No Video....
No Video....
After lots of searching the forums, wikis and docs: i have run into a very particular problem. My usb web cam works with cheese, xawtv and almost Zoneminder.
The light comes on when I run Zoneminder but when I select "Cam1" the is not video displayed, just a white square with a broken page in the corner.
So now if I click to create a new zone it takes i can see the image from my webcam but still no live feed.
I know i have a path wrong somewhere but im not sure which one. I know something isn"t talking to the next one =)
Could somoe one of point me in the right direction? i didn't post any logs because im not sure which if any to post.
Thanks in Advance
Ubuntu 9.04 32 Bit Desktop
4 gigs of ram.
Logitect C500 USB Webcam (on the approved list)
Zoneminder 1.23.3 (from the Ubuntu repositories)
Thanks in Advance
4 gigs of ram.
ok,
I dont see anything here> but you might. (From message.log)
Apr 9 18:39:26 chmiel-desktop zmdc[8182]: INF ['zmaudit.pl -c' starting at 10/04/09 18:39:26, pid = 8208]
Apr 9 18:39:26 chmiel-desktop zmfilter[8206]: INF [Scanning for events] Apr 9 18:39:22 chmiel-desktop zmpkg[8175]: INF [Command: start]
Apr 9 18:39:22 chmiel-desktop zmdc[8182]: INF [Server starting at 10/04/09 18:39:22]
Apr 9 18:39:26 chmiel-desktop zmdc[8182]: INF ['zmc -d /dev/video0' starting at 10/04/09 18:39:26, pid = 8204]
Apr 9 18:39:26 chmiel-desktop zmdc[8204]: INF ['zmc -d /dev/video0' started at 10/04/09 18:39:26]
Apr 9 18:39:26 chmiel-desktop zmc_dvideo0[8204]: INF [Debug Level = 0, Debug Log = <none>]
Apr 9 18:39:26 chmiel-desktop zmdc[8182]: INF ['zmfilter.pl' starting at 10/04/09 18:39:26, pid = 8206]
Apr 9 18:39:26 chmiel-desktop zmdc[8206]: INF ['zmfilter.pl' started at 10/04/09 18:39:26]
Apr 9 18:39:26 chmiel-desktop zmc_dvideo0[8204]: INF [Starting Capture]
Apr 9 18:39:26 chmiel-desktop zmdc[8208]: INF ['zmaudit.pl -c' started at
Apr 9 18:39:26 chmiel-desktop zmdc[8182]: INF ['zmwatch.pl' starting at 10/04/09 18:39:26, pid = 8211]
Apr 9 18:39:26 chmiel-desktop zmdc[8211]: INF ['zmwatch.pl' started at 10/04/09 18:39:26]
Apr 9 18:39:26 chmiel-desktop zmdc[8213]: INF ['zmupdate.pl -c' started at 10/04/09 18:39:26]
Apr 9 18:39:26 chmiel-desktop zmdc[8182]: INF ['zmupdate.pl -c' starting at 10/04/09 18:39:26, pid = 8213]
Apr 9 18:39:26 chmiel-desktop zmwatch[8211]: INF [Watchdog starting]
Apr 9 18:39:26 chmiel-desktop zmwatch[8211]: INF [Watchdog pausing for 30 seconds]
Apr 9 18:40:33 chmiel-desktop zmc_dvideo0[8204]: INF [Cam1: 1000 - Capturing at 14.93 fps]
Apr 9 18:41:40 chmiel-desktop zmc_dvideo0[8204]: INF [Cam1: 2000 - Capturing at 14.93 fps]
Apr 9 18:42:47 chmiel-desktop zmc_dvideo0[8204]: INF [Cam1: 3000 - Capturing at 14.93 fps]
Apr 9 18:43:53 chmiel-desktop zmc_dvideo0[8204]: INF [Cam1: 4000 - Capturing at 15.15 fps]
Apr 9 18:45:00 chmiel-desktop zmc_dvideo0[8204]: INF [Cam1: 5000 - Capturing at 14.93 fps]
Apr 9 18:46:07 chmiel-desktop zmc_dvideo0[8204]: INF [Cam1: 6000 - Capturing at 14.93 fps]
Apr 9 18:47:14 chmiel-desktop zmc_dvideo0[8204]: INF [Cam1: 7000 - Capturing at 14.93 fps]
Apr 9 18:48:21 chmiel-desktop zmc_dvideo0[8204]: INF [Cam1: 8000 - Capturing at 14.93 fps]
Apr 9 18:49:27 chmiel-desktop zmc_dvideo0[8204]: INF [Cam1: 9000 - Capturing at 15.15 fps]
Apr 9 18:50:34 chmiel-desktop zmc_dvideo0[8204]: INF [C
and apache error log
[Fri Apr 09 18:53:18 2010] [warn] NameVirtualHost *:80 has no VirtualHosts
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20060613+lfs/gd.so' - /usr/lib/php5/20060613+lfs/gd.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20060613+lfs/mcrypt.so' - /usr/lib/php5/20060613+lfs/mcrypt.so: cannot open shared object file: No such file or directory in Unknown on line 0
[Fri Apr 09 18:53:18 2010] [notice] Apache/2.2.11 (Ubuntu) PHP/5.2.6-3ubuntu4.5 with Suhosin-Patch configured -- resuming normal operations
[Fri Apr 09 18:54:40 2010] [error] [client 127.0.0.1] File does not exist: /htdocs, referer: http://localhost/zm/index.php?view=watc ... 0&control=
[Fri Apr 09 18:54:44 2010] [error] [client 127.0.0.1] File does not exist: /htdocs, referer: http://localhost/zm/index.php?view=even ... c=0&page=1
[Fri Apr 09 18:54:50 2010] [error] [client 127.0.0.1] File does not exist: /htdocs
[Fri Apr 09 18:54:50 2010] [error] [client 127.0.0.1] File does not exist: /htdocs, referer: http://localhost/zm/index.php?view=even ... c=0&page=1
[Fri Apr 09 18:54:51 2010] [error] [client 127.0.0.1] File does not exist: /htdocs
[Fri Apr 09 18:54:57 2010] [error] [client 127.0.0.1] File does not exist: /htdocs, referer: http://localhost/zm/index.php?view=even ... c=0&page=1
[Fri Apr 09 18:55:01 2010] [error] [client 127.0.0.1] File does not exist: /htdocs
[Fri Apr 09 19:07:59 2010] [error] [client 127.0.0.1] File does not exist: /htdocs, referer: http://www.zoneminder.com/forums/viewto ... httpd+conf
[Fri Apr 09 19:08:06 2010] [error] [client 127.0.0.1] File does not exist: /htdocs, referer: http://www.zoneminder.com/forums/viewto ... httpd+conf
[Fri Apr 09 19:09:25 2010] [error] [client 127.0.0.1] File does not exist: /htdocs
[Fri Apr 09 19:20:26 2010] [error] [client 127.0.0.1] File does not exist: /htdocs, referer: http://localhost/zm/index.php?view=watc ... 0&control=
[Fri Apr 09 19:20:27 2010] [error] [client 127.0.0.1] File does not exist: /htdocs
Hmmm... nowonder... cambozola isn't used with firefox...
Read this link http://www.zoneminder.com/forums/viewto ... 50678b2be6
ok. that post isint the same issue im haveing>
I can access the Zoneminder control panel. i just cant stream any video. I triend un checking the ZM_OPT_CAMBOZOLA option and that didnt do anything either.
heres my apche2.conf
# Based upon the NCSA server configuration files originally by Rob McCool.
# This is the main Apache server configuration file. It contains the
# configuration directives that give the server its instructions.
# See http://httpd.apache.org/docs/2.2/ for detailed information about
# the directives.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
# The configuration directives are grouped into three basic sections:
# 1. Directives that control the operation of the Apache server process as a
# whole (the 'global environment').
# 2. Directives that define the parameters of the 'main' or 'default' server,
# which responds to requests that aren't handled by a virtual host.
# These directives also provide default values for the settings
# of all virtual hosts.
# 3. Settings for virtual hosts, which allow Web requests to be sent to
# different IP addresses or hostnames and have them handled by the
# same Apache server process.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path. If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "/var/log/apache2/foo.log"
# with ServerRoot set to "" will be interpreted by the
# server as "//var/log/apache2/foo.log".
### Section 1: Global Environment
# The directives in this section affect the overall operation of Apache,
# such as the number of concurrent requests it can handle or where it
# can find its configuration files.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation (available
# at <URL>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
#<IfModule>
#<IfModule>
LockFile /var/lock/apache2/accept.lock
#</IfModule>
#</IfModule>
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 15
## Server-Pool Size Regulation (MPM specific)
# prefork MPM
# StartServers: number of server processes to start
# MinSpareServers: minimum number of server processes which are kept spare
# MaxSpareServers: maximum number of server processes which are kept spare
# MaxClients: maximum number of server processes allowed to start
# MaxRequestsPerChild: maximum number of requests a server process serves
<IfModule>
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 150
MaxRequestsPerChild 0
</IfModule>
# worker MPM
# StartServers: initial number of server processes to start
# MaxClients: maximum number of simultaneous client connections
# MinSpareThreads: minimum number of worker threads which are kept spare
# MaxSpareThreads: maximum number of worker threads which are kept spare
# ThreadsPerChild: constant number of worker threads in each server process
<IfModule>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
</IfModule>
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files>
Order allow,deny
Deny from all
</Files>
# DefaultType is the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value. If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
DefaultType text/plain
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog /var/log/apache2/error.log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
# Include module configuration:
Include /etc/apache2/mods-enabled/*.load
Include /etc/apache2/mods-enabled/*.conf
# Include all the user configurations:
Include /etc/apache2/httpd.conf
# Include ports listing
Include /etc/apache2/ports.conf
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
# If you are behind a reverse proxy, you might want to change %h into %{X-Forwarded-For}i
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Define an access log for VirtualHosts that don't define their own logfile
CustomLog /var/log/apache2/other_vhosts_access.log vhost_combined
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# Putting this all together, we can internationalize error responses.
# We use Alias to redirect any /error/HTTP_<error>.html.var response to
# our collection of by-error message multi-language collections. We use
# includes to substitute the appropriate text.
# You can modify the messages' appearance without changing any of the
# default HTTP_<error>.html.var files by adding the line:
# Alias /error/include/ "/your/include/path/"
# which allows you to create your own set of files by starting with the
# /usr/share/apache2/error/include/ files and copying them to /your/include/path/,
# even on a per-VirtualHost basis. The default include files will display
# your Apache version number and your ServerAdmin email address regardless
# of the setting of ServerSignature.
# The internationalized error documents require mod_alias, mod_include
# and mod_negotiation. To activate them, uncomment the following 30 lines.
# Alias /error/ "/usr/share/apache2/error/"
# <Directory>
# AllowOverride None
# Options IncludesNoExec
# AddOutputFilter Includes html
# AddHandler type-map var
# Order allow,deny
# Allow from all
# LanguagePriority en cs de es fr it nl sv pt-br ro
# ForceLanguagePriority Prefer Fallback
# </Directory>
# ErrorDocument 400 /error/HTTP_BAD_REQUEST.html.var
# ErrorDocument 401 /error/HTTP_UNAUTHORIZED.html.var
# ErrorDocument 403 /error/HTTP_FORBIDDEN.html.var
# ErrorDocument 404 /error/HTTP_NOT_FOUND.html.var
# ErrorDocument 405 /error/HTTP_METHOD_NOT_ALLOWED.html.var
# ErrorDocument 408 /error/HTTP_REQUEST_TIME_OUT.html.var
# ErrorDocument 410 /error/HTTP_GONE.html.var
# ErrorDocument 411 /error/HTTP_LENGTH_REQUIRED.html.var
# ErrorDocument 412 /error/HTTP_PRECONDITION_FAILED.html.var
# ErrorDocument 413 /error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
# ErrorDocument 414 /error/HTTP_REQUEST_URI_TOO_LARGE.html.var
# ErrorDocument 415 /error/HTTP_UNSUPPORTED_MEDIA_TYPE.html.var
# ErrorDocument 500 /error/HTTP_INTERNAL_SERVER_ERROR.html.var
# ErrorDocument 501 /error/HTTP_NOT_IMPLEMENTED.html.var
# ErrorDocument 502 /error/HTTP_BAD_GATEWAY.html.var
# ErrorDocument 503 /error/HTTP_SERVICE_UNAVAILABLE.html.var
# ErrorDocument 506 /error/HTTP_VARIANT_ALSO_VARIES.html.var
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
Include /etc/apache2/conf.d/
# Include the virtual host configurations:
Include /etc/apache2/sites-enabled/
# the directives.
# at <URL>);
#<IfModule>
#<IfModule>
#</IfModule>
#</IfModule>
Timeout 300
KeepAlive On
KeepAliveTimeout 15
# prefork MPM
<IfModule>
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 150
</IfModule>
# worker MPM
<IfModule>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
</IfModule>
# directive.
<Files>
Order allow,deny
Deny from all
</Files>
# text.
# nameserver.
HostnameLookups Off
# alert, emerg.
LogLevel warn
# Some examples:
# <Directory>
# Order allow,deny
# Allow from all
# </Directory>
Hey Guys,
Thanks for the help. I ended up completely uninstalling apache, ZM, and hacked out all of the config files that were left behind. Then I cleared Synamtic Package Manager cache so i could get a new download of ZM.
After it installed, I had to chmod 777 video0 and increased the shared memory.
Viola ... its working now =)
Thanks again for the replies.
Ok first off you pallet if right if its report capturing @ 15 fps.
second the problem is right here
run
sudo apt-get install mcrypt gd
run
