Debian Repo Update
lbm
Re: Debian Repo Update
Post by lbm »
iconnor wrote: Mon May 31, 2021 1:07 pm I have one report that the resulting install is actually 1.37.0. Fear not, The difference at this time is minimal and the next update will fix the stored version #.
Yes. Got the same.. thx for the headsup!
Seems to be some issues in regards to versioning. :)
shows 1.36.3
 apt policy zoneminder
zoneminder:
  Installed: 1.36.3-buster
  Candidate: 1.36.3-buster
  Version table:
 *** 1.36.3-buster 500
        500 https://zmrepo.zoneminder.com/debian/release-1.36 buster/ Packages
        100 /var/lib/dpkg/status
     1.36.2-buster 500
     1.36.0-buster1 500
but then zmupdate.pl shows 1.37.0, when it was installed..
Initiating database upgrade to version 1.37.0 from version 1.36.0
Do you wish to take a backup of your database prior to upgrading?
This may result in a large file in /var/tmp/zm if you have a lot of events.
Press 'y' for a backup or 'n' to continue : y
Creating backup to /var/tmp/zm/zm-1.36.0.dump. This may take several minutes.
Database successfully backed up to /var/tmp/zm/zm-1.36.0.dump, proceeding to upgrade.
And also the GUI shows 1.37.0 :D
sammyke007
Post by sammyke007 »
Is the repo being updated automatically now? 1.36.3 still the latest for buster.
gruiarew
Post by gruiarew »
Updated from Repo and I'm to 1.37.0 now. Strange.
One issue I see, the checkboxes were moved to the left and on small monitors those appear hidden. Can the scaling be improved somehow?
Besides that, the new interface is amazing. Thanks for the possibility to filter the columns!
lbm
Post by lbm »
repo is now 1.36.5. Just updated from 1.36.3 (which showed as 1.37).
Everything seems fine.
It "upgrades" the DB from 1.37 to 1.36.5 when running zmupdate.pl, and now version shows correct as 1.36.5
francis3
Post by francis3 »
I'm late! :D
Just found out 1.36 is here!
Is the repo
still available?
Today I'm getting a "Page Not Found"
regards,
francis3
lbm
Post by lbm »
francis3 wrote: Thu Jul 01, 2021 10:56 am I'm late! :D
Is the repo
still available?
regards,
francis3
Seems like the certificate has been wrongly replaced. The CN is wrong, for which the repo is no longer working.
Openssl, gets the following CNAME: subject=CN = www.connortechnology.com
SteveGilvarry
Post by SteveGilvarry »
Community hosted so it doesn’t have an SLA, will be back just can’t say when.
francis3
Post by francis3 »
No hurry. :)
My v1.34.25 is just fine
dave_88
Post by dave_88 »
Looks like SSL certificate fixed, but getting 403 forbidden now for 1.36. Looking forward to trying the new version once the repo is accessible.
francis3
Post by francis3 »
Repo seems ok now
But branches
release-1.34/
and
release-1.36/
are empty.
The master branch is working
regards
francis3
Post by francis3 »
Repo is working now.
Smooth upgrade here to 1.36.5-buster
regards,
francis3
