Zoneminder database problems... first time user. Help Please
kingpikey
Post by kingpikey » Wed Sep 05, 2007 12:16 am
ok i followed the instructions in the readme, rpms seem to have installed correctly.
when i go to
https://myip:81/zm/
i get this...
 Could not connect to database: Access denied for user 'zmuser'@'localhost' (using password: YES)
I've been googling my fingers off, searched here, zoneminder forums, etc etc. Please help!!
kingpikey
Post by kingpikey » Wed Sep 05, 2007 12:17 am
forgot to mention, I followed the instructions I found here... followed the readme.
http://www.clarkconnect.com/forums/show ... art=2&vc=1
I'm trying to get this installed on ClarkConnect.
Thanks in advance.
agilseguranca
Post by agilseguranca » Wed Sep 05, 2007 11:41 am
kingpikey wrote:forgot to mention, I followed the instructions I found here... followed the readme.
Thanks in advance.
Check in MySQL if this user exists, look the default password too: u:zmuser p:zmpass
Using PhpMyAdmin can be easier.
Sorry my english... :oops:
Laevi
Post by Laevi » Wed Sep 05, 2007 11:45 am
you're filling in 'YES' as pass when you try to connect to mysql database while it should be 'zmpass'. switch it :roll:
we4zonM
Post by we4zonM » Thu Jan 15, 2009 10:05 am
How do you tell Zoneminder to use a different username and password when you start it? Such as using "yes" instead of "zmpass"?
cordel
Post by cordel » Thu Jan 15, 2009 10:12 am
That is covered in the documentation:
http://www.zoneminder.com/wiki/index.ph ... n#Building
Third paragraph.
we4zonM
Post by we4zonM » Thu Jan 15, 2009 12:41 pm
./configure --with-webdir=<your> --with-cgidir=<your>
./configure --with-webdir=<your> --with-cgidir=<your> ZM_DB_PASS=zmnewpass
This does mention ZM_DB_USER and ZM_DB_PASS, but this is for changing it at build time. If you have already built it, it does not tell you how to change it! I tried editing the zm.conf file and that seemed to work.
cordel
Post by cordel » Mon Jan 19, 2009 1:56 am
There is that as well, just the configured database user must match what is in zm.conf.
Users browsing this forum: No registered users and 7 guests
