I did a search for this but couldn't find anything. Sorry if this is a repost maybe i'm just not wording my search right. Anyway, onto my problem...
I have a script to import my cameras and filters from a SQL backup when I reload a server. One of the filters is the PurgeWhenFull which is set to run in background. But each time I setup a new server, the events drive gets full and I have go manually start the filter. So it doesn't appear the filter is actually running even though it was imported with the run in background set.
Is there a command I can add to my install script after i've imported the tables from my SQL backup that will execute or start the filter?
