I installed ZoneMinder with Apache on Raspberry Pi4 and I configured a local usb camera (/dev/video0) but is not capturing from it. Seems that the problem is related with cgi configuration.
Zoneminder error log:
"Socket /var/run/zm/zms-297092s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information."
In Apache error log:
[Tue Jun 08 18:52:14.079099 2021] [cgi:error] [pid 30597] [client _______: Unable to connect to zmc process. Please ensure that it is running.: /usr/lib/zoneminder/cgi-bin/nph-zms, referer: http://____/zm/index.php?view=watch&mid=1
I've run into this before, is there more to the errors in the logs? Check local camera permissions that the web server / ZM user has access to /dev/video*
Other thing I remember from some instances that my OS did not have the dependencies to stream the local usb cams.
Yes there are some other errors I encountered. I tried to follow the instructions found so far but it could be good if there is any document for troubleshooting CGI with Apache + Zoneminder.
The other errors:
Socket /var/run/zm/zms-491186s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2051
web_js 886 ERR TypeError: streamStatus is undefined http://______/zm/cache/skins_classic_views_js_watch-classic-1544278956.js
Hi!
I tried with 320x240 and 160x120 capturing resolutions. The problem remains.
Error log:
2021-06-10 web_js 899 WAR Adjusting to minimum width when getting popup size for tag 'watch' - getPopupSize() ?view=montagereview
2021-06-10 web_php 867 ERR Socket /var/run/zm/zms-349502s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information. /usr/share/zoneminder/www/includes/functions.php
I also checked the /var/run/zm/ directory and it creates a .sock file and the it shows like it capturing frames.
captured frames
