Running on Gentoo Linux, chromium 95.0.4638.69, PHP 8.0.12, Apache 2.4.51-r1
I see the following in web_js.log
11/19/21 11:07:24.336151 web_js[2406].ERR [xxx.xxx.xxx.xxx] [Uncaught%20TypeError%3A%20stats%20is%20not%20iterable] at https://lyalls-pc.at.the-pearces.com/zm/cache/skins_classic_views_js_frame-dark-1637274650.js line 60
https://example.com/zm/index.php?view=event&eid=8364&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=StartDateTime&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3E%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=-1+day&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Battr%5D=MonitorId&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bval%5D=2&filter%5BQuery%5D%5Bsort_asc%5D=0&filter%5BQuery%5D%5Bsort_field%5D=StartDateTime&filter%5BQuery%5D%5Blimit%5D=100&sort_field=StartDateTime&sort_asc=0&page=1
Since Pause does not work, the step forward and backward buttons also do not work.
Only the skip forward and backward seem to operate.
