Nov 1 10:12:18 doghouse web_php[1674415]: 11/01/21 10:12:18.357243 web_php[1674415].ERR [192.168.1.41]
[Socket /run/zm/zms-257651s.sock does not exist. This file is created by zms, and since it does not exist, either zms
did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that
the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the
capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/
faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
at /usr/share/zoneminder/www/includes/functions.php line 1902
# ZoneMinder url path to the zms streaming server
ZM_PATH_ZMS=/zm/cgi-bin/nph-zms
kalle@doghouse:/etc/zm/conf.d$ ls -l /run/zm/
total 4
srwxrwxr-x 1 www-data www-data 0 marras 1 10:11 zmdc.sock
-rw-rw-r-- 1 www-data www-data 7 marras 1 10:11 zm.pid
-rw------- 1 www-data www-data 0 loka 28 14:38 zms-055718.lock
-rw------- 1 www-data www-data 0 marras 1 09:47 zms-073287.lock
-rw------- 1 www-data www-data 0 loka 30 09:38 zms-089335.lock
-rw------- 1 www-data www-data 0 marras 1 10:12 zms-257651.lock
-rw------- 1 www-data www-data 0 loka 28 18:57 zms-862369.lock
-rw------- 1 www-data www-data 0 loka 31 17:39 zms-864815.lock
-rw------- 1 www-data www-data 0 marras 1 09:56 zms-920305.lock
srwxrwxr-x 1 www-data www-data 0 marras 1 10:11 zmtrigger.sock
How can I get rid of those error messages?
