Page 1 of 1
don't stop capture
Posted: Wed Sep 05, 2007 6:02 pm
by morpheus106
Why don't stop capture when there are not many movements?
my set zone is:
Unità Percent
Colore Allarme (RGB) 255/0/0
Metodo di Controllo Allarme Blobs
Min/Max Pixel Threshold (0-255) 20 50
Filter Width/Height (pixels) 3 5
Zone Area 100
Min/Max Alarmed Area 8 40
Min/Max Filtered Area 6 20
Min/Max Blob Area 2 5
Min/Max Blobs 2 5
There is some parameter too much sensible?
help me please!!
Posted: Thu Sep 06, 2007 7:27 am
by Laevi
Maybe u linked the monitor to itself so it keeps recording when motion is detected?
Posted: Thu Sep 06, 2007 10:29 am
by morpheus106
if i watch my image capture there are zone-red in the image but in these zone is not movements or peoples and for this reason the capture don't stop
perhaps i have set zm too much sensible, which parameter I can modify?
this is image
http://www.pixilive.com/viewi/20070906/611-analyse.jpg
the other images are much similar
Posted: Fri Sep 07, 2007 5:49 am
by Lee Sharp
Changes in light intensity. You need to make it less sensitive, or crop out the edges when the shadowing is the worst.
Posted: Fri Sep 07, 2007 7:33 am
by morpheus106
where is the parameter to make it less sensitive?
Posted: Sat Sep 08, 2007 5:24 pm
by Lee Sharp
You need to load up the active zone for the camera. If you have not done anything, there will only be one. To change sensitivity, choose a preset. Best uses blobs, and gives you the red lines to see what is happening, but is more CPU intensive. Fast does not use blobs, and is easier on the CPU, but harder to fine tune. On the right is the camera, and you can drag the points to exclude regions of the camera that will alarm. You can also add more points to make more complex shapes. The less area you have to check, the less CPU you will use. This is all in the documentation, but may not be so intuitive.
