How can I get zmcontrol-IP9100.pl patch?
tropdelaballe
Post by tropdelaballe » Tue Sep 09, 2008 4:38 pm
How can I get zmcontrol-IP9100.pl patch as it doesn't seem to be implemented to zm1.23.3?
Best regards
Patrick
3gem
Re: How can I get zmcontrol-IP9100.pl patch?
Post by 3gem » Wed Oct 08, 2014 2:32 am
I found it using the wayback machine..
#!/usr/bin/perl -wT
# ZoneMinder Aviosys 9100 Control Script, $Date: 2007/05/03 11:23:05 $, $Revision: .1 $
# Copyright (C) 2006 Glenn Neufeld
# Adapted From:
# ZoneMinder VISCA Control Script, $Date: 2005/07/14 08:53:15 $, $Revision: 1.6 $
# Copyright (C) 2003, 2004, 2005  Philip Coombes
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
#use strict;
#use Switch;
# These are the elements you need to edit to suit your installation
use constant DBG_ID => "zmctrl-ip9100";	# Tag that appears in debug to identify source
use constant DBG_LEVEL => 3;		# 0 is errors, warnings and info only, > 0 for debug
use ZoneMinder;
use Getopt::Long;
use LWP::UserAgent;
$| = 1;
$ENV{PATH}  = '/bin:/usr/bin';
$ENV{SHELL} = '/bin/sh' if exists $ENV{SHELL};
delete @ENV{qw(IFS CDPATH ENV BASH_ENV)};
sub Usage
    print( "
Usage: zmcontrol-SNC-M3W.pl <various options>
    exit( -1 );
zmDbgInit( DBG_ID, level=>DBG_LEVEL );
my $arg_string = join( " ", @ARGV );
my $device = "";
my $address = "192.168.1.116";
my $command = "";
my $speed = 0;
my $step = 0;
my $xcoord = 0;
my $ycoord = 0;
my $panspeed = 0;
my $tiltspeed = 0;
my $panstep = 0;
my $tiltstep = 0;
my $preset = 0;
# Massive array of http commands and possible args:
# This script for this 4-port video digitizer only switches feeds using the presets
my %cameraCommands =
	 'preset_goto' => '$evalString = "/SetChannel.cgi?Channel=$preset"',
	 'preset_set' => '$evalString = "/SetChannel.cgi?Channel=$preset"'
if ( !GetOptions(
		 'device=s'=>\$device,
		 'address=i'=>\$address,
		 'command=s'=>\$command,
		 'speed=i'=>\$speed,
		 'step=i'=>\$step,
		 'xcoord=i'=>\$xcoord,
		 'ycoord=i'=>\$ycoord,
		 'panspeed=i'=>\$panspeed,
		 'tiltspeed=i'=>\$tiltspeed,
		 'panstep=i'=>\$panstep,
		 'tiltstep=i'=>\$tiltstep,
		 'preset=i'=>\$preset
    Usage();
srand( time() );
Debug( "Passed => " . $arg_string . "\n" );
sub doCommand
# Given a zm_command, execute it using http commo to the camera
    my $httpCommand = "";
#    my $command = @_;
    Debug ("doCommand => " . $command."\n");
    $httpCommand = $cameraCommands{ $command };
    Debug("doCommand => " . $httpCommand . "\n" );
    #print( $httpCommand . "\n" );
    if ( $httpCommand )
	my $result = "";
	my $a = "";
	my $evalString = "";
	#eval($httpCommand);
	#print $evalString;
	$httpCommand = "http://$address" . eval($httpCommand);
	#$httpCommand =~ s/ //g;
	$ua = LWP::UserAgent->new;
	$ua->agent( "ZoneMinder Control Agent/".ZM_VERSION );
	Debug( $httpCommand );
	#print( $httpCommand."\n" );
	$req = HTTP::Request->new( GET=>$httpCommand );
	$res = $ua->request($req);
	#print( $res->as_string );
	if ( $res->is_success )
	    $result = !undef;
	else
	    Error( "doCommand => Error check failed: '".$res->status_line()."'\n" );
	#print( $result."\n" );
    else
	{ Debug("Error, can't handle command $command\n")}
# Usage here, too
if ( $command eq "" )
    Usage();
if ( $command eq "preset_set" )
    Debug("That tickles!");
# Device uses 0-3 (zero-based), ZM uses 1-4 (1-based)
# Input "-1" seems to make the device round-robin the *stream* ?!?!
if ( $preset == 0 )
    Debug("Get the YOICS ROM if you want 4 feeds!");
    exit( -1 );
$preset -= 1;
# Run it
doCommand( $command );
Posting here for record purposes
