I run zm on a machine with mobilebroadband (T-Mobile).
I want to be able to see live streams over this connection, but it appears that T-Mobile block the ports.
Can anyone suggest a way to view the cameras in realtime over the internet ?.
Mobilebroadband
OP: you can change the port Apache listens on, then open up the relevant port on your router. How to do this is beyond the scope of a single post, and running a home server that is accessible on the internet is almost always disallowed by home broadband providers (and mobile providers as well). That said, if you run a password protected site on a non-standard port and only use it yourself for limited traffic, most likely no one will hassle you.
Then change the port Apache listens on in your ZM box. Since you don't have a router, you skip that step. In your httpd.conf, set "Listen 80" to "Listen 90" and try accessing your box at:
(restart apache)
<<ipaddress>>:90
Edit: I just saw your first line, every port is blocked? interesting, maybe you're hosed then?
(restart apache)
<<ipaddress>>:90
OK, i finally managed to find some time to figure this out, so here is a short howto.
Using ssh reverse tunneling.
I have three systems. Mobile (usb mobile broadband connection), Server, this is my Linux hosted server for all my websites, running debian and i have full ssh access. Home, a number of systems on an ADSL connection. (Instead of using server, i could probably use a shell account freely available on the net)
I want to be able to see what is hapenning at my mobile site (using zm),from home but can't because it's NAT'd and firewalled out.
First make a change on Server, edit the sshd_config file, and uncomment the "GatewayPorts" statement and change it from "no" to "yes". Reboot the ssh server.
Now from Mobile, issue the following command. ssh -N -f -R 19823:localhost:80 Server
Replace Server with the ip address of your own machine thats going to act as a way of accessing zm.
Normally, when i want to go to a webpage on my web Server machine (from Home), i will type in this "http://www.Server.com" , by default your browser looks for web pages on port 80, but if you are running a server on a different port, you have to tell the browser to use a different port, by adding a colon (:) then the port number. In this instance, I want to access port 19823, so i would use http://www.Server.com:19823. Providing you followed the instructions above correctly, you should access the webserver running on Mobile.
This worked for me flawlessly, it's not automatic as I have to enter a password at the start of the ssh connection, and I'm sure that the connection will die if there's no traffic, thats next on the agenda.
Hope this helps someone.
