Delete logs from interface
gruiarew
Post by gruiarew »
I just realized that after the upgrade to 1.36.X logs cannot be anymore deleted from GUI. Was that intentional or?
Re: Delete logs from interface
It was gone in my 1.35 version.
If you are trying to delete logs to save space, then do that under Options -> Logs to have them automatically purged.
If you are trying to delete events to simply get them out of the way, then use the search filter instead.
