Installation Problem
oscarliu
Post by oscarliu » Sun Dec 02, 2007 7:17 am
I'm using Fedora 7. While installing ZOneMinder 1.22.3 from source, the following errors are shown. Can anyone help?
[root@mamaday ZoneMinder-1.22.3]# make
make all-recursive
make[1]: Entering directory `/root/ZoneMinder-1.22.3'
Making all in src
make[2]: Entering directory `/root/ZoneMinder-1.22.3/src'
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -I/usr/local/bin/include -g -O3 -march=pentium4 -MT zm_mpeg.o -MD -MP -MF ".deps/zm_mpeg.Tpo" -c -o zm_mpeg.o zm_mpeg.cpp; \
then mv -f ".deps/zm_mpeg.Tpo" ".deps/zm_mpeg.Po"; else rm -f ".deps/zm_mpeg.Tpo"; exit 1; fi
zm_mpeg.cpp: In destructor ‘VideoStream::~VideoStream()’:
zm_mpeg.cpp:280: error: cannot convert ‘ByteIOContext**’ to ‘ByteIOContext*’ for argument ‘1’ to ‘int url_fclose(ByteIOContext*)’
zm_mpeg.cpp: In member function ‘double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)’:
zm_mpeg.cpp:308: warning: ‘img_convert’ is deprecated (declared at /usr/local/include/ffmpeg/avcodec.h:2421)
zm_mpeg.cpp:310: warning: ‘img_convert’ is deprecated (declared at /usr/local/include/ffmpeg/avcodec.h:2421)
make[2]: *** [zm_mpeg.o] Error 1
make[2]: Leaving directory `/root/ZoneMinder-1.22.3/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/ZoneMinder-1.22.3'
make: *** [all] Error 2
ThomasH
Post by ThomasH » Mon Dec 03, 2007 2:40 am
I am having the same problem on CentOS 5 with the latest version of ffmpeg from the SVN.
kevin_robson
Post by kevin_robson » Mon Dec 03, 2007 3:21 pm
Same problem on fedora 8. Tried the fixes on various posts but gives the same problem. Has anyone got past this?
ioane
Post by ioane » Mon Dec 03, 2007 4:00 pm
I had the same problem.
I solved it by installing an older version of ffmpeg. I found it on sourceforge, at the motion project.
Good luck.
oscarliu
Post by oscarliu » Tue Dec 04, 2007 1:46 am
Hi ioane,
Thanks. I've just downloaded the old version of ffmpeg from project motion. While compiling, the following errors are shown. Any idea?
Thanks in advance.
./libavcodec/libavcodec.so: undefined reference to `ff_ac3_frame_sizes'
./libavcodec/libavcodec.so: undefined reference to `flashsv_encoder'
./libavcodec/libavcodec.so: undefined reference to `sgi_encoder'
./libavcodec/libavcodec.so: undefined reference to `dsicinvideo_decoder'
./libavcodec/libavcodec.so: undefined reference to `h261_decoder'
./libavcodec/libavcodec.so: undefined reference to `rawvideo_decoder'
./libavformat/libavformat.so: undefined reference to `end_tag'
./libavcodec/libavcodec.so: undefined reference to `dnxhd_encoder'
./libavcodec/libavcodec.so: undefined reference to `xsub_decoder'
./libavformat/libavformat.so: undefined reference to `get_frame_filename'
./libavcodec/libavcodec.so: undefined reference to `wavpack_decoder'
./libavcodec/libavcodec.so: undefined reference to `ptx_decoder'
./libavcodec/libavcodec.so: undefined reference to `av_init_random'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg1_default_non_intra_matrix'
./libavcodec/libavcodec.so: undefined reference to `v2_mb_type'
./libavcodec/libavcodec.so: undefined reference to `h261_parser'
./libavcodec/libavcodec.so: undefined reference to `vp6_decoder'
./libavformat/libavformat.so: undefined reference to `apc_demuxer'
./libavformat/libavformat.so: undefined reference to `ff_mp4_obj_type'
./libavcodec/libavcodec.so: undefined reference to `wmv1_y_dc_scale_table'
./libavcodec/libavcodec.so: undefined reference to `init_vlc'
./libavcodec/libavcodec.so: undefined reference to `ff_sgaintab'
./libavcodec/libavcodec.so: undefined reference to `ff_fgaintab'
./libavcodec/libavcodec.so: undefined reference to `wmv1_encoder'
./libavcodec/libavcodec.so: undefined reference to `ff_mpa_sblimit_table'
./libavcodec/libavcodec.so: undefined reference to `ff_sdecaytab'
./libavcodec/libavcodec.so: undefined reference to `smackaud_decoder'
./libavcodec/libavcodec.so: undefined reference to `ff_ac3_bit_alloc_calc_bap'
./libavformat/libavformat.so: undefined reference to `mpeg2vob_muxer'
./libavcodec/libavcodec.so: undefined reference to `adpcm_adx_encoder'
./libavformat/libavformat.so: undefined reference to `dxa_demuxer'
./libavcodec/libavcodec.so: undefined reference to `ff_fft_calc_3dn2'
./libavcodec/libavcodec.so: undefined reference to `ff_ac3_bitratetab'
./libavcodec/libavcodec.so: undefined reference to `vp6f_decoder'
./libavformat/libavformat.so: undefined reference to `nuv_demuxer'
./libavcodec/libavcodec.so: undefined reference to `ff_floortab'
./libavformat/libavformat.so: undefined reference to `crc_muxer'
./libavcodec/libavcodec.so: undefined reference to `pgm_encoder'
./libavcodec/libavcodec.so: undefined reference to `mjpega_dump_header_bsf'
./libavcodec/libavcodec.so: undefined reference to `ff_wma_hgain_huffbits'
./libavcodec/libavcodec.so: undefined reference to `dump_extradata_bsf'
./libavcodec/libavcodec.so: undefined reference to `ac3_common_init'
./libavcodec/libavcodec.so: undefined reference to `mp3_header_compress_bsf'
./libavcodec/libavcodec.so: undefined reference to `nuv_decoder'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg12_vlc_dc_lum_code'
./libavcodec/libavcodec.so: undefined reference to `mm_flags'
./libavcodec/libavcodec.so: undefined reference to `wmv1_scantable'
./libavcodec/libavcodec.so: undefined reference to `mpegaudio_parser'
./libavcodec/libavcodec.so: undefined reference to `ljpeg_encoder'
./libavformat/libavformat.so: undefined reference to `matroska_audio_muxer'
./libavcodec/libavcodec.so: undefined reference to `ff_wma_hgain_huffcodes'
./libavcodec/libavcodec.so: undefined reference to `flashsv_decoder'
./libavformat/libavformat.so: undefined reference to `ogg_muxer'
./libavcodec/libavcodec.so: undefined reference to `ff_wma_init'
./libavcodec/libavcodec.so: undefined reference to `wmav2_encoder'
./libavcodec/libavcodec.so: undefined reference to `cavs_decoder'
./libavformat/libavformat.so: undefined reference to `start_tag'
./libavcodec/libavcodec.so: undefined reference to `mpeg4_encoder'
./libavcodec/libavcodec.so: undefined reference to `gif_encoder'
./libavcodec/libavcodec.so: undefined reference to `vp5_decoder'
./libavcodec/libavcodec.so: undefined reference to `roq_decoder'
./libavcodec/libavcodec.so: undefined reference to `pam_encoder'
./libavformat/libavformat.so: undefined reference to `matroska_muxer'
./libavcodec/libavcodec.so: undefined reference to `qtrle_encoder'
./libavcodec/libavcodec.so: undefined reference to `h264_mp4toannexb_bsf'
./libavcodec/libavcodec.so: undefined reference to `flac_encoder'
./libavcodec/libavcodec.so: undefined reference to `targa_encoder'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg2_aspect'
./libavcodec/libavcodec.so: undefined reference to `jpegls_encoder'
./libavcodec/libavcodec.so: undefined reference to `av_crc8005'
./libavcodec/libavcodec.so: undefined reference to `ac3_parser'
./libavcodec/libavcodec.so: undefined reference to `ff_msmp4_dc_chroma_vlc'
./libavcodec/libavcodec.so: undefined reference to `ff_vc1dsp_init'
./libavcodec/libavcodec.so: undefined reference to `ff_ac3_bit_alloc_calc_mask'
./libavcodec/libavcodec.so: undefined reference to `ff_fdecaytab'
./libavformat/libavformat.so: undefined reference to `codec_movaudio_tags'
./libavcodec/libavcodec.so: undefined reference to `ff_wma_total_gain_to_bits'
./libavformat/libavformat.so: undefined reference to `ogg_demuxer'
./libavformat/libavformat.so: undefined reference to `ff_mov_lang_to_iso639'
./libavformat/libavformat.so: undefined reference to `guess_image_format'
./libavformat/libavformat.so: undefined reference to `matroska_demuxer'
./libavcodec/libavcodec.so: undefined reference to `mlp_parser'
./libavcodec/libavcodec.so: undefined reference to `ppm_encoder'
./libavcodec/libavcodec.so: undefined reference to `c93_decoder'
./libavcodec/libavcodec.so: undefined reference to `ff_imdct_calc_3dn2'
./libavcodec/libavcodec.so: undefined reference to `pgmyuv_encoder'
./libavcodec/libavcodec.so: undefined reference to `dca_decoder'
./libavcodec/libavcodec.so: undefined reference to `rawvideo_encoder'
./libavcodec/libavcodec.so: undefined reference to `ff_write_quant_matrix'
./libavcodec/libavcodec.so: undefined reference to `ff_wmv2_decode_mb'
./libavcodec/libavcodec.so: undefined reference to `h261_encoder'
./libavcodec/libavcodec.so: undefined reference to `ff_imdct_calc_sse'
./libavcodec/libavcodec.so: undefined reference to `ff_ac3_freqs'
./libavcodec/libavcodec.so: undefined reference to `dsputil_init_mmx'
./libavcodec/libavcodec.so: undefined reference to `mm_support'
./libavcodec/libavcodec.so: undefined reference to `mpc8_decoder'
./libavformat/libavformat.so: undefined reference to `av_crc'
./libavformat/libavformat.so: undefined reference to `mpc8_demuxer'
./libavcodec/libavcodec.so: undefined reference to `av_log_level'
./libavcodec/libavcodec.so: undefined reference to `ff_dbkneetab'
./libavcodec/libavcodec.so: undefined reference to `ff_intrax8dsp_init'
./libavcodec/libavcodec.so: undefined reference to `ff_huff_build_tree'
./libavformat/libavformat.so: undefined reference to `tiertexseq_demuxer'
./libavformat/libavformat.so: undefined reference to `mpeg1vcd_muxer'
./libavcodec/libavcodec.so: undefined reference to `atrac3_decoder'
./libavformat/libavformat.so: undefined reference to `ea_cdata_demuxer'
./libavcodec/libavcodec.so: undefined reference to `ff_flac_compute_autocorr'
./libavcodec/libavcodec.so: undefined reference to `ff_wma_scale_huffcodes'
./libavcodec/libavcodec.so: undefined reference to `h263_parser'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg12_mbPatTable'
./libavcodec/libavcodec.so: undefined reference to `av_crc07'
./libavformat/libavformat.so: undefined reference to `mjpeg_encoder'
./libavformat/libavformat.so: undefined reference to `av_write_image'
./libavcodec/libavcodec.so: undefined reference to `v2_intra_cbpc'
./libavformat/libavformat.so: undefined reference to `thp_demuxer'
./libavcodec/libavcodec.so: undefined reference to `mjpeg_parser'
./libavcodec/libavcodec.so: undefined reference to `ff_ac3_window'
./libavcodec/libavcodec.so: undefined reference to `ff_msmp4_mb_i_table'
./libavcodec/libavcodec.so: undefined reference to `txd_decoder'
./libavformat/libavformat.so: undefined reference to `nut_muxer'
./libavcodec/libavcodec.so: undefined reference to `mp2_encoder'
./libavformat/libavformat.so: undefined reference to `av_stristart'
./libavformat/libavformat.so: undefined reference to `txd_demuxer'
./libavcodec/libavcodec.so: undefined reference to `mpc7_decoder'
./libavcodec/libavcodec.so: undefined reference to `wmav1_encoder'
./libavformat/libavformat.so: undefined reference to `siff_demuxer'
./libavcodec/libavcodec.so: undefined reference to `smacker_decoder'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg12_vlc_dc_lum_bits'
./libavcodec/libavcodec.so: undefined reference to `vmnc_decoder'
./libavcodec/libavcodec.so: undefined reference to `ff_h264_find_frame_end'
./libavcodec/libavcodec.so: undefined reference to `h264_parser'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg12_vlc_dc_chroma_code'
./libavformat/libavformat.so: undefined reference to `cropTbl'
./libavcodec/libavcodec.so: undefined reference to `noise_bsf'
./libavcodec/libavcodec.so: undefined reference to `ff_mpa_enwindow'
./libavformat/libavformat.so: undefined reference to `ff_rtp_send_mpegvideo'
./libavcodec/libavcodec.so: undefined reference to `vb_decoder'
./libavcodec/libavcodec.so: undefined reference to `ff_cavsdsp_init'
./libavcodec/libavcodec.so: undefined reference to `vorbis_inverse_coupling'
./libavcodec/libavcodec.so: undefined reference to `msmpeg4v1_encoder'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg4_find_frame_end'
./libavformat/libavformat.so: undefined reference to `gxf_demuxer'
./libavformat/libavformat.so: undefined reference to `amr_muxer'
./libavcodec/libavcodec.so: undefined reference to `svq1_decoder'
./libavformat/libavformat.so: undefined reference to `voc_get_packet'
./libavcodec/libavcodec.so: undefined reference to `roq_dpcm_encoder'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg1_default_intra_matrix'
./libavformat/libavformat.so: undefined reference to `av_read_image'
./libavcodec/libavcodec.so: undefined reference to `ff_fft_calc_3dn'
./libavformat/libavformat.so: undefined reference to `rm_demuxer'
./libavcodec/libavcodec.so: undefined reference to `png_encoder'
./libavcodec/libavcodec.so: undefined reference to `msmpeg4v3_encoder'
./libavformat/libavformat.so: undefined reference to `gxf_muxer'
./libavcodec/libavcodec.so: undefined reference to `thp_decoder'
./libavcodec/libavcodec.so: undefined reference to `MPV_common_init_mmx'
./libavcodec/libavcodec.so: undefined reference to `vc1_parser'
./libavformat/libavformat.so: undefined reference to `put_wav_header'
./libavcodec/libavcodec.so: undefined reference to `ff_rl_mpeg1'
./libavcodec/libavcodec.so: undefined reference to `ff_wmv2_decode_secondary_picture_header'
./libavcodec/libavcodec.so: undefined reference to `flv_encoder'
./libavcodec/libavcodec.so: undefined reference to `ff_h264_pred_init'
./libavcodec/libavcodec.so: undefined reference to `ff_table1_dc_lum'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg1_aspect'
./libavformat/libavformat.so: undefined reference to `ff_rtp_send_aac'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg12_mbAddrIncrTable'
./libavformat/libavformat.so: undefined reference to `ff_ac3_parse_header'
./libavcodec/libavcodec.so: undefined reference to `dca_parser'
./libavformat/libavformat.so: undefined reference to `c93_demuxer'
./libavformat/libavformat.so: undefined reference to `av_strlcat'
./libavcodec/libavcodec.so: undefined reference to `kmvc_decoder'
./libavcodec/libavcodec.so: undefined reference to `ff_wma_scale_huffbits'
./libavformat/libavformat.so: undefined reference to `av_tree_insert'
./libavcodec/libavcodec.so: undefined reference to `wmv1_c_dc_scale_table'
./libavcodec/libavcodec.so: undefined reference to `aac_parser'
./libavcodec/libavcodec.so: undefined reference to `svq1_encoder'
./libavcodec/libavcodec.so: undefined reference to `amv_decoder'
./libavcodec/libavcodec.so: undefined reference to `rv20_encoder'
./libavcodec/libavcodec.so: undefined reference to `h263_encoder'
./libavcodec/libavcodec.so: undefined reference to `wmv2_decoder'
./libavcodec/libavcodec.so: undefined reference to `old_ff_y_dc_scale_table'
./libavcodec/libavcodec.so: undefined reference to `png_decoder'
./libavcodec/libavcodec.so: undefined reference to `mpeg2video_encoder'
./libavformat/libavformat.so: undefined reference to `ape_demuxer'
./libavcodec/libavcodec.so: undefined reference to `ape_decoder'
./libavcodec/libavcodec.so: undefined reference to `ff_wma_lsp_codebook'
./libavcodec/libavcodec.so: undefined reference to `ff_table0_dc_lum'
./libavcodec/libavcodec.so: undefined reference to `vp6a_decoder'
./libavcodec/libavcodec.so: undefined reference to `ff_wma_end'
./libavformat/libavformat.so: undefined reference to `mtv_demuxer'
./libavcodec/libavcodec.so: undefined reference to `ff_wmv2_decode_picture_header'
./libavcodec/libavcodec.so: undefined reference to `nellymoser_decoder'
./libavcodec/libavcodec.so: undefined reference to `imx_dump_header_bsf'
./libavcodec/libavcodec.so: undefined reference to `ff_mpeg12_vlc_dc_chroma_bits'
./libavcodec/libavcodec.so: undefined reference to `tiertexseqvideo_decoder'
./libavcodec/libavcodec.so: undefined reference to `vorbis_encoder'
./libavcodec/libavcodec.so: undefined reference to `pnm_parser'
./libavcodec/libavcodec.so: undefined reference to `sp5x_decoder'
./libavcodec/libavcodec.so: undefined reference to `ff_wmv2_add_mb'
./libavcodec/libavcodec.so: undefined reference to `msmpeg4v2_encoder'
./libavformat/libavformat.so: undefined reference to `codec_wav_tags'
./libavformat/libavformat.so: undefined reference to `av_base64_encode'
./libavcodec/libavcodec.so: undefined reference to `ff_h263_find_frame_end'
./libavcodec/libavcodec.so: undefined reference to `table_inter_intra'
./libavcodec/libavcodec.so: undefined reference to `sgi_decoder'
./libavformat/libavformat.so: undefined reference to `ff_asfcrypt_dec'
./libavcodec/libavcodec.so: undefined reference to `rl_table'
./libavcodec/libavcodec.so: undefined reference to `bmp_encoder'
./libavcodec/libavcodec.so: undefined reference to `ff_frame_rate_tab'
./libavcodec/libavcodec.so: undefined reference to `tiff_encoder'
./libavcodec/libavcodec.so: undefined reference to `ff_mspel_motion'
./libavformat/libavformat.so: undefined reference to `nut_demuxer'
./libavcodec/libavcodec.so: undefined reference to `jpegls_decoder'
./libavcodec/libavcodec.so: undefined reference to `dnxhd_decoder'
./libavformat/libavformat.so: undefined reference to `wv_demuxer'
./libavformat/libavformat.so: undefined reference to `ff_h264_dynamic_handler'
collect2: ld returned 1 exit status
make: *** [ffmpeg_g] Error 1
[root@mamaday ffmpeg]#
neouser
Post by neouser » Tue Dec 04, 2007 12:18 pm
Yesterday nigth i had same problem compiling zoneminder. It seems that newest version of ffmpeg has changed some things.
I changed in zm_mpeg.cpp line 280:
-url_fclose(&ofc->pb);
+url_fclose(ofc->pb);
After this i compiled suscesfully and it seems like all is working well. If this solution is wrong i would like to know.
Regards
ioane
Post by ioane » Wed Dec 05, 2007 8:30 pm
Sorry, i don't know why you get those errors.
I installed the same ffmpeg version on Slackware 12.0 and it didn't get any errors.
Try neouser's advice and let us know if it works
oscarliu
Post by oscarliu » Thu Dec 06, 2007 1:01 am
have tried neouser's way but got exactly the same errors while compiling ZoneMinder. Quite frustrated. Thanks for your advice anyway. Hope there will be a way out.
neouser
Post by neouser » Fri Dec 07, 2007 11:14 am
Hello Oscarliu,
Same errors ? What errors are you getting ?
If you are talking about line 280 error, please review your steps, it is impossible that after line change you get same error.
If you are taliking about "undefined reference" errors, ensure you are linking with correct ffmpeg library, look at include path and library path, uninstall ffmpeg rpms or older versions, re-install ffmpeg and add ffmpeg path ( "--with-ffmpeg=" option) to configure. Always is recommended to execute "make clean" before compile again.
Hope this help
oscarliu
Post by oscarliu » Tue Dec 11, 2007 1:22 am
Hi neouser,
Thanks for your reply. Finally, I compiled an old version of ffmpeg found in the Motion project in sourceforge.net as suggested in another thread and solved the problem.
Thanks again.
Oscar
ammaross
Post by ammaross » Tue Dec 11, 2007 8:43 pm
neouser wrote: I changed in zm_mpeg.cpp line 280:
The more-recent SVNs of ffmpeg appear to have changed url_fclose() as well as depreciated img_convert(). Neouser's mod works for me.
BadFish
Post by BadFish » Sun Jun 01, 2008 4:29 pm
I'm having the same error,
I tried editting zm_mpeg.cpp line 280
but now I get the following error
[root@Zoneminder ZoneMinder-1.22.3]# make
make all-recursive
Making all in src
g++ -g -O3 -march=pentium4 -L/usr/local//lib -L/usr/lib/mysql -o zmc zmc.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_poly.o zm_image.o zm_event.o zm_zone.o zm_camera.o zm_local_camera.o zm_remote_camera.o zm_file_camera.o zm_monitor.o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_signal.o zm_buffer.o zm_debug.o -lavformat -lavcodec -lavutil -lpcre -lcrypto -lmysqlclient -ldl -lz -ljpeg
zm_mpeg.o: In function `VideoStream::EncodeFrame(unsigned char*, int, bool, unsigned int)':
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:310: undefined reference to `img_convert(AVPicture*, int, AVPicture const*, int, int, int)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:339: undefined reference to `avcodec_encode_video(AVCodecContext*, unsigned char*, int, AVFrame const*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:346: undefined reference to `av_init_packet(AVPacket*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:351: undefined reference to `av_rescale_q(long long, AVRational, AVRational)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:359: undefined reference to `av_write_frame(AVFormatContext*, AVPacket*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:325: undefined reference to `av_init_packet(AVPacket*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:332: undefined reference to `av_write_frame(AVFormatContext*, AVPacket*)'
zm_mpeg.o: In function `~VideoStream':
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:254: undefined reference to `avcodec_close(AVCodecContext*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:258: undefined reference to `av_free(void*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:259: undefined reference to `av_free(void*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:262: undefined reference to `av_free(void*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:263: undefined reference to `av_free(void*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:265: undefined reference to `av_free(void*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:269: undefined reference to `av_write_trailer(AVFormatContext*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:274: undefined reference to `av_freep(void*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:280: undefined reference to `url_fclose(ByteIOContext*)'
zm_mpeg.o: In function `VideoStream::OpenStream()':
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:165: undefined reference to `avcodec_find_encoder(CodecID)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:172: undefined reference to `avcodec_open(AVCodecContext*, AVCodec*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:178: undefined reference to `avcodec_alloc_frame()'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:183: undefined reference to `avpicture_get_size(int, int, int)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:190: undefined reference to `avpicture_fill(AVPicture*, unsigned char*, int, int, int)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:198: undefined reference to `avcodec_alloc_frame()'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:203: undefined reference to `avpicture_get_size(int, int, int)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:210: undefined reference to `avpicture_fill(AVPicture*, unsigned char*, int, int, int)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:217: undefined reference to `url_fopen(ByteIOContext**, char const*, int)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:187: undefined reference to `av_free(void*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:207: undefined reference to `av_free(void*)'
zm_mpeg.o: In function `VideoStream::SetParameters()':
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:126: undefined reference to `av_set_parameters(AVFormatContext*, AVFormatParameters*)'
zm_mpeg.o: In function `VideoStream::SetupCodec(int, int, int, int, int)':
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:79: undefined reference to `av_new_stream(AVFormatContext*, int)'
zm_mpeg.o: In function `VideoStream::SetupFormat(char const*, char const*)':
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:49: undefined reference to `guess_format(char const*, char const*, char const*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:61: undefined reference to `av_mallocz(unsigned int)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:53: undefined reference to `guess_format(char const*, char const*, char const*)'
zm_mpeg.o: In function `VideoStream::Initialise()':
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:39: undefined reference to `av_register_all()'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:284: undefined reference to `av_free(void*)'
/root/ZoneMinder-1.22.3/src/zm_mpeg.cpp:233: undefined reference to `av_write_header(AVFormatContext*)'
make[2]: *** [zmc] Error 1
any idea?
ammaross
Post by ammaross » Mon Jun 02, 2008 4:46 pm
Try this posting. Seems to solve this exact compile issue.
http://www.zoneminder.com/forums/viewto ... der+ffmpeg
It has a link to a patch for ZM that accomidates the new ffmpeg.
Users browsing this forum: No registered users and 6 guests
