Ubuntu 7.10 server/ZM 1.23.2 from src, how to (31/03/2008)
caladeira
Post by caladeira »
Update instructions from ZM 1.23.1 to 1.23.2.
bangbecak
Post by bangbecak »
Hi Caladeira,
I was trying your Ubuntu 7.10 server manual, but I found some problems as following:
1. On code:
./configure --enable-shared --enable-pp --enable-swscaler --enable-gpl --prefix=/opt/
I can't get the --enable--pp to work, so I proceed without --enable-pp
2. on code:
Alias /zm /var/www/html/zm
<Directory>
  php_flag register_globals off
  <IfModule>
    DirectoryIndex index.php
  </IfModule>
</Directory>
And when I run
sudo /etc/init.d/apache2 force-reload
It said "Syntax error on line 292 of /etc/apache2/apache2.conf" syntax error on line 5 of /etc/apache2/conf.d/zoneminder.conf: <IfModule> directive require additional arguments.
How do I solve those problems?
And one more question, how do I run zoneminder from webbrowser?because when I point to the this server, it didn't show anything.
Thank you and looking forward for your response.
George
PeterHoward
Post by PeterHoward »
bangbecak wrote:Hi Caladeira,
2. on code:
<Directory>
  <IfModule>
  </IfModule>
</Directory>
And when I run
The conf file from the debian/ubuntu package is:
Alias /zm /usr/share/zoneminder
<Directory /usr/share/zoneminder>
  <IfModule mod_dir.c>
  </IfModule>
</Directory>
No I don't fully understand it :) But it does work so I suggest you try it , with "/usr/share/zoneminder" changed to "/var/www/html/zm".
I suspect you're not seeing anything from the browser because apache isn't completing the setup due to the error mentioned.
PJH
caladeira
Post by caladeira »
Hello.
Reply to issue 1 related with ffmpeg:
The last time I've tested it It worked, but now It might not becouse current version from svn has changed (I suspect!).
Hoever, you may try using an older version of ffmpeg using this command:
svn checkout -r 11637 svn://svn.mplayerhq.hu/ffmpeg/trunk ffmpeg
If you search the forum you'll see that version 11637 is known as a good one to use with zoneminder.
Please try it and post results.
Best regards.
bangbecak
Post by bangbecak »
I tried this code (PeterHoward):
<Directory>
  <IfModule>
  </IfModule>
</Directory>
and it didn't give me error when running
However (Caladeira), I still getting error after running 'make' from
error as following:
make                    -C libavutil   all
make[1]: Entering directory `/home/george/ffmpeg/libavutil'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/george/ffmpeg/libavutil'
make                    -C libavcodec  all
make[1]: Entering directory `/home/george/ffmpeg/libavcodec'
make[1]: Leaving directory `/home/george/ffmpeg/libavcodec'
make                    -C libavformat all
make[1]: Entering directory `/home/george/ffmpeg/libavformat'
make[1]: Leaving directory `/home/george/ffmpeg/libavformat'
make                    -C libavdevice all
make[1]: Entering directory `/home/george/ffmpeg/libavdevice'
make[1]: Leaving directory `/home/george/ffmpeg/libavdevice'
make       -C libpostproc all
make[1]: Entering directory `/home/george/ffmpeg/libpostproc'
make[1]: Leaving directory `/home/george/ffmpeg/libpostproc'
make -C libswscale  all
make[1]: Entering directory `/home/george/ffmpeg/libswscale'
gcc  -DHAVE_AV_CONFIG_H -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_ISOC9X_SOURCE -I"/home/george/ffmpeg" -I"/home/george/ffmpeg" -I"/home/george/ffmpeg"/libavutil -fomit-frame-pointer -g -Wdeclaration-after-statement -Wall -Wno-switch -Wdisabled-optimization -Wpointer-arith -Wredundant-decls -Wno-pointer-sign -O3  -c -o rgb2rgb.o rgb2rgb.c
rgb2rgb.c:91: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:91: error: expected declaration specifiers or ‘...’ before ‘mmx_null’
rgb2rgb.c:91: warning: data definition has no type or storage class
rgb2rgb.c:91: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:91: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:92: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:92: error: expected declaration specifiers or ‘...’ before ‘mmx_one’
rgb2rgb.c:92: warning: data definition has no type or storage class
rgb2rgb.c:92: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:92: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:92: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:91: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:93: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:93: error: expected declaration specifiers or ‘...’ before ‘mask32b’
rgb2rgb.c:93: warning: data definition has no type or storage class
rgb2rgb.c:93: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:93: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:93: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:92: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:94: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:94: error: expected declaration specifiers or ‘...’ before ‘mask32g’
rgb2rgb.c:94: warning: data definition has no type or storage class
rgb2rgb.c:94: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:94: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:94: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:93: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:95: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:95: error: expected declaration specifiers or ‘...’ before ‘mask32r’
rgb2rgb.c:95: warning: data definition has no type or storage class
rgb2rgb.c:95: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:95: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:95: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:94: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:96: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:96: error: expected declaration specifiers or ‘...’ before ‘mask32’
rgb2rgb.c:96: warning: data definition has no type or storage class
rgb2rgb.c:96: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:96: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:96: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:95: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:97: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:97: error: expected declaration specifiers or ‘...’ before ‘mask3216br’
rgb2rgb.c:97: warning: data definition has no type or storage class
rgb2rgb.c:97: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:97: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:97: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:96: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:98: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:98: error: expected declaration specifiers or ‘...’ before ‘mask3216g’
rgb2rgb.c:98: warning: data definition has no type or storage class
rgb2rgb.c:98: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:98: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:98: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:97: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:99: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:99: error: expected declaration specifiers or ‘...’ before ‘mask3215g’
rgb2rgb.c:99: warning: data definition has no type or storage class
rgb2rgb.c:99: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:99: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:99: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:98: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:100: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:100: error: expected declaration specifiers or ‘...’ before ‘mul3216’
rgb2rgb.c:100: warning: data definition has no type or storage class
rgb2rgb.c:100: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:100: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:100: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:99: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:101: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:101: error: expected declaration specifiers or ‘...’ before ‘mul3215’
rgb2rgb.c:101: warning: data definition has no type or storage class
rgb2rgb.c:101: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:101: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:101: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:100: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:102: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:102: error: expected declaration specifiers or ‘...’ before ‘mask24b’
rgb2rgb.c:102: warning: data definition has no type or storage class
rgb2rgb.c:102: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:102: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:102: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:101: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:103: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:103: error: expected declaration specifiers or ‘...’ before ‘mask24g’
rgb2rgb.c:103: warning: data definition has no type or storage class
rgb2rgb.c:103: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:103: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:103: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:102: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:104: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:104: error: expected declaration specifiers or ‘...’ before ‘mask24r’
rgb2rgb.c:104: warning: data definition has no type or storage class
rgb2rgb.c:104: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:104: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:104: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:103: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:105: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:105: error: expected declaration specifiers or ‘...’ before ‘mask24l’
rgb2rgb.c:105: warning: data definition has no type or storage class
rgb2rgb.c:105: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:105: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:105: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:104: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:106: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:106: error: expected declaration specifiers or ‘...’ before ‘mask24h’
rgb2rgb.c:106: warning: data definition has no type or storage class
rgb2rgb.c:106: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:106: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:106: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:105: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:107: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:107: error: expected declaration specifiers or ‘...’ before ‘mask24hh’
rgb2rgb.c:107: warning: data definition has no type or storage class
rgb2rgb.c:107: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:107: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:107: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:106: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:108: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:108: error: expected declaration specifiers or ‘...’ before ‘mask24hhh’
rgb2rgb.c:108: warning: data definition has no type or storage class
rgb2rgb.c:108: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:108: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:108: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:107: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:109: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:109: error: expected declaration specifiers or ‘...’ before ‘mask24hhhh’
rgb2rgb.c:109: warning: data definition has no type or storage class
rgb2rgb.c:109: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:109: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:109: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:108: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:110: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:110: error: expected declaration specifiers or ‘...’ before ‘mask15b’
rgb2rgb.c:110: warning: data definition has no type or storage class
rgb2rgb.c:110: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:110: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:110: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:109: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:111: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:111: error: expected declaration specifiers or ‘...’ before ‘mask15rg’
rgb2rgb.c:111: warning: data definition has no type or storage class
rgb2rgb.c:111: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:111: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:111: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:110: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:112: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:112: error: expected declaration specifiers or ‘...’ before ‘mask15s’
rgb2rgb.c:112: warning: data definition has no type or storage class
rgb2rgb.c:112: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:112: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:112: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:111: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:113: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:113: error: expected declaration specifiers or ‘...’ before ‘mask15g’
rgb2rgb.c:113: warning: data definition has no type or storage class
rgb2rgb.c:113: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:113: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:113: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:112: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:114: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:114: error: expected declaration specifiers or ‘...’ before ‘mask15r’
rgb2rgb.c:114: warning: data definition has no type or storage class
rgb2rgb.c:114: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:114: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:114: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:113: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:116: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:116: error: expected declaration specifiers or ‘...’ before ‘mask16g’
rgb2rgb.c:116: warning: data definition has no type or storage class
rgb2rgb.c:116: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:116: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:116: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:114: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:117: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:117: error: expected declaration specifiers or ‘...’ before ‘mask16r’
rgb2rgb.c:117: warning: data definition has no type or storage class
rgb2rgb.c:117: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:117: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:117: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:116: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:118: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:118: error: expected declaration specifiers or ‘...’ before ‘red_16mask’
rgb2rgb.c:118: warning: data definition has no type or storage class
rgb2rgb.c:118: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:118: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:118: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:117: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:119: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:119: error: expected declaration specifiers or ‘...’ before ‘green_16mask’
rgb2rgb.c:119: warning: data definition has no type or storage class
rgb2rgb.c:119: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:119: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:119: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:118: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:120: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:120: error: expected declaration specifiers or ‘...’ before ‘blue_16mask’
rgb2rgb.c:120: warning: data definition has no type or storage class
rgb2rgb.c:120: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:120: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:120: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:119: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:121: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:121: error: expected declaration specifiers or ‘...’ before ‘red_15mask’
rgb2rgb.c:121: warning: data definition has no type or storage class
rgb2rgb.c:121: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:121: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:121: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:120: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:122: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:122: error: expected declaration specifiers or ‘...’ before ‘green_15mask’
rgb2rgb.c:122: warning: data definition has no type or storage class
rgb2rgb.c:122: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:122: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:122: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:121: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
rgb2rgb.c:123: error: expected declaration specifiers or ‘...’ before numeric constant
rgb2rgb.c:123: error: expected declaration specifiers or ‘...’ before ‘blue_15mask’
rgb2rgb.c:123: warning: data definition has no type or storage class
rgb2rgb.c:123: warning: type defaults to ‘int’ in declaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:123: error: function ‘DECLARE_ASM_CONST’ is initialized like a variable
rgb2rgb.c:123: warning: redundant redeclaration of ‘DECLARE_ASM_CONST’
rgb2rgb.c:122: warning: previous declaration of ‘DECLARE_ASM_CONST’ was here
In file included from rgb2rgb.c:170:
rgb2rgb_template.c: In function ‘rgb24to32_MMX’:
rgb2rgb_template.c:97: error: ‘mask32’ undeclared (first use in this function)
rgb2rgb_template.c:97: error: (Each undeclared identifier is reported only once
rgb2rgb_template.c:97: error: for each function it appears in.)
rgb2rgb_template.c:97: error: memory input 0 is not directly addressable
rgb2rgb_template.c: In function ‘rgb32to24_MMX’:
rgb2rgb_template.c:204: error: ‘mask24l’ undeclared (first use in this function)
rgb2rgb_template.c:205: error: ‘mask24h’ undeclared (first use in this function)
rgb2rgb_template.c:205: error: ‘mask24hh’ undeclared (first use in this function)
rgb2rgb_template.c:205: error: ‘mask24hhh’ undeclared (first use in this function)
rgb2rgb_template.c:205: error: ‘mask24hhhh’ undeclared (first use in this function)
rgb2rgb_template.c:159: error: memory input 2 is not directly addressable
rgb2rgb_template.c:159: error: memory input 3 is not directly addressable
rgb2rgb_template.c:159: error: memory input 4 is not directly addressable
rgb2rgb_template.c:159: error: memory input 5 is not directly addressable
rgb2rgb_template.c:159: error: memory input 6 is not directly addressable
rgb2rgb_template.c: In function ‘rgb15to16_MMX’:
rgb2rgb_template.c:246: error: ‘mask15s’ undeclared (first use in this function)
rgb2rgb_template.c:246: error: memory input 0 is not directly addressable
rgb2rgb_template.c: In function ‘rgb16to15_MMX’:
rgb2rgb_template.c:295: error: ‘mask15rg’ undeclared (first use in this function)
rgb2rgb_template.c:296: error: ‘mask15b’ undeclared (first use in this function)
rgb2rgb_template.c:295: error: memory input 0 is not directly addressable
rgb2rgb_template.c:296: error: memory input 0 is not directly addressable
rgb2rgb_template.c: In function ‘rgb32to16_MMX’:
rgb2rgb_template.c:386: error: ‘mask3216g’ undeclared (first use in this function)
rgb2rgb_template.c:386: error: ‘mask3216br’ undeclared (first use in this function)
rgb2rgb_template.c:386: error: ‘mul3216’ undeclared (first use in this function)
rgb2rgb_template.c:354: error: memory input 3 is not directly addressable
rgb2rgb_template.c:354: error: memory input 4 is not directly addressable
rgb2rgb_template.c:354: error: memory input 5 is not directly addressable
rgb2rgb_template.c: In function ‘rgb32tobgr16_MMX’:
rgb2rgb_template.c:454: error: ‘red_16mask’ undeclared (first use in this function)
rgb2rgb_template.c:454: error: ‘green_16mask’ undeclared (first use in this function)
rgb2rgb_template.c:487: error: ‘blue_16mask’ undeclared (first use in this function)
rgb2rgb_template.c:451: error: memory input 0 is not directly addressable
rgb2rgb_template.c:451: error: memory input 1 is not directly addressable
rgb2rgb_template.c:458: error: memory input 2 is not directly addressable
rgb2rgb_template.c: In function ‘rgb32to15_MMX’:
rgb2rgb_template.c:545: error: ‘mask3215g’ undeclared (first use in this function)
rgb2rgb_template.c:545: error: ‘mask3216br’ undeclared (first use in this function)
rgb2rgb_template.c:545: error: ‘mul3215’ undeclared (first use in this function)
rgb2rgb_template.c:513: error: memory input 3 is not directly addressable
rgb2rgb_template.c:513: error: memory input 4 is not directly addressable
rgb2rgb_template.c:513: error: memory input 5 is not directly addressable
rgb2rgb_template.c: In function ‘rgb32tobgr15_MMX’:
rgb2rgb_template.c:613: error: ‘red_15mask’ undeclared (first use in this function)
rgb2rgb_template.c:613: error: ‘green_15mask’ undeclared (first use in this function)
rgb2rgb_template.c:646: error: ‘blue_15mask’ undeclared (first use in this function)
rgb2rgb_template.c:610: error: memory input 0 is not directly addressable
rgb2rgb_template.c:610: error: memory input 1 is not directly addressable
rgb2rgb_template.c:617: error: memory input 2 is not directly addressable
rgb2rgb_template.c: In function ‘rgb24to16_MMX’:
rgb2rgb_template.c:674: error: ‘red_16mask’ undeclared (first use in this function)
rgb2rgb_template.c:674: error: ‘green_16mask’ undeclared (first use in this function)
rgb2rgb_template.c:707: error: ‘blue_16mask’ undeclared (first use in this function)
rgb2rgb_template.c:671: error: memory input 0 is not directly addressable
rgb2rgb_template.c:671: error: memory input 1 is not directly addressable
rgb2rgb_template.c:678: error: memory input 2 is not directly addressable
rgb2rgb_template.c: In function ‘rgb24tobgr16_MMX’:
rgb2rgb_template.c:737: error: ‘red_16mask’ undeclared (first use in this function)
rgb2rgb_template.c:737: error: ‘green_16mask’ undeclared (first use in this function)
rgb2rgb_template.c:770: error: ‘blue_16mask’ undeclared (first use in this function)
rgb2rgb_template.c:734: error: memory input 0 is not directly addressable
rgb2rgb_template.c:734: error: memory input 1 is not directly addressable
rgb2rgb_template.c:741: error: memory input 2 is not directly addressable
rgb2rgb_template.c: In function ‘rgb24to15_MMX’:
rgb2rgb_template.c:800: error: ‘red_15mask’ undeclared (first use in this function)
rgb2rgb_template.c:800: error: ‘green_15mask’ undeclared (first use in this function)
rgb2rgb_template.c:833: error: ‘blue_15mask’ undeclared (first use in this function)
rgb2rgb_template.c:797: error: memory input 0 is not directly addressable
rgb2rgb_template.c:797: error: memory input 1 is not directly addressable
rgb2rgb_template.c:804: error: memory input 2 is not directly addressable
rgb2rgb_template.c: In function ‘rgb24tobgr15_MMX’:
rgb2rgb_template.c:863: error: ‘red_15mask’ undeclared (first use in this function)
rgb2rgb_template.c:863: error: ‘green_15mask’ undeclared (first use in this function)
rgb2rgb_template.c:896: error: ‘blue_15mask’ undeclared (first use in this function)
rgb2rgb_template.c:860: error: memory input 0 is not directly addressable
rgb2rgb_template.c:860: error: memory input 1 is not directly addressable
rgb2rgb_template.c:867: error: memory input 2 is not directly addressable
rgb2rgb_template.c: In function ‘rgb15to24_MMX’:
rgb2rgb_template.c:1007: error: ‘mask15b’ undeclared (first use in this function)
rgb2rgb_template.c:1007: error: ‘mask15g’ undeclared (first use in this function)
rgb2rgb_template.c:1007: error: ‘mask15r’ undeclared (first use in this function)
rgb2rgb_template.c:1007: error: ‘mmx_null’ undeclared (first use in this function)
rgb2rgb_template.c:1057: error: ‘mask24l’ undeclared (first use in this function)
rgb2rgb_template.c:1057: error: ‘mask24h’ undeclared (first use in this function)
rgb2rgb_template.c:1057: error: ‘mask24hh’ undeclared (first use in this function)
rgb2rgb_template.c:1057: error: ‘mask24hhh’ undeclared (first use in this function)
rgb2rgb_template.c:1057: error: ‘mask24hhhh’ undeclared (first use in this function)
rgb2rgb_template.c:947: error: memory input 2 is not directly addressable
rgb2rgb_template.c:947: error: memory input 3 is not directly addressable
rgb2rgb_template.c:947: error: memory input 4 is not directly addressable
rgb2rgb_template.c:947: error: memory input 5 is not directly addressable
rgb2rgb_template.c:1010: error: memory input 2 is not directly addressable
rgb2rgb_template.c:1010: error: memory input 3 is not directly addressable
rgb2rgb_template.c:1010: error: memory input 4 is not directly addressable
rgb2rgb_template.c:1010: error: memory input 5 is not directly addressable
rgb2rgb_template.c:1010: error: memory input 6 is not directly addressable
rgb2rgb_template.c: In function ‘rgb16to24_MMX’:
rgb2rgb_template.c:1148: error: ‘mask15b’ undeclared (first use in this function)
rgb2rgb_template.c:1148: error: ‘mask16g’ undeclared (first use in this function)
rgb2rgb_template.c:1148: error: ‘mask16r’ undeclared (first use in this function)
rgb2rgb_template.c:1148: error: ‘mmx_null’ undeclared (first use in this function)
rgb2rgb_template.c:1198: error: ‘mask24l’ undeclared (first use in this function)
rgb2rgb_template.c:1198: error: ‘mask24h’ undeclared (first use in this function)
rgb2rgb_template.c:1198: error: ‘mask24hh’ undeclared (first use in this function)
rgb2rgb_template.c:1198: error: ‘mask24hhh’ undeclared (first use in this function)
rgb2rgb_template.c:1198: error: ‘mask24hhhh’ undeclared (first use in this function)
rgb2rgb_template.c:1089: error: memory input 2 is not directly addressable
rgb2rgb_template.c:1089: error: memory input 3 is not directly addressable
rgb2rgb_template.c:1089: error: memory input 4 is not directly addressable
rgb2rgb_template.c:1089: error: memory input 5 is not directly addressable
rgb2rgb_template.c:1151: error: memory input 2 is not directly addressable
rgb2rgb_template.c:1151: error: memory input 3 is not directly addressable
rgb2rgb_template.c:1151: error: memory input 4 is not directly addressable
rgb2rgb_template.c:1151: error: memory input 5 is not directly addressable
rgb2rgb_template.c:1151: error: memory input 6 is not directly addressable
rgb2rgb_template.c: In function ‘rgb15to32_MMX’:
rgb2rgb_template.c:1262: error: ‘mask15b’ undeclared (first use in this function)
rgb2rgb_template.c:1262: error: ‘mask15g’ undeclared (first use in this function)
rgb2rgb_template.c:1262: error: ‘mask15r’ undeclared (first use in this function)
rgb2rgb_template.c:1231: error: memory input 2 is not directly addressable
rgb2rgb_template.c:1231: error: memory input 3 is not directly addressable
rgb2rgb_template.c:1231: error: memory input 4 is not directly addressable
rgb2rgb_template.c: In function ‘rgb16to32_MMX’:
rgb2rgb_template.c:1340: error: ‘mask15b’ undeclared (first use in this function)
rgb2rgb_template.c:1340: error: ‘mask16g’ undeclared (first use in this function)
rgb2rgb_template.c:1340: error: ‘mask16r’ undeclared (first use in this function)
rgb2rgb_template.c:1309: error: memory input 2 is not directly addressable
rgb2rgb_template.c:1309: error: memory input 3 is not directly addressable
rgb2rgb_template.c:1309: error: memory input 4 is not directly addressable
rgb2rgb_template.c: In function ‘rgb32tobgr32_MMX’:
rgb2rgb_template.c:1419: error: ‘mask32b’ undeclared (first use in this function)
rgb2rgb_template.c:1419: error: ‘mask32r’ undeclared (first use in this function)
rgb2rgb_template.c:1419: error: ‘mmx_one’ undeclared (first use in this function)
rgb2rgb_template.c:1371: error: memory input 3 is not directly addressable
rgb2rgb_template.c:1371: error: memory input 4 is not directly addressable
rgb2rgb_template.c:1371: error: memory input 5 is not directly addressable
In file included from rgb2rgb.c:179:
rgb2rgb_template.c: In function ‘rgb24to32_MMX2’:
rgb2rgb_template.c: In function ‘rgb32to24_MMX2’:
rgb2rgb_template.c: In function ‘rgb15to16_MMX2’:
rgb2rgb_template.c: In function ‘rgb16to15_MMX2’:
rgb2rgb_template.c: In function ‘rgb32to16_MMX2’:
rgb2rgb_template.c: In function ‘rgb32tobgr16_MMX2’:
rgb2rgb_template.c: In function ‘rgb32to15_MMX2’:
rgb2rgb_template.c: In function ‘rgb32tobgr15_MMX2’:
rgb2rgb_template.c: In function ‘rgb24to16_MMX2’:
rgb2rgb_template.c: In function ‘rgb24tobgr16_MMX2’:
rgb2rgb_template.c: In function ‘rgb24to15_MMX2’:
rgb2rgb_template.c: In function ‘rgb24tobgr15_MMX2’:
rgb2rgb_template.c: In function ‘rgb15to24_MMX2’:
rgb2rgb_template.c: In function ‘rgb16to24_MMX2’:
rgb2rgb_template.c: In function ‘rgb15to32_MMX2’:
rgb2rgb_template.c: In function ‘rgb16to32_MMX2’:
rgb2rgb_template.c: In function ‘rgb32tobgr32_MMX2’:
In file included from rgb2rgb.c:188:
rgb2rgb_template.c: In function ‘rgb24to32_3DNOW’:
rgb2rgb_template.c: In function ‘rgb32to24_3DNOW’:
rgb2rgb_template.c: In function ‘rgb15to16_3DNOW’:
rgb2rgb_template.c: In function ‘rgb16to15_3DNOW’:
rgb2rgb_template.c: In function ‘rgb32to16_3DNOW’:
rgb2rgb_template.c: In function ‘rgb32tobgr16_3DNOW’:
rgb2rgb_template.c: In function ‘rgb32to15_3DNOW’:
rgb2rgb_template.c: In function ‘rgb32tobgr15_3DNOW’:
rgb2rgb_template.c: In function ‘rgb24to16_3DNOW’:
rgb2rgb_template.c: In function ‘rgb24tobgr16_3DNOW’:
rgb2rgb_template.c: In function ‘rgb24to15_3DNOW’:
rgb2rgb_template.c: In function ‘rgb24tobgr15_3DNOW’:
rgb2rgb_template.c: In function ‘rgb15to24_3DNOW’:
rgb2rgb_template.c: In function ‘rgb16to24_3DNOW’:
rgb2rgb_template.c: In function ‘rgb15to32_3DNOW’:
rgb2rgb_template.c: In function ‘rgb16to32_3DNOW’:
rgb2rgb_template.c: In function ‘rgb32tobgr32_3DNOW’:
make[1]: *** [rgb2rgb.o] Error 1
make[1]: Leaving directory `/home/george/ffmpeg/libswscale'
make: *** [lib] Error 2
in addition, running 'make install' resulting this error:
make                    -C libavutil   install-libs
install -d "/opt//lib"
install -m 755  "/opt//lib/.49.6.0"
install: missing destination file operand after `/opt//lib/.49.6.0'
Try `install --help' for more information.
make[1]: *** [install-lib-shared] Error 1
make: *** [install-libs] Error 2
Thank you and looking forward your response.
George[/code]
bangbecak
Post by bangbecak »
I reinstalled Ubuntu Server 7.10, followed setup (caladeira) and zoneminder 1.23.2-1 (PeterHoward), and PHP Serialization, also new ffmpeg from SVN. Now my zoneminder is up and running, and I could run my camera over network.
Thank you guys.
caladeira
Post by caladeira »
Good to ear about your success!
Best regards.
sloan949
Very Helful Post some suggestions
Post by sloan949 »
Thanks for taking the time to write this post. It helped in getting ZM 1.23.3 running on ubuntu 7.04.
I had had to use different compile options for FFMPEG. Your options are below.
Install FFMPEG from SVN
Code:
svn checkout svn://svn.mplayerhq.hu/ffmpeg/trunk ffmpeg
cd ffmpeg
make
sudo make install
I had to use these
Code:
cd ffmpeg
. ./configure --enable-shared --enable-postproc --enable-swscale --enable-gpl --prefix=/opt/
make
sudo make install
./configure --help will help any newbies to fix this type of problem
caladeira
Post by caladeira »
Good to ear.
I haven't investigated that deep, but for what I can understand it was a change in most recent versions of ffmpeg from svn.
I'll update initial instructions.
Good job!
carteriii
Post by carteriii »
I have few questions about the install paths for 1.23.2 for Ubuntu 7.10 given that I previously installed 1.22.3 from the debian package.
For starters, this is the configure command I have so far:
./configure --with-webdir=/usr/share/zoneminder --with-cgidir=/usr/lib/cgi-bin --with-webuser=www-data --with-webgroup=www-data --with-mysql=/usr --prefix=/usr
I thought I was in good shape until scanning through the makefile I saw that ZM_CONFIG = /usr/etc/zm.conf. However, my current zm.conf file is located at /etc/zm/zm.conf and I don't even have a /usr/etc directory. I see an entry for SYSCONFDIR = /usr/etc, but the ZM_CONFIG entry doesn't reference that, so at a minimum it appears I have to change both entries rather than just one prefix.
I don't want to run 'make install' as long as I see obviously differences like this, since I assume the differences will come back to haunt me. Has anyone else installed 1.23.2 from source having previously used the package installation on Ubuntu 7.10? What is my best course of action at this point?
Peter, have you been trying to keep the same paths as the previous debian package and might you have a detailed list which you can share? Thanks.
PeterHoward
Here's the config line that the 1.23.2 package uses:
 ./configure --host=$(DEB_HOST_
GNU_TYPE) --build=$(DEB_BUILD_GNU_TYPE) --sysconfdir=/etc/zm --prefix=/usr --man
dir=\$${prefix}/share/man --infodir=\$${prefix}/share/info --with-mysql=/usr  --with-webdir=/usr/share/zoneminder --with-ffmpeg=/usr --with-cgidir=/usr/lib/cgi-bin --with-webuser=www-data --with-webgroup=www-data --enable-crashtrace=no
Note that for the stock ffmpeg to work you need to apply the following patch:
#! /bin/sh /usr/share/dpatch/dpatch-run
## 06_no_ffmpeg_from_svn.dpatch by  <kushnir@kushnir>
## All lines beginning with `## DP:' are a description of the patch.
## DP: No description.
@DPATCH@
diff -urNad ZoneMinder-1.23.2~/src/zm_mpeg.cpp ZoneMinder-1.23.2/src/zm_mpeg.cpp
--- ZoneMinder-1.23.2~/src/zm_mpeg.cpp  2007-12-18 00:17:23.000000000 +1100
+++ ZoneMinder-1.23.2/src/zm_mpeg.cpp   2008-02-28 21:39:58.000000000 +1100
@@ -277,7 +277,7 @@
        if (!(of->flags & AVFMT_NOFILE))
                /* close the output file */
-#if ZM_FFMPEG_SVN
+#if !ZM_FFMPEG_SVN
                url_fclose(ofc->pb);
 #else
                url_fclose(&ofc->pb);
Out of interest, why are you switching from package to manual install?
PJH
carteriii
Post by carteriii »
Mostly just so I could stay more current with updates, rather than having to wait for a package to be built or updated. Secondarily, I was fearful that a package install might accidentally wipe my database rather than upgrading it. I saw the database upgrade scripts so I knew I could control that. Do you expect the package to be easier to maintain now, such that it's likely to be more current, and does the package properly detect an upgrade vs. new install scenario?
I actually feel guilty even asking those questions, so please understand I do appreciate everything you've done and was just trying to be a bit more self-sufficient. Given that I did manually install the PHP::Serialization already, do you believe my best course of action is to just use your package at this point?
PeterHoward
One of the two main reasons that the 1.23 package was a long time coming was that I was making sure the upgrade process worked. It invokes the database upgrade scripts and my testing (admittedly basic) has the upgrade working fine.
(Of course the other one was getting PHP::Serialization into Debian - and thus into Ubuntu)
As to it being easy to maintain, it depends what new dependencies get sprung on me next time :-). However we now have a channel to warn the packagers of what is coming.
The more people that use the package the more likely problems are found and (hopefully) fixed. I have no problem with people wanting to roll their own. It's more that, if they do, I'd like to know if it's a problem with the package or now. So I'd suggest trying the upgrade (and it does prompt you to do a backup), but by all means build it yourself if you want to.
PJH
carteriii
Post by carteriii »
Well, I may be my own worst enemy here. I tried running the 1.23.2 package and it failed with:
ERROR 1091 (42000) at line 47: Can't DROP 'UC_Name'; check that column/key exists
I assume this is from trying to delete the index UC_Name (not a column), which ironically enough I already dropped since I was the one who initially reported/suggested that change. Ooops!
It looks like many of the binary files were already copied over, despite the failure of the package to install. Does that sound correct, that they would have been moved before the database updates, and that they wouldn't be rolled back? If so, then perhaps all I need to do is manually update the database myself?
PeterHoward
I think you're half-correct - the database upgrade happens in the "post-install" phase which (IIRC) is past the point at which a full rollback can occur. However as far as the system is concerned, the package hasn't been properly installed. So you need to do a manual "hack" to get the installation to complete, as well as doing the manual upgrade.
I can't remember the full detail, so we'll have to work through it. Do you have anything with "zoneminder" in the name in /usr/share/debhelper/autoscripts"?
