ZM on Debian - can't open via web.
ramz
Post by ramz »
I have a Debian 4.0_r3 system:
debian:~# uname -a
Linux debian 2.6.18-6-686 #1 SMP Sun Feb 10 22:11:31 UTC 2008 i686 GNU/Linux
with Apache2 which was set up in the following way:
 aptitude install apache2
MySQL with was installed from source
debian:~# mysql -V
mysql  Ver 14.12 Distrib 5.0.51b, for pc-linux-gnu (i686) using  EditLine wrapper
and "aptitude install libmysqlclient15-dev" for mysql header files.
I have installed the ZM from source - ZoneMinder-1.23.3.tar.gz
And when I try to get access via web: http://192.168.1.103/zm/
I get the following error:
Warning: mysql_pconnect() [function.mysql-pconnect]: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) in /var/www/zm/zm_db.php on line 27
Could not connect to database: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
There is no mysql folder under /var/run/
according to /etc/my.cnf, socket file is in /tmp folder:
# The following options will be passed to all MySQL clients
[client]
#password       = your_password
port            = 3306
socket          = /tmp/mysql.sock
# Here follows entries for some specific programs
# The MySQL server
[mysqld]
port            = 3306
What am I doing wrong ? Please advise.
theorganloft
Zoneminder on Debian
Post by theorganloft »
I do not know exactly how to fix that problem but I have a suggestion:
Why not load Ubuntu 7.10 and run apt-get install zoneminder? After Zoneminder installs, you will have to take a few more steps to get it going but it would be so much easier.
"Organs are my passion but music is my goal"
"Open Source and Open Mind help one to Open mine"
Lee Sharp
Post by Lee Sharp »
He is on Debian. He can just 'apt-get install zoneminder' right now.
As to your question, I do not know. I use the debs. :)
betulichergutmensch
Post by betulichergutmensch »
yeah sure he can!
i'd suggest you to change the folder to /var/run/mysqld and create it with following rights chown -R mysql:root /var/run/mysqld, because this is the standard path to the mysql socket file on debian systems... if you would have installed mysql through apt-get install mysql, it would be this way and you probably make a right ./configure with paths for your system... always remember to set right paths if compiling yourself, otherwise you will always get those messages with mixed up systems ;-)
theorganloft
Debian vs. Ubuntu Debian
Lee Sharp wrote:He is on Debian. He can just 'apt-get install zoneminder' right now.
I tried the Debian Distro. I had problems with it. It works but the Ubuntu Debian teams seem to do a better job of keeping up with updates.
