Can't Login
nojstevens
Can't Login
Post by nojstevens » Sun Jul 05, 2009 3:35 pm
All was working quite well - added cameras etc. Then I switch authentication on.
Now I cannot login. I tried admin/admin, the system appears to logon for a brief second, then I get returned to the login screen. I read on another thread that I can turn authentication off in webmin. I took a look but I can't see how to do this. Could someone help me?
I am running Centos 5 with Zoneminder 1.23.3
Jon
________
Suzuki Alto Lapin History
kingofkya
Post by kingofkya » Mon Jul 06, 2009 1:50 am
a quick search tells you it is admin:admin
nojstevens
Post by nojstevens » Mon Jul 06, 2009 1:55 am
Yes, I found that, but when I enter it, it appears to login for a second and then returns to the logon page.
Jon
________
Buy bubblers
kingofkya
Post by kingofkya » Mon Jul 06, 2009 5:34 am
can you access the mysql database
nojstevens
Post by nojstevens » Mon Jul 06, 2009 11:09 am
Yes, I can access mysql from both ssh and webmin
Jon
________
Subaru Xt History
50cc
Post by 50cc » Mon Jul 06, 2009 5:35 pm
I had the same, I was curious what would happen if you delete the admin user.... You get no extra warning, it will delete it and that's it.
I used phpmyadmin to restore the admin user, ZoneMinder itself was unusable.
nojstevens
Post by nojstevens » Mon Jul 06, 2009 5:37 pm
Hi 50cc, thanks for your input - what exactly did you do - step wise - with phpmyadmin? I'm not familiar with this.
Any help would be much appreciated, I don't want to have to reinstall (again)!
Jon
________
Miyoshi plant (mazda)
50cc
Post by 50cc » Mon Jul 06, 2009 5:41 pm
http://<yourserver>/phpmyadmin
ZM database -> Users table -> Click on SQL at the top of the page.
Insert:
INSERT INTO `Users` (`Id`, `Username`, `Password`, `Language`, `Enabled`, `Stream`, `Events`, `Control`, `Monitors`, `Devices`, `System`, `MaxBandwidth`, `MonitorIds`) VALUES
(1, 0x61646d696e, '*4ACFE3202A5FF5CF467898FC58AAB1D615029441', '', 1, 'View', 'Edit', 'Edit', 'Edit', 'Edit', 'Edit', '', '');
Click Go.
nojstevens
Post by nojstevens » Mon Jul 06, 2009 5:47 pm
Great, thanks - will try tonight. Fingers crossed.
Jon
________
Volcano vaporizer
nojstevens
Post by nojstevens » Tue Jul 07, 2009 1:30 am
Hi, tried the above but still the same, can't logon.
This was working before i ticked the box to say 'require authorization' in the ZM Options page.
Would you know how to untick this option in a config file or in the mysql tables - that would allow me in again?
Thanks for your help
Jon
________
Vaporizer reviews
nojstevens
Post by nojstevens » Tue Jul 07, 2009 2:08 am
I reinstalled and all is ok now.
Thanks for the help
Jon
________
VAPORIZER AFFILIATE PROGRAM
mysterylectricity
Re: Can't Login
Post by mysterylectricity » Fri Feb 17, 2017 2:38 am
This worked for me:
mysql -u root -p
Enter password:
If you have not set an explicit password for mysql, the system root password worked for me.
Then select the zm database:
use zm;
Then enter the following:
(1, 'admin', '*3B34B40DAE3DD1E15943B37622F688A6D7F8002D', 'en_gb', 1, 'View', 'Edit', 'Edit', 'Edit', 'Edit', 'Edit', '', '');
This will set the default login to admin and the password to changepassword
dad1
Re: Can't Login
Post by dad1 » Wed Feb 13, 2019 12:31 pm
Thanks to mysterylectricity for pointing at a solution having just locked myself out by enabling authentication.
As an enhacement to his solution in the post above, if you have an existing admin user then use this SQL command instead of the INSERT:
UPDATE `Users` set Password = '*3B34B40DAE3DD1E15943B37622F688A6D7F8002D' where `Id` = 1;
You should then be able to log in using:
Username: admin
Password: changepassword
Users browsing this forum: No registered users and 18 guests
