Alarm Check Method real-life diffrence?
SyRenity
Post by SyRenity »
Hi.
After playing with the zones a bit, I wonder if someone ever used other alarm check method then "blobs", and have found it more accurate or faster?
Lee Sharp
Post by Lee Sharp »
Yes. It uses less CPU but it doesn't give you the nice red outline to troubleshoot false positives.
SyRenity
Post by SyRenity »
Thanks for the info.
And what about the accuracy? Is it accurate in the same way as the blobs method?
Lee Sharp
Post by Lee Sharp »
I have not noticed a difference, but I have not looked that closely.
jameswilson
Post by jameswilson »
from memory the othe rmethods are the old methods ie filtered and alarmed and are not as good, filtered might be ok but blobs has additional processing plus the prettyness mentioned
sy, if you wanana make you r box public and let me in ill have a look if you like. Ive laways used blobs
James Wilson
