Recursive config: MODECT CAN'T STOP RECORDING.
giulio_asc
Post by giulio_asc » Fri Sep 07, 2007 10:52 pm
Dear sirs,
I have search in forum, but not find similar problem.
if is it, please forgive me, i not find probably for my bad english.
the situation is:
the cam watch a car in a parking place.
the car go away and the cam detect and (modect mode) start recording. BUT NOT STOP.
PROBLEM 1: I not find any mode in the configurations panels to limit\selecting recording after
alarm
BY TIME. exist one solution?
the cam a this point (after 120 sec for example) must stop recording and acquire a new ''stand-by''
situation on empty parking.
PROBLEM 2: how to select the ''new'' image (empty parking) to analyze in modect mode?
the car back to parking place. new the cam detect movement and start reconding for 120 sec, ecc ecc
(go to problem 1).
I need to implement this recursive situation.
I use ubuntu festy an zm 1.22.3.
thanks for help.
:roll:
Giulio from Italy.
morpheus106
Post by morpheus106 » Sat Sep 08, 2007 8:28 am
Ciao Giulio
avevo anch'io il tuo stesso problema, ma l'ho risolto (almeno spero) impostando una sola zona e con parametri minimi un pò + alti
Poi verifica dalle imamgini che ti ha catturato (e che non avrebbe dovuto) dove è avvenuto il movimento e verifica i dati
Hi Giulio
i'had an equal problem and i have set the minimal parameter alarm area e filter and 1 zone only to time
Sorry for my english
Lee Sharp
Post by Lee Sharp » Sat Sep 08, 2007 5:38 pm
A little more information will help us.
First, how did you install it? Did you compile it, or use Peter's debs? And what version?
Second, what are the settings you have for your zones, and for your buffers?
Users browsing this forum: No registered users and 17 guests
