I just reinstalled my ZM system to Fedora Core 10, but made the partitions wrong. I created a huge /usr partition, when I should have created a huge /var partition.
Is there an easy way to "rearrange" these? I suppose it could be done via symlinks, but other than that, I would be willing to reinstall from scratch since I just did it. Which leads to my (other) question:
How can I "backup" everything in the database, reinstall the OS, then "restore" it? In the "old days", somebody had created an awesome "backup-zm" and "restore-zm" script, that would do exactly that...but that doesn't work when you install via the repository (due to the naming). What would be the commands to do this manually?
backup -- then restore
The backup script should still work for the most part. Not sure which one you were using, I had made a very basic one and Ross made one that was a bit more intuitive with a few more features. The basic one would not be difficult to adapt.
For the most part it just runs mysqldump and puts most of the tables in a flat file and tars it all up.
mysqldump zm -u <zm_db_user> -p > zm-db-backup.sql
This will get everything in the database.
To restore a database you do the following at the console.
mysql -u <mysql_root> -p zm < zm-db-backup.sql
If you get an error that the database zm dosen't exist you type
mysqladmin -u <mysql_root> -p create zm
and then try again the db restore again.
Then you'd want to set the zm_db_user permissions if you havent' done so already on the restored system by typing
then
grant select,insert,update,delete on zm.* to '<zm_db_user>'@localhost identified by '<zm_db_user_password>';
then
