Cannot create new events. Database errors.
CyanideSandwich
Post by CyanideSandwich »
Hello. I am new to ZM and I have encountered an issue. I am sometimes getting the following error messages in my logs. When I do, new events aren't being created on the monitor(s) in question.
Sep 20 12:37:57 zm zmc_m4[32427]: ERR [zmc_m4] [Can't run query INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES #012( 189176, 29, 'Normal', from_unixtime( 1632155875 ), 4.60, 0 ),#012( 189176, 30, 'Normal', from_unixtime( 1632155875 ), 4.75, 0 ),#012( 189176, 31, 'Normal', from_unixtime( 1632155876 ), 4.95, 0 ),#012( 189176, 32, 'Normal', from_unixtime( 1632155876 ), 5.09, 0 ),#012( 189176, 33, 'Alarm', from_unixtime( 1632155876 ), 5.24, 2 ),#012( 189176, 34, 'Alarm', from_unixtime( 1632155876 ), 5.45, 3 ),#012( 189176, 35, 'Alarm', from_unixtime( 1632155876 ), 5.60, 6 ): Cannot add or update a child row: a foreign key constraint fails (`zm`.`Frames`, CONSTRAINT `Frames_ibfk_1` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
Sep 20 12:37:58 zm zmc_m1[32413]: INF [zmc_m1] [Front Porch: 321 - Gone into alarm state PreAlarmCount: 4 > AlarmFrameCount:5 Cause:Motion Right]
Sep 20 12:37:58 zm zmc_m4[32427]: ERR [zmc_m4] [Can't run query INSERT INTO `Stats` (`EventId`, `FrameId`, `MonitorId`, `ZoneId`, `PixelDiff`, `AlarmPixels`, `FilterPixels`, `BlobPixels`,`Blobs`,`MinBlobSize`, `MaxBlobSize`, `MinX`, `MinY`, `MaxX`, `MaxY`,`Score`) VALUES #012(189176,29,4,8,28,2177,0,0,0,0,0,0,0,0,0,0),#012(189176,29,4,21,29,293,0,0,0,0,0,0,0,0,0,0),#012(189176,29,4,10,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,29,4,11,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,29,4,13,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,30,4,8,28,1724,0,0,0,0,0,0,0,0,0,0),#012(189176,30,4,21,35,347,0,0,0,0,0,0,0,0,0,0),#012(189176,30,4,10,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,30,4,11,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,30,4,13,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,31,4,8,26,1715,0,0,0,0,0,0,0,0,0,0),#012(189176,31,4,21,27,230,0,0,0,0,0,0,0,0,0,0),#012(189176,31,4,10,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,31,4,11,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,31,4,13,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,32,4,8,27,2316,0,0,0,0,0,0,0,0,0,0),#012(189176,32,4,21,32,335,0,0,0,0,0,0,0,0,0,0),#012(189176,32,4,10,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,32,4,11,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,32,4,13,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,33,4,8,29,2653,0,0,0,0,0,0,0,0,0,0),#012(189176,33,4,21,56,530,0,0,0,0,0,0,0,0,0,2),#012(189176,33,4,10,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,33,4,11,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,33,4,13,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,34,4,8,37,2858,0,0,0,0,0,0,0,0,0,0),#012(189176,34,4,21,69,939,0,0,0,0,0,0,0,0,0,3),#012(189176,34,4,10,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,34,4,11,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,34,4,13,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,35,4,8,38,3926,0,0,0,0,0,0,0,0,0,0),#012(189176,35,4,21,76,1640,0,0,0,0,0,0,0,0,0,6),#012(189176,35,4,10,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,35,4,11,0,0,0,0,0,0,0,0,0,0,0,0),#012(189176,35,4,13,0,0,0,0,0,0,0,0,0,0,0,0): Cannot add or update a child row: a foreign key constraint fails (`zm`.`Stats`, CONSTRAINT `Stats_ibfk_3` FOREIGN KEY (`EventId`) REFERENCES `Events` (`Id`) ON DELETE CASCADE)]
Sep 20 12:37:58 zm zmc_m2[32417]: INF [zmc_m2] [Back Porch: 350 - Gone into prealarm state]
Sep 20 12:37:58 zm zmc_m3[32422]: ERR [zmc_m3] [Can't open /zm/3/2021-09-20/189175/00054-capture.jpg for writing: No such file or directory]
Sep 20 12:37:58 zm zmc_m3[32422]: ERR [zmc_m3] [Failed to write frame image]
Sep 20 12:37:58 zm zmc_m3[32422]: ERR [zmc_m3] [Can't open /zm/3/2021-09-20/189175/00054-analyse.jpg for writing: No such file or directory]
Sep 20 12:37:58 zm zmc_m3[32422]: ERR [zmc_m3] [Failed to write analysis frame image]
Sep 20 12:37:58 zm zmc_m4[32427]: ERR [zmc_m4] [Can't open /zm/4/2021-09-20/189176/00043-capture.jpg for writing: No such file or directory]
Sep 20 12:37:58 zm zmc_m4[32427]: ERR [zmc_m4] [Failed to write frame image]
Sep 20 12:37:58 zm zmc_m4[32427]: ERR [zmc_m4] [Can't open /zm/4/2021-09-20/189176/00043-analyse.jpg for writing: No such file or directory]
Sep 20 12:37:58 zm zmc_m4[32427]: ERR [zmc_m4] [Failed to write analysis frame image]
Sep 20 12:37:58 zm zmc_m4[32427]: ERR [zmc_m4] [Can't open /zm/4/2021-09-20/189176/00044-capture.jpg for writing: No such file or directory]
Sep 20 12:37:58 zm zmc_m4[32427]: ERR [zmc_m4] [Can't open /zm/4/2021-09-20/189176/00044-analyse.jpg for writing: No such file or directory]
For these errors, it seems like I can "fix" the problem by deleting the most recent event for the monitor. I have no idea if or what I am doing that would cause them to start happening.
Can somebody help me?
Re: Cannot create new events. Database errors.
I've seen this when events were being deleted immediately after creation. Check your filters.
Any filter that deletes events or does much of anything should have an End Date/Time NOT NULL rule so that it only matches finished events.
CyanideSandwich
Okay so I *thought* the only filters I had were the two that came with ZM. However I had a bunch of "_TMP" filters and a few of them were set to run in the background. I deleted all of these. So let's see what happens now.
Thanks!
EdwinZ
Post by EdwinZ »
I had the same error, but no additional filters to PurgeWhenFull and Update DiskSpace, which puzzled me a lot.
Then I noticed that (due to another process logging extensively on the same partition) my Diskspace was at 80%, which triggered the PurgeWhenFull filter during an event, creating such parent/child database errors.
Cleaning up my partition solved the issue...
JCAK
Post by JCAK »
iconnor wrote: Mon Sep 20, 2021 5:59 pm I've seen this when events were being deleted immediately after creation. Check your filters.
I had the same problem and I could fix it following your suggest. THANKS !!
