I just installed suse 10.3, basic installation with apache and mysql. I've added the liquid-co-de and packman repositories, but when I try to install zoneminder through yast it says there are missing dependencies for zoneminder and ffmpeg that it cannot resolve and it won't tell me what those dependencies are. Does anyone know what could be missing? Any help would be greatly appreciated.
Thanks, Michael
suse 10.3 missing dependencies
My reason for choosing Suse was the rpms for 1.23 zoneminder. I've had it running under fedora 8 with 1.22, but never got my webcams to work, now I have a compatable capture card and wanted to try 1.23. I think I would run into the same dependency problems from source, but maybe it would atleast tell me whats missing. I was just looking for the easiest installation method since my linux skills aren't the best.
Hi, try adding this repository in yast: http://packman.unixheads.com/suse/10.3/
In suse 1.2 I used this to get some, if not all, dependencies for zm v1.22.3
Hope this helps.
Hope this helps.
I finally got it, I ended up adding alot of repositories from http://en.opensuse.org/Additional_YaST_ ... positories
I figured something must be missing out of the basic installation. I then tried the zoneminder install and it added over 30 additional packages. It is now up and running except i get no output from my cameras. I'm not sure if its not configured right or what here is the output from zoneminder.
zmu -d /dev/video0 -q -v
Video Capabilities
Name: BT878 video ( *** UNKNOWN/GENER
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 320
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 3
Channel has a tuner
Channel has audio
Type: 1 - TV
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Video Capabilities
Type: 171
Can capture
Can tune
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 320
Picture Attributes
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel: 0
Flags: 3
Channel has a tuner
Channel has audio
Type: 1 - TV
Format: 0 - PAL
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
