Export ZIP problem
Alan87i
Export ZIP problem
Post by Alan87i »
When I export as a tar file all is fine but when I try ZIP I get this error.
Warning: opendir(events/Cam2/4951) [function.opendir]: failed to open dir: No such file or directory in /usr/share/zoneminder/zm_export_funcs.php on line 198
Export Failed
I'm setting this up for a friend and he is a windows user.
Thanks for any ideas.
Allan
coke
Post by coke »
You're better off fixing your problem locally, in the long run, but WinRAR doesn't mind .zip, .tar, etc.
Lee Sharp
Post by Lee Sharp »
Do you have zip installed and enabled?
Alan87i
Post by Alan87i »
Yes
I forgot to mention I'm running Ubuntu 8.04 zip works fine just not when I export with Zoneminder
coke
Post by coke »
Uploaded events may be stored in either .tar or .zip format, this option specifies which. Note that to use this you will need to have the Archive::Tar and/or Archive::Zip perl modules installed.
Do you have zip perl modules installed, or just zip?
Alan87i
Post by Alan87i »
Yes I just checked and the lib perl module for tar and zip are installed.
kingofkya
Post by kingofkya »
This Happen to me also Check To see if you have a symlink for each cam in event directory Ex Cam link to folder 1
zlatan24
Re: Export ZIP problem
Post by zlatan24 »
Alan87i wrote:When I export as a tar file all is fine but when I try ZIP I get this error.
Export Failed
Allan
Zip files are very popular everywhere. Not so long ago I dug up a program which can resolve like problems - fix zip error.
Flash_
Post by Flash_ »
Can you please stop re-opening two year old threads? The original poster has long since resolved their problem.
