[Solved]Suse 10.3 an Zoneminder
schnurzelat
Post by schnurzelat » Mon Oct 15, 2007 1:14 pm
i've upgraded from Suse 10.2 to Suse 10.3. But after the Update the Webinterfache won't work anymore. The Services started properly, but if i try to open the Webinterface, there is a strange looking window. Even the name of the Window is incorrect: <?= ZM_WEB_TITLE_PREFIX ?> etc.
I think there is something missing in apache2, but i've no idea what missing modul cause this error. Can anyone help?
Thanks.
schnurzelat
# Files in this directory are created at apache start time by /usr/sbin/rcapache2
# Do not edit them!
# as listed in APACHE_MODULES (/etc/sysconfig/apache2)
LoadModule authz_host_module              /usr/lib/apache2-prefork/mod_authz_host.so
LoadModule actions_module                 /usr/lib/apache2-prefork/mod_actions.so
LoadModule alias_module                   /usr/lib/apache2-prefork/mod_alias.so
LoadModule auth_basic_module              /usr/lib/apache2-prefork/mod_auth_basic.so
LoadModule authz_groupfile_module         /usr/lib/apache2-prefork/mod_authz_groupfile.so
LoadModule authn_file_module              /usr/lib/apache2-prefork/mod_authn_file.so
LoadModule authz_user_module              /usr/lib/apache2-prefork/mod_authz_user.so
LoadModule autoindex_module               /usr/lib/apache2-prefork/mod_autoindex.so
LoadModule cgi_module                     /usr/lib/apache2-prefork/mod_cgi.so
LoadModule dir_module                     /usr/lib/apache2-prefork/mod_dir.so
LoadModule include_module                 /usr/lib/apache2-prefork/mod_include.so
LoadModule log_config_module              /usr/lib/apache2-prefork/mod_log_config.so
LoadModule mime_module                    /usr/lib/apache2-prefork/mod_mime.so
LoadModule negotiation_module             /usr/lib/apache2-prefork/mod_negotiation.so
LoadModule setenvif_module                /usr/lib/apache2-prefork/mod_setenvif.so
LoadModule status_module                  /usr/lib/apache2-prefork/mod_status.so
LoadModule userdir_module                 /usr/lib/apache2-prefork/mod_userdir.so
LoadModule asis_module                    /usr/lib/apache2-prefork/mod_asis.so
LoadModule imagemap_module                /usr/lib/apache2-prefork/mod_imagemap.so
LoadModule php5_module                    /usr/lib/apache2/mod_php5.so
LoadModule authz_default_module           /usr/lib/apache2-prefork/mod_authz_default.so
LoadModule ssl_module                     /usr/lib/apache2-prefork/mod_ssl.so
LoadModule proxy_module                   /usr/lib/apache2-prefork/mod_proxy.so
LoadModule proxy_http_module              /usr/lib/apache2-prefork/mod_proxy_http.so
LoadModule proxy_connect_module           /usr/lib/apache2-prefork/mod_proxy_connect.so
LoadModule apparmor_module                /usr/lib/apache2-prefork/mod_apparmor.so
achix
Post by achix » Mon Oct 15, 2007 3:12 pm
what do the logs of apache say?
write simple php script with one line
phpinfo();
and see if you can run it.
schnurzelat
Post by schnurzelat » Mon Oct 15, 2007 9:05 pm
I' ve found the following line in the apache log:
[client 127.0.0.1] script '/srv/www/htdocs/zm/zm_audit.php' not found or unable to stat
The File doesn't exists in the specified folder. Where can i get this file? It is not included in ZoneMinder-1.22.3.tar.gz.
I've made a file named, index.php in my webserver root directory and put the lines in it. If i call the index.php i can only see a blank page.
I'm running also phpMyAdmin and phpBB. Both works fine.
Any suggestions?
Thanks.
monex
Post by monex » Wed Oct 17, 2007 7:23 pm
i've got similar error :)
you have to enable short tags for php. some how these are diabled by default
open /etc/php5/apache2/php.ini
change
short_open_tag = Off
to
short_open_tag = On
this should do it.
hope this helps
schnurzelat
Post by schnurzelat » Thu Oct 18, 2007 10:33 am
THANKS!
That solves the problem!
greetings
schnurzelat
Users browsing this forum: No registered users and 5 guests
