I updated my zoneminder from 1.34 to 1.36 and also updated to the lastet Event Server 6.1.27 in order to be able to use my coral edge tpu.
However everything works fine until i switch the models from full yolo v3 to edge tpu. Then i get the following error:
Unrecoverable error:No module named 'edgetpu' Traceback:Traceback (most recent call last): File "/var/lib/zmeventnotification/bin/zm_detect.py", line 849, in main_handler() File "/var/lib/zmeventnotification/bin/zm_detect.py", line 321, in main_handler m = object_detection.Object(logger=g.logger, options=g.config) File "/usr/local/lib/python3.8/dist-packages/pyzm/ml/object.py", line 30, in __init__ import pyzm.ml.coral_edgetpu as tpu File "/usr/local/lib/python3.8/dist-packages/pyzm/ml/coral_edgetpu.py", line 14, in from edgetpu.detection.engine import DetectionEngineModuleNotFoundError: No module named 'edgetpu'
Any idea what the cause is?
Thanks in advance
Best regards
Flave
