I have installed ZoneMinder 1.35.27 from Master snapshot on Ubuntu 20.10 and trying to connect IP camera to it. However, instead of camera image I get "Monitor is not capturing. We will be unable to provide an image" message. Log contains the following strings that repeats periodically:
2021-04-25 16:42:27 zmdc 1330 ERR 'zmc -m 3' exited abnormally, exit status 255 zmdc.pl -
2021-04-25 16:42:27 zmc_m3 6228 FAT Failed to bind RTCP server zm_rtp_ctrl.cpp 264
2021-04-25 16:42:27 zmc_m3 6228 ERR bind(), Could not bind zm_comms.cpp 559
2021-04-25 16:42:27 zmc_m3 6224 INF Starting Capture version 1.35.27 zmc.cpp 220
The same camera works fine via RTSP with VLC player. Also, in the same network segment I have another server with ZoneMinder 1.32.3 installed, and it capture the same stream without any problems, monitor options are identical. I've tried to remove and re-create Monitor, but nothing changed.
I would be glad to get advises on fixing this problem.
