Downgrade to 1.36.x from 1.37
goatman64
Post by goatman64 »
I'm stuck ... I've been running 1.37 for a while as I needed the newer zmeventnotification enhancements. Now that those enhancements exist in 1.36 I'd like to run 1.36.x.
At one point the do_debian_package.sh with --snapshot=stable script downgraded my install to 1.36.x
After a couple of weeks .. I did another do_debian_package.sh and my install jumped back to 1.37.
I populated the new ppa for 1.36 and tried the apt route but can't get back to 1.36.x
I've tried --reinstall apt flag and apt indicates it will DOWNGRADE but nothing happens ... my install continues as 1.37.
What am I missing here?
Thanks in advance
Re: Downgrade to 1.36.x from 1.37
sudo apt-get install zoneminder=1.36.4-focal should do the trick. Assuming you running ubuntu focal. Replace with the name of whatever distro you are using.
Oh wait, I think I released 1.36.5, you should that instead.
goatman64
Post by goatman64 »
I tried that ... it acts like it wants to downgrade but does nothing ...
apt install -s zoneminder=1.36.5-focal1
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
libb64-0d libjwt-gnutls0
Suggested packages:
fcgiwrap
Recommended packages:
zoneminder-doc
The following NEW packages will be installed:
The following packages will be DOWNGRADED:
zoneminder
0 upgraded, 2 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
Inst libb64-0d (1.2-5 Ubuntu:20.04/focal [amd64])
Inst libjwt-gnutls0 (1.10.2-1 Ubuntu:20.04/focal [amd64])
Inst zoneminder [1.37.0-focal] (1.36.5-focal1 ZoneMinder 1.36 The Memory Remains:20.04/focal [amd64])
Conf libb64-0d (1.2-5 Ubuntu:20.04/focal [amd64])
Conf libjwt-gnutls0 (1.10.2-1 Ubuntu:20.04/focal [amd64])
Conf zoneminder (1.36.5-focal1 ZoneMinder 1.36 The Memory Remains:20.04/focal [amd64])
goatman64
Post by goatman64 »
In my many attempts to get this work I tried the -s ...
Once I got the full version correct I was able to downgrade to 1.36.5
apt install zoneminder=1.36.5-focal1
One follow-up question ... if you use the do_debian_package.sh with --snapshot=stable ... shouldn't that pull the 1.36 branch?
As always, many thanks for all the work that goes into Zoneminder.... awesome stuff!
