leandrorepolho
Post
by leandrorepolho » Tue Oct 23, 2007 1:19 pm
Hello, i would like to only record my movies when a door is open, so i had defined a new zone in my camera called "door zone" and set the camera type to Mocord, but when i move the door it keeps IDLE and does not start to record.
Runing on Ubuntu Server 7.04
How should i proceed ??
japerlman
Post
by japerlman » Tue Oct 23, 2007 2:34 pm
What type of zone did you define it as?
Also your thresholds might be to high, try lowering them.
leandrorepolho
Post
by leandrorepolho » Tue Oct 23, 2007 3:14 pm
japerlman wrote:What type of zone did you define it as?
Zone Door
Type: Active
Preset: Fast, medium sensitivy
japerlman
Post
by japerlman » Tue Oct 23, 2007 3:24 pm
Try setting it to the 'low sensitivity'.
If the door is far from the camera not enough might be changing in the picture to set off the alarm.
MJN
Post
by MJN » Tue Oct 23, 2007 10:08 pm
If that's the case then if anything you'd need high sensitivity...
cordel
Post
by cordel » Wed Oct 24, 2007 2:55 am
Try using modect for recordings with only motion, mocord just constantly records.
Users browsing this forum: No registered users and 16 guests
