How to receive and process two video streams from different DVRs in the ZoneMinder?
I have two video streams from different DVRs. Is it possible to receive and process these streams in the ZoneMinder?
Re: How to receive and process two video streams from different DVRs in the ZoneMinder?
You should be able to do that if you can view the streams in a web browser or VLC.
You will be able to view a stream in the browser or in the VLC player it's when the flow from the IP camera. But I have the stream from the DVR ... And I would like to process it in ZoneMinder. Is it posible in ZoneMinder?
As far as I know, ZM doesn't care where a stream comes from, so long as it's in a format it understands.
So give it a shot - should be fine unless it's encrypted.
