Just managed to get Zoneminder installed and this happens when I go into Gedit to change a file:
root@Cameras:/home/brafferton# gedit
(gedit:3934): EggSMClient-WARNING **: Failed to connect to the session manager: None of the authentication protocols specified are supported
GConf Error: Failed to contact configuration server; some possible causes are that you need to enable TCP/IP networking for ORBit, or you have stale NFS locks due to a system crash. See http://projects.gnome.org/gconf/ for information. (Details - 1: Failed to get connection to session: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.)
This message repeats 52 times, but at about the 45th time, it also says:
(gedit:3934): GVFS-RemoteVolumeMonitor-WARNING **: cannot connect to the session bus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
This happens every single time!
It certainly did not do this before zoneminder was installed!
