Zonminder suddenly stopped recording.
godsyn
Post by godsyn » Thu Aug 21, 2008 1:51 pm
ZoneMinder Running - v1.23.3
I have recorded past events without issue. Recently, it has stopped.
.../www/events$ ls -lah
total 12K
drwxr-xr-x 3 www-data www-data 4.0K 2008-08-17 11:10 .
drwxr-xr-x 5 www-data www-data 4.0K 2008-08-15 01:08 ..
drwxr-xr-x 3 www-data www-data 4.0K 2008-08-20 21:55 1
lrwxrwxrwx 1 www-data www-data    1 2008-08-13 13:13 Garage -> 1
Repeated in apache2's error.log is:
[Wed Aug 20 23:23:24 2008] [warn] [client 192.168.1.1] Timeout waiting for output from CGI script /usr/lib/cgi-bin/nph-zms, referer: http://cam.godsyn.com/index.php?view=watchfeed&mode=&mid=1&scale=100&control=
Where should I go from here? (i can see the stream. When I force event, nothing records)
jameswilson
Post by jameswilson » Thu Aug 21, 2008 1:57 pm
is the database ok?
James Wilson
godsyn
Post by godsyn » Thu Aug 21, 2008 8:40 pm
jameswilson wrote:is the database ok?
CHECK TABLE `Config` , `ControlPresets` , `Controls` , `Devices` , `Events` , `Filters` , `Frames` , `Groups` , `MonitorPresets` , `Monitors` , `States` , `Stats` , `TriggersX10` , `Users` , `ZonePresets` , `Zones`
| Table             | Op    | Msg_type | Msg_text |
| zm.Config         | check | status   | OK       |
| zm.ControlPresets | check | status   | OK       |
| zm.Controls       | check | status   | OK       |
| zm.Devices        | check | status   | OK       |
| zm.Events         | check | status   | OK       |
| zm.Filters        | check | status   | OK       |
| zm.Frames         | check | status   | OK       |
| zm.Groups         | check | status   | OK       |
| zm.MonitorPresets | check | status   | OK       |
| zm.Monitors       | check | status   | OK       |
| zm.States         | check | status   | OK       |
| zm.Stats          | check | status   | OK       |
| zm.TriggersX10    | check | status   | OK       |
| zm.Users          | check | status   | OK       |
| zm.ZonePresets    | check | status   | OK       |
| zm.Zones          | check | status   | OK       |
all is well.
godsyn
Post by godsyn » Thu Aug 21, 2008 8:50 pm
Disregard. deleting and re-adding the cam resolved the issue.
bad zone config, perhaps..
W.
Post by W. » Fri Aug 22, 2008 7:33 am
if you dont have ZM_USE_DEEP_STORAGE enabled, you might have hit 32k file (directory) limit. Check how many events are there for your old monitor.
if common sense is so uncommon, why is it called common then?
Users browsing this forum: No registered users and 21 guests
