Axis 221 problem with /axis-cgi/mjpg/video.cgi
craver84
Post by craver84 » Sun May 24, 2009 12:32 pm
I've got 2 axis cameras, axis207 and axis221. this is my problem:
for axis207 I use:
/axis-cgi/mjpg/video.cgi and everything works well
If I use this setting for axis221, there is always a delay of 7-10 seconds compared to the axis live view.
Instead if I use /axis-cgi/jpg/image.cgi it seams to work, not fluent, but works.
the problem is that the motion detection doesn't record nothing, I thing this is due to this setting.
Can you confirm? Any suggestion?
craver84
Post by craver84 » Mon May 25, 2009 11:51 am
nobody with a axis 221?
kingofkya
Post by kingofkya » Mon May 25, 2009 5:52 pm
there is always gona be a delay if you are monitoring it live use the shared memory viewer its less delayed but still is a little bit.
hers why
1. the camera itself is delayed
2. network dely
3. per buffer in zoneimeder 10 frames default
4. delay from apache to webbrowser
craver84
Post by craver84 » Tue May 26, 2009 10:19 am
It's not only a delay... some frames are not shown.
I have this problem only with 221, axis 207, with the same settings works great!
kingofkya
Post by kingofkya » Tue May 26, 2009 2:43 pm
turn on some debug and put _zms in the box see what comes up
coke
221
Post by coke » Tue May 26, 2009 2:46 pm
The source I use on my 221 is
/axis-cgi/mjpg/video.cgi?resolution=640x480
Mine is only set to 1 FPS at the moment due to needing up to a 2 second exposure in it's current very dark location. On the positive side, with the long exposure, my 221 can see better there than I can in person.
My 207's use exactly the same source settings, and I think there's not even a 1/10th second delay. I haven't really measured that, but I can tell when I'm calling the front desk about something while watching them on a camera.
My 207w's have a very slight delay, being wireless, but when I cranked up the compression, they achieved MUCH higher frame-rates than otherwise.
Users browsing this forum: No registered users and 8 guests
