I tried following https://zoneminder.readthedocs.io/en/stable/api.html
I have Gentoo Linux, PHP 8 apcu enabled (shows up in phpinfo).
apcu
APCu Support Enabled
Version 5.1.19
APCu Debugging Disabled
MMAP Support Enabled
MMAP File Mask no value
Serialization Support php
Build Date Oct 18 2021 21:21:33
I receive 404 errors when using curl, as described in https://zoneminder.readthedocs.io/en/stable/api.html
# curl http://localhost/zm/api/host/getVersion.json
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL was not found on this server.</p>
<hr>
<address>Apache Server at localhost Port 80</address>
</body></html>
127.0.0.1 - - [27/Oct/2021:22:54:26 +1030] "GET /zm/api/host/getVersion.json HTTP/1.1" 404 255
Nothing more serious than a Warning is generated in the Web based ZM log.
No indication of errors in /var/log/zoneminder/* logs, including cake_error.log
