 4657]
root@camera-pc:~#
root@camera-pc:~# tail /var/log/syslog
Nov 19 01:56:47 camera-pc zmc_dvideo0[5044]: ERR [Failed to setup memory: Invalid argument]
Nov 19 01:56:47 camera-pc zmdc[4360]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Nov 19 01:56:57 camera-pc zmwatch[4389]: INF [Restarting capture daemon for FrontDoor, shared memory not valid]
Nov 19 01:56:57 camera-pc zmdc[5046]: INF ['zmc -d /dev/video0' started at 10/11/19 01:56:57]
Nov 19 01:56:57 camera-pc zmdc[4360]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:56:57, pid = 5046]
Nov 19 01:56:57 camera-pc zmwatch[4389]: INF ['zmc -d /dev/video0' starting at 10/11/19 01:56:57, pid = 5046]
Nov 19 01:56:57 camera-pc zmc_dvideo0[5046]: INF [Debug Level = 0, Debug Log = <none>]
Nov 19 01:56:57 camera-pc zmc_dvideo0[5046]: INF [New Debug Level = 0, New Debug Log = /tmp/zm_debug.log.05046]
Nov 19 01:56:57 camera-pc zmc_dvideo0[5046]: ERR [Failed to setup memory: Invalid argument]
Nov 19 01:56:57 camera-pc zmdc[4360]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
root@camera-pc:~#
Not sure how else to fix it. Im thinking i may not have enough memory in this pc for zoneminder to run with my cameras. Any help would be appreciated.
thanks
Here are my logs.
root@camera-pc:~#
Video Capabilities
Type: 7
Can capture
Can tune
Does teletext
Video Channels: 5
Audio Channels: 0
Maximum Width: 720
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Colour Depth: 0
Brightness: 32896
Hue: 32896
Colour :33026
Contrast: 33026
Whiteness: 0
Channel: 0
Flags: 1
Channel has a tuner
Type: 1 - TV
Format: 1 - NTSC
Channel: 1
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel: 2
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel: 3
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel: 4
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
root@camera-pc:~#
root@camera-pc:~#
root@camera-pc:~#
thanks
I believe you're thinking right. 512MB is enough to run Linux and ZM, have a look: http://www.zoneminder.com/forums/viewto ... red+memory. I've run two camera's at 640*480 on 512 MB without any issues but your card might be an issue depending on the kernel: http://www.zoneminder.com/wiki/index.ph ... VR_150/160
So what kernal version should I be using? kernel 2.6.16? Its weird that ivtv commands v4lt-ctl commands all work fine and I can save the video fromthe command using ivtv and it shows the video. I added the correct values for my 512 mgs of ram but still gets the shared memory invalid. So it doesn't like the memory.
Kernel 2.6.16 or newer. Shared memory values for ZM are not determined by how much memory you have available but by ring buffer size x image width x image height x 3 (for 24 bit images) + a bit of overhead (covered in the wiki). A base value of 134217728 for shmall and shmmax is what I see mostly posted, this is good for 320*240 resolutions but won't work for 640*480. The programs you list as working probably map their memory use (I'm guessing) and aren't using the shared. It's not unusual for browsers, VLC, MPlayer, and others to display a picture/stream with nothing showing up in ZM. It usually boils down to source settings or shared memory.
Here is my output from uname -r. So i am running a new version of the kernel that 2.6.16bb99 wrote:Kernel 2.6.16 or newer. Shared memory values for ZM are not determined by how much memory you have available but by ring buffer size x image width x image height x 3 (for 24 bit images) + a bit of overhead (covered in the wiki). A base value of 134217728 for shmall and shmmax is what I see mostly posted, this is good for 320*240 resolutions but won't work for 640*480. The programs you list as working probably map their memory use (I'm guessing) and aren't using the shared. It's not unusual for browsers, VLC, MPlayer, and others to display a picture/stream with nothing showing up in ZM. It usually boils down to source settings or shared memory.
root@camera-pc:/tmp# uname -r
2.6.28-11-generic
also i changed my values to what you have and still getting a failed to setup memory: invalid argument in the zm_debug.log.32761PacoLM wrote:Hi,
Debian 5 (Linux sheevaplug-debian 2.6.32-00007-g56678ec #1 PREEMPT Mon Feb 8 03:49:55 PST 2010 armv5tel GNU/Linux), running a in Guruplug with 512Mbytes of RAM, with 2 ipcams working in a 320x240, my settings for shared memory:
kernel.shmmax = 536870912
kernel.shmall = 805306368
Regards,
PacoLM
i also have an update for zoneminder to the latest version. Should i go with the update or will that not made a difference at all. Also here is some more output.
root@camera-pc:~# sudo zmu -q -d /dev/video0
N:Hauppauge WinTV PVR-150,T:7,nC:5,nA:0,mxW:720,mxH:480,mnW:48,mnH:32,X:0,Y:0,W:320,H:240,P:0,D:0,B:32896,h:32896,Cl:33026,Cn:33026,w:0,n0:Tuner 1,C0:0,Fl0:1,T0:1F0:1,,n1:S-Video 1,C1:1,Fl1:0,T1:2F1:1,,n2:Composite 1,C2:2,Fl2:0,T2:2F2:1,,n3:S-Video 2,C3:3,Fl3:0,T3:2F3:1,,n4:Composite 2,C4:4,Fl4:0,T4:2F4:1
oot@camera-proot@camera-pc:~# lsmod | grep video
video 25360 0
output 11008 1 video
videodev 41600 3 msp3400,tuner,ivtv
v4l1_compat 21764 1 videodev
root@camera-pc:~# ps axo user,command | grep zm
www-data /usr/bin/perl -wT /usr/bin/zmdc.pl startup
www-data /usr/bin/perl -wT /usr/bin/zmfilter.pl
www-data /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
www-data /usr/bin/perl -wT /usr/bin/zmwatch.pl
www-data /usr/bin/perl -w /usr/bin/zmupdate.pl -c
root grep zm
root@camera-pc:~#
root@camera-pc:/tmp# tail /tmp/zm_debug.log.13618
11/21/10 20:08:26.525687 zmc_dvideo0[13618].DB1-zm_local_camera.cpp/92 [Old D:0]
11/21/10 20:08:26.525705 zmc_dvideo0[13618].DB1-zm_local_camera.cpp/93 [Old B:32896]
11/21/10 20:08:26.525722 zmc_dvideo0[13618].DB1-zm_local_camera.cpp/94 [Old h:32896]
11/21/10 20:08:26.525740 zmc_dvideo0[13618].DB1-zm_local_camera.cpp/95 [Old Cl:33026]
11/21/10 20:08:26.525757 zmc_dvideo0[13618].DB1-zm_local_camera.cpp/96 [Old Cn:33026]
11/21/10 20:08:26.529592 zmc_dvideo0[13618].DB1-zm_local_camera.cpp/140 [Old X:0]
11/21/10 20:08:26.529611 zmc_dvideo0[13618].DB1-zm_local_camera.cpp/141 [Old Y:0]
11/21/10 20:08:26.529629 zmc_dvideo0[13618].DB1-zm_local_camera.cpp/142 [Old W:320]
11/21/10 20:08:26.529646 zmc_dvideo0[13618].DB1-zm_local_camera.cpp/143 [Old H:240]
11/21/10 20:08:26.529702 zmc_dvideo0[13618].ERR-zm_local_camera.cpp/162 [Failed to setup memory: Invalid argument]
root@camera-pc:~# sysctl -p
root@camera-pc:~# ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 524288
max total shared memory (kbytes) = 3221225472
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 989
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
video 25360 0
root grep zm
root@camera-pc:~#
If you update now you might solve the problem or more likely have to start completely over. A better suggestion would be to get a copy of ZoneMinder LiveCD 1.23.3 or better yet ZoneMinder 1.24.2 on Arch Linux live CD from Linuxtracker, boot it (don't install), and configure a monitor (camera). If you get it working the problem is in the Ubuntu install. Be sure to use 320*240 resolution, greyscale, and device path of /dev/video0, with a channel of 0. Toggle the Vfl choice between 1 and 2; and try both ntsc and pal. Ross' live CD's are very valuable for this type of troubleshooting.
ok i cant download torrent at work but will give this a try after i download it at home. I also was browsing the capture file size for pvr 150 and pvr 250 cards. Heres the info i got. So should i be putting this information in zoneminder.bb99 wrote:If you update now you might solve the problem or more likely have to start completely over. A better suggestion would be to get a copy of ZoneMinder LiveCD 1.23.3 or better yet ZoneMinder 1.24.2 on Arch Linux live CD from Linuxtracker, boot it (don't install), and configure a monitor (camera). If you get it working the problem is in the Ubuntu install. Be sure to use 320*240 resolution, greyscale, and device path of /dev/video0, with a channel of 0. Toggle the Vfl choice between 1 and 2; and try both ntsc and pal. Ross' live CD's are very valuable for this type of troubleshooting.
Pvr-150 (MPEG1)
-320X 240 (NTSC)
-352X288 (PAL/SECAM)
Pvr-250 (MPEG1)
-352-480 (NTSC)
-352-576 (PAL/SECAM)
After playing with the /etc/modprobe.d/ivtv file i am seeing these errors in dmesg. Here is exactly what is in the modprobe.d/ivtv file.
#wintv pvr 150
alias char-major-81-0 ivtv
#winTV PVR 250
alias char-major-81-1 ivtv
root@camera-pc:~# dmesg | grep Initialized
[ 14.451112] ivtv0: Initialized card #0: Hauppauge WinTV PVR-150
[ 14.829903] ivtv1: Initialized card #1: Hauppauge WinTV PVR-250
[ 48.150413] [drm] Initialized drm 1.1.0 20060810
[ 48.185144] [drm] Initialized i810 1.4.0 20030605 on minor 0
my dmesg log:
[ 48.183693] pci 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 48.183705] pci 0000:00:02.0: setting latency timer to 64
[ 48.282510] mtrr: base(0xec000000) is not aligned on a size(0x12c000) boundary
[ 48.294354] [drm] Using v1.4 init.
[ 51.504017] [drm:drm_release] *ERROR* reclaim_buffers_locked() deadlock.
Please rework this
[ 51.504025] driver to use reclaim_buffers_idlelocked() instead.
[ 51.504029] I will go on reclaiming the buffers anyway.
[ 58.072035] eth0: no IPv6 routers present
Now when i run these commands:
root@camera-pc:~# cat /dev/video1 > /home/joe/test_capture1.mpg (doesnt work)
root@camera-pc:~# cat /dev/video0 > /home/joe/test_capture.mpg (works)
The dmsg | grep Intialized shows Video1 is there. I really dont get this.
#wintv pvr 150
#winTV PVR 250
my dmesg log:
Please rework this
I was under the impression you were working on one card at a time, if I'm wrong pull the 250 out for now; it's much harder to get two working initially. Do this with the 1.24.2 live CD also, remember: the idea for now is to just get it working then make changes.
The settings mentioned earlier belong on the monitor -> source tab when setting up the monitor. If the values I've posted (widely supported by capture cards) don't work you can substitute the resolution values you've listed.
Just brought up a seed for both LiveCD's mentioned earlier, should be able to bump up your download by at least 250 - 300 kB/sec.
Just to be sure, did you get a look at this: http://www.zoneminder.com/forums/viewto ... deo+output
yeah i seen this post yesterday and thinking the pvr-150 is not supported so looking for more open-source security camera software for linux but not having much luck. I also have a q-see 4 channel dvr pci card but on on the q-see site it only shows supported in windows and tried to search google linux for it but no luck. I was thinking of just putting the card in and seeing if linux would recognize it.bb99 wrote:Just to be sure, did you get a look at this: http://www.zoneminder.com/forums/viewto ... deo+output
Users browsing this forum: No registered users and 15 guests
