Released 1.36.10 The Memory Remains
Changes since 1.36.9
- Set shm->valid to false on disconnect. Fix linked monitors stopping after a while
- Documentation update regard WEB_TITLE
- Corrections to filters when using row locks. An error would commit, ending the transaction and locks.
- Fix monitor type labels by adding an Unknown for entry 0. Implement Function_Strings.
- Fix decoding_enabled not being recalculated correctly because we havn't loaded savejpegs or videowriter yet.
- Fix logic ordering in db 1.35.14 update that moves columns from Monitor table to Monitor_Status
- set vertical-align:top on monitor edit labels
- We now delete a non-keyframe from head instead of waiting in capture. This should fix lockups when MaxImageBufferCount is too low.
1.36.10
Full Changelog
