andrew
Post
by andrew » Sun Oct 28, 2007 8:57 pm
I have a small problem that after several days of using ZM on my Ubuntu box it falls over, now I dont know if it is a Ubuntu issue or ZM, I get an error on the main page it starts :-
warning session-start [function session start] open(var/lib/php5/session_bxxxxxxxxxxx, O_RDWR) Failed Read onnly file system(30) in usr/share/zoneminder/zmphp on line 177
But the rest of the pc is locked and no programs will start, I reset the pc and it does a fsck and shows up lots of links to image files of ZM which donot exist and inode issues.
Can any advise me if it is a Ubuntu issue or ZM I am using Peter .deb install.
Many thanks
cordel
Post
by cordel » Sun Oct 28, 2007 10:04 pm
This sounds more like a failing hard drive to me but I could be wrong.
MJN
Post
by MJN » Sun Oct 28, 2007 10:26 pm
Take a look in /var/log/messages for indications why the filesystem is being mounted as read only. This is a mechanism of preventing further data loss on a live system when things start going horribly wrong and, as Cordel says, could well be a sign that the drive is failing.
Mathew
Lee Sharp
Post
by Lee Sharp » Mon Oct 29, 2007 3:10 pm
That is exactly how every Ubuntu machine with a failing hard drive looks to me. It will get worse.
andrew
Post
by andrew » Mon Oct 29, 2007 5:41 pm
Thank you for your replies,
I have the box back at the creator! and it certainly has hard drive issues. So I will be putting a much bigger HD this time as 250GB wasn't big enough.
Thank you...
Users browsing this forum: No registered users and 5 guests
