Capture crash on 1.36.1 (CentOS 8)
don-code
Post by don-code »
I just upgraded to ZoneMinder 1.36.1 on a CentOS 8 box and am having issues getting capture to run on any cameras. Each gives the following backtrace:
[root@localhost yum.repos.d]# uname -a
Linux localhost.localdomain 4.18.0-240.22.1.el8_3.x86_64 #1 SMP Thu Apr 8 19:01:30 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
[root@localhost yum.repos.d]# zmc --version
1.36.1
May 28 16:22:22 localhost.localdomain zmc_m1[5033]: INF [zmc_m1] [Starting Capture version 1.36.1]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Got signal 6 (Aborted), crashing]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Signal address is 0x30000013a9, from 0x7f6c8c1487ff]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Backtrace 0: /usr/bin/zmc(+0xd002a) [0x55f74e37602a]]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Backtrace 1: /lib64/libpthread.so.0(+0x12b20) [0x7f6c8f89fb20]]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Backtrace 2: /lib64/libc.so.6(gsignal+0x10f) [0x7f6c8c1487ff]]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Backtrace 3: /lib64/libc.so.6(abort+0x127) [0x7f6c8c132c35]]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Backtrace 4: /usr/bin/zmc(+0x54418) [0x55f74e2fa418]]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Backtrace 5: /usr/bin/zmc(+0xb9ec7) [0x55f74e35fec7]]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Backtrace 6: /usr/bin/zmc(+0xbb358) [0x55f74e361358]]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Backtrace 7: /lib64/libstdc++.so.6(+0xc2ba3) [0x7f6c8cb30ba3]]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Backtrace 8: /lib64/libpthread.so.0(+0x814a) [0x7f6c8f89514a]]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: ERR [zmc_m1] [Backtrace 9: /lib64/libc.so.6(clone+0x43) [0x7f6c8c20df23]]
May 28 16:22:23 localhost.localdomain zmc_m1[5033]: INF [zmc_m1] [Backtrace complete, please execute the following command for more information: addr2line -e /usr/bin/zmc 0x55f74e37602a 0x7f6c8f89fb20 0x7f6c8c1487ff 0x7f6c8c132c35 0x55f74e2fa418 0x55f74e35fec7 0x55f74e361358 0x7f6c8cb30ba3 0x7f6c8f89514a 0x7f6c8c20df23]
The packages I have installed (from RPM Fusion) are as follows. I didn't have the debug packages installed at the time the issue started.
[root@localhost yum.repos.d]# rpm -qa | grep zoneminder
zoneminder-common-debuginfo-1.36.1-1.el8.x86_64
zoneminder-1.36.1-1.el8.x86_64
zoneminder-common-1.36.1-1.el8.x86_64
zoneminder-httpd-1.36.1-1.el8.x86_64
zoneminder-debugsource-1.36.1-1.el8.x86_64
Happy to help debug in any way I can. have two other CentOS 8 boxes that I have not yet upgraded, and I can walk through the upgrade process on one of them to help debug, provided I come up with some restore process for them first. The machine with the issue is not remotely accessible, so there may be a few days between my access to it.
don-code
Re: Capture crash on 1.36.1 (CentOS 8)
Post by don-code »
I have upgraded to 1.36.3 and see the same crash.
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Got signal 6 (Aborted), crashing]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Signal address is 0x30001107c1, from 0x7f8a57ded37f]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Backtrace 0: /usr/bin/zmc(+0xd002a) [0x56114a2e402a]]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Backtrace 1: /lib64/libpthread.so.0(+0x12b20) [0x7f8a5b546b20]]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Backtrace 2: /lib64/libc.so.6(gsignal+0x10f) [0x7f8a57ded37f]]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Backtrace 3: /lib64/libc.so.6(abort+0x127) [0x7f8a57dd7db5]]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Backtrace 4: /usr/bin/zmc(+0x54418) [0x56114a268418]]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Backtrace 5: /usr/bin/zmc(+0xb9ec7) [0x56114a2cdec7]]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Backtrace 6: /usr/bin/zmc(+0xbb358) [0x56114a2cf358]]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Backtrace 7: /lib64/libstdc++.so.6(+0xc2ba3) [0x7f8a587d7ba3]]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Backtrace 8: /lib64/libpthread.so.0(+0x814a) [0x7f8a5b53c14a]]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: ERR [zmc_m3] [Backtrace 9: /lib64/libc.so.6(clone+0x43) [0x7f8a57eb2dc3]]
Jun 04 23:54:29 localhost.localdomain zmc_m3[1116097]: INF [zmc_m3] [Backtrace complete, please execute the following command for mor...
I also updated another host on CentOS 8 and am not seeing the crash. Unlike this host, the new host I upgraded is remotely accessible.
I am additionally going to try a fresh install of Zoneminder on a CentOS 8 VM and see if this works. If it does, I'll take a database dump the next time I'm at the isolated host, restore it, and see if I can reproduce.
don-code
Post by don-code »
I took a backup of the Zoneminder database and determined two things from it:
1. I can't reproduce the crash if the cameras are unavailable - the capture daemon exits gracefully in this situation. (This limits how effectively I can test off-site, since I can't also bring the cameras with me.)
2. If I restore the database to another host with a clean install of Zoneminder 1.36.3 on CentOS 8, I see the same crash.
1.36.4 hasn't yet hit the RPM Fusion testing repo, and I didn't have time to manually install during my last visit, so I will try again whenever it's pushed there.
pszonem
Post by pszonem »
I am facing the same issue. Centos7 clean install. My previous installation is gone due to HDD failure. I don't want to use backup, thus install from scratch. So tried to use Monitor/Nodect for my cameras, but no success :(
I did use RPMFusion repo.
zmc 1.36.5
CentOS Linux release 7.9.2009 (Core)
Updated
log:
Sep 14 22:46:18 cent02 zmdc[3397]: INF [Starting pending process, zmc -m 2]
Sep 14 22:46:18 cent02 zmdc[3397]: INF ['zmc -m 2' starting at 21/09/14 22:46:18, pid = 6270]
Sep 14 22:46:18 cent02 zmdc[6270]: INF ['zmc -m 2' started at 21/09/14 22:46:18]
Sep 14 22:46:18 cent02 zmc_m2[6270]: INF [zmc_m2] [Starting Capture version 1.36.5]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Got signal 6 (Aborted), crashing]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Signal address is 0x300000187e, from 0x7f597891e387]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 0: /usr/bin/zmc() [0x4bbedc]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 1: /lib64/libpthread.so.0(+0xf630) [0x7f597c0df630]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 2: /lib64/libc.so.6(gsignal+0x37) [0x7f597891e387]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 3: /lib64/libc.so.6(abort+0x148) [0x7f597891fa78]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 4: /lib64/libc.so.6(+0x78f67) [0x7f5978960f67]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 5: /lib64/libc.so.6(+0x7f474) [0x7f5978967474]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 6: /lib64/libc.so.6(+0x816a4) [0x7f59789696a4]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 7: /usr/bin/zmc() [0x49eccc]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 8: /usr/bin/zmc() [0x49fdb6]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 9: /lib64/libstdc++.so.6(+0xb5330) [0x7f5979283330]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 10: /lib64/libpthread.so.0(+0x7ea5) [0x7f597c0d7ea5]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: ERR [zmc_m2] [Backtrace 11: /lib64/libc.so.6(clone+0x6d) [0x7f59789e69fd]]
Sep 14 22:46:18 cent02 zmc_m2[6270]: INF [zmc_m2] [Backtrace complete, please execute the following command for more information: addr2line -e /usr/bin/zmc 0x4bbedc 0x7f597c0df630 0x7f597891e387 0x7f597891fa78 0x7f5978960f67 0x7f5978967474 0x7f59789696a4 0x49eccc 0x49fdb6 0x7f5979283330 0x7f597c0d7ea5 0x7f59789e69fd]
Sep 14 22:46:18 cent02 zmdc[3397]: ERR ['zmc -m 2' exited abnormally, exit status 6]
addr2line -e /usr/bin/zmc 0x4bbedc 0x7f597c0df630 0x7f597891e387 0x7f597891fa78 0x7f5978960f67 0x7f5978967474 0x7f59789696a4 0x49eccc 0x49fdb6 0x7f5979283330 0x7f597c0d7ea5 0x7f59789e69fd:
??:0
??:0
??:0
??:0
??:0
??:0
??:0
??:0
??:0
pszonem
Post by pszonem »
Same issue with 'zoneminder-1.37.1 ' from 'https://zmrepo.zoneminder.com/el/7/x86_64/'. Don't have a time to fight with Docker, thus used my backup and put back 1.34-22 - which works like a charm!
pszonem
Post by pszonem »
No one? I accidentally updated to 1.36.10 - same issue. It is really so rare???
I'm running 1.36.10 and 11 on a ton of centos 7 boxes. No problems.
Perhaps if you gave us some information, llke what type of monitors, etc.
Perhaps some debug logs leading up to the crash.
We are not psychic.
pszonem
Post by pszonem »
iconnor wrote: Tue Nov 23, 2021 7:05 pm I'm running 1.36.10 and 11 on a ton of centos 7 boxes. No problems.
We are not psychic.
Hmm, sad you didn't reply few months ago. Maybe original reporter will appreciate even current effort. Log (incl trace) was already cited as well...
Un-fortunately I started from scratch with 1.36.10-1 from rpmfusion; with Maria from 'base' repo on Centos7 (same installation - didn't reinstall).Using Monitors/Modect with RTSP for RLC IP cameras. They worked like a charm till that update... ..and now are working as well on fresh installation.
