Linked monitors broken in latest releases?
Bit confused by this...have seen other posts, but confused by them too as they seem to contradict a bit (or maybe things have just changed?).
As others seem to do, I have several IP cameras where I use their high resolution streams with monitors for event and live viewing, and their low resolution streams for event detection. I have no interest in viewing the events/recording of the low resolution monitors, so would rather do everything to reduce their impact on overall CPU etc. and just have them as pure triggers for their high resolution counterparts.
As it stands I'm using the latest master PPA (v1.35.14) on Ubuntu 20.04, and I have the following:
* High resolution "Nodect" ffmpeg monitors with "Save JPEGs: Disabled", "Video Writer: H264 Camera Passthrough" and no detection zones
* These are linked to low resolution "Modect" ffmpeg monitors with "Save JPEGs: Disabled", "Video Writer: Disabled" and detection zones setup
I think that (mostly) follows the suggestion here viewtopic.php?t=29007#p113698 but with this setup I get events on the low resolution monitors but no triggering at all of their companion high resolution monitors.
I have had this working, at various points, with some success, but I think with various combinations of having "Video Writer: H264 Camera Passthrough" on the low resolution monitors and/or (redundant?) detection zones present on the high resolution monitors. I think I'm basically seeing some of the observations detailed here: viewtopic.php?t=28279#p110449 ; I see no errors in the logs.
Should this all work with no detection zones on the high resolution monitors and "Save JPEGs: Disabled" + "Video Writer: Disabled" on the low resolution monitors to which they're linked?
If not, what's the recommended setup for achieving triggering in this sort of setup and keeping CPU/memory as low as possible?
Thanks!
Thanks!
Re: The definitive "rules" for linked monitors: low res detection, high res triggered?
Bit more on this, since I've left things running with a single setup:
I'm definitely getting no triggering of my Nodect monitors from their linked/companion Modect monitors, if:
* The Nodect monitors have no detection zones
* The Modect monitors they're linked with have "Save JPEGs: Disabled" + "Video Writer: Disabled"
The Modect monitors are recording motion events though, which I'd initially thought was enough for them to trigger a Nodect monitor linked to them?
Is this a bug with 1.35.x or am I missing a combination of things that need to be in place for the Nodect/Modect linked setup to work with minimal processing overhead?
Thanks!
Thanks!
mmm...not sure what's going on here.
I changed the setup with the following differences from the above:
* The Nodect monitors now have a detection zone
* The Modect monitors now have "Save JPEGs: Disabled" + "Video Writer: H264 Camera Passthrough"
After that: 18 events detected from one of the Modect monitors (nothing new there) but still nothing triggered for the Nodect monitor that's linked to it.
I ought to add that the Nodect monitors record events fine if I manually trigger an alarm, it's just they aren't being triggered from their companion Modect monitors (and also confirm that they're setup the "right" way round i.e. the link to the Nodect monitors is made from each Modect monitor).
Anyone any ideas on why this isn't working?
Am I missing something obvious in this setup?
Thanks.
Thanks.
Were your linked monitors working previously?
I'm currently troubleshooting a similar setup, where my linked high res nodect monitors are not triggering from their low res modect counterparts under 1.35.14~20201123104159-focal. For me, things were/are working fine under 1.35.12~20201028131153-focal. Maybe try downgrading and see if it works for you too?
Interesting, thanks.johncolby wrote: ↑Fri Nov 27, 2020 5:50 pm Were your linked monitors working previously?
Well, the answer is that, yes, they were working "OK" with a prior version of 1.35.* - not sure which. Unfortunately though, that wasn't *this* installation - I had a hard-disk failure, so this is a clean install of the latest 1.35.*.
Also, when I say working "OK", they were working to the extent that I got most (but not all) of the triggered events from the Modect monitors on the Nodect ones.
Any known fix for this yet, as I have the same issue.
So, I think I've tried most combinations of the various options to try and get linked monitors working with the very latest release (at the time of writing that's 1.35.14~20201127133119-focal) - doesn't seem to be working.
I've not tried downgrading to 1.35.12~20201028131153-focal, as suggest by johncolby - it's not vital to me, at the moment, that this all works, so I'll stick with whatever the latest release is and hope it informs development (I realise that we're in "things can and will be broken" in 1.35.* land ).
Changing the subject title as a few of us seem to be seeing this and to make it a bit more appropriate.
Re: Linked monitors broken in latest releases?
Nothing revealing to my admittedly novice eyes here. The linked cam says it is "Linking to monitor 2", which sounds correct, but then no linking happens when an event gets triggered on monitor 2. Maybe I should be looking in some of the other component logs?
Also, I do note that there have been some code changes in the vicinity of linked monitor handling between my last known working package (1.35.12~20201028131153-focal) and my first known NOT working package (1.35.14~20201123104159-focal):
https://github.com/ZoneMinder/zoneminde ... #L492-L523
zma_m1 (high res nodect linked monitor):
zma_m2 (low res modect monitor):
❯ cat zm_debug.log.1129958
11/30/20 00:00:52.265432 zma_m1[1129958].DB1-zm_logger.cpp/235 [LogOpts: level=DB1 effective=DB1, screen=OFF, database=WAR, logfile=DB1->/var/log/zm/zm_debug.log.1129958, syslog=WAR]
11/30/20 00:00:52.265851 zma_m1[1129958].DB1-zm_utils.cpp/240 [Detected a x86\x86-64 processor with AVX]
11/30/20 00:00:52.266360 zma_m1[1129958].DB1-zm_ffmpeg_camera.cpp/195 [ffmpegcamera: width 2592 height 1520 linesize 7776 colours 3 image linesize 7776 imagesize 11819520]
11/30/20 00:00:52.266435 zma_m1[1129958].DB1-zm_monitor.cpp/386 [encoder params # Lines beginning with # are a comment
# For changing quality, use the crf option
# 1 is best, 51 is worst quality
#crf=23]
11/30/20 00:00:52.266485 zma_m1[1129958].DB1-zm_monitor.cpp/435 [mem.size(8) SharedData=616 TriggerData=560 VideoStoreData=4128 timestamps=800 images=50x11819520 = 590976000 total=590982168]
11/30/20 00:00:52.266497 zma_m1[1129958].DB1-zm_storage.cpp/94 [No id passed to Storage constructor. Using default path /mnt/Data/zoneminder/events instead]
11/30/20 00:00:52.266507 zma_m1[1129958].DB1-zm_monitor.cpp/444 [Storage path: /mnt/Data/zoneminder/events]
11/30/20 00:00:52.266527 zma_m1[1129958].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.1 (590982168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:52.266540 zma_m1[1129958].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.1 (590982168 bytes) to unlocked memory]
11/30/20 00:00:52.266597 zma_m1[1129958].DB1-zm_monitor.cpp/499 [Waiting for capture daemon shared_data(1) last_write_index(0), last_write_time(0)]
11/30/20 00:00:53.266804 zma_m1[1129958].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.1 (590982168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:53.266878 zma_m1[1129958].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.1 (590982168 bytes) to unlocked memory]
11/30/20 00:00:53.266938 zma_m1[1129958].DB1-zm_monitor.cpp/499 [Waiting for capture daemon shared_data(1) last_write_index(50), last_write_time(0)]
11/30/20 00:00:54.267111 zma_m1[1129958].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.1 (590982168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:54.267149 zma_m1[1129958].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.1 (590982168 bytes) to unlocked memory]
11/30/20 00:00:54.267176 zma_m1[1129958].DB1-zm_monitor.cpp/499 [Waiting for capture daemon shared_data(1) last_write_index(50), last_write_time(0)]
11/30/20 00:00:55.267354 zma_m1[1129958].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.1 (590982168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:55.267433 zma_m1[1129958].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.1 (590982168 bytes) to unlocked memory]
11/30/20 00:00:55.267498 zma_m1[1129958].DB1-zm_monitor.cpp/499 [Waiting for capture daemon shared_data(1) last_write_index(50), last_write_time(0)]
11/30/20 00:00:56.267665 zma_m1[1129958].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.1 (590982168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:56.267714 zma_m1[1129958].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.1 (590982168 bytes) to unlocked memory]
11/30/20 00:00:56.278332 zma_m1[1129958].DB1-zm_monitor.cpp/1939 [Reloading linked monitors for monitor Driveway, '2']
11/30/20 00:00:56.278368 zma_m1[1129958].DB1-zm_monitor.cpp/1990 [Linking to 1 monitors]
11/30/20 00:00:56.278378 zma_m1[1129958].DB1-zm_monitor.cpp/1994 [Checking linked monitor 2]
11/30/20 00:00:56.279057 zma_m1[1129958].DB1-zm_monitor.cpp/2021 [Linking to monitor 2]
11/30/20 00:00:56.279073 zma_m1[1129958].DB1-zm_monitor.cpp/537 [Monitor Driveway has function 6,
label format = '%N - %m/%d/%Y %H:%M:%S', label X = 0, label Y = 0, label size = 2,
image buffer count = 50, warmup count = 25, pre-event count = 25, post-event count = 25, alarm frame count = 1,
fps report interval = 1000, ref blend percentage = 6, alarm ref blend percentage = 6, track motion = 0]
11/30/20 00:00:56.279625 zma_m1[1129958].DB1-zm_zone.cpp/854 [Got 0 zones for monitor Driveway]
11/30/20 00:00:56.279640 zma_m1[1129958].DB1-zm_monitor.cpp/2456 [Loaded monitor 1(Driveway), 0 zones]
11/30/20 00:00:56.279706 zma_m1[1129958].INF-zma.cpp/136 [In mode 6/1, warming up]
11/30/20 00:02:34.213159 zma_m1[1129958].INF-zm_monitor.cpp/1338 [Driveway: 1000 - Analysing at 10.20 fps]
11/30/20 00:04:14.268854 zma_m1[1129958].INF-zm_monitor.cpp/1338 [Driveway: 2000 - Analysing at 10.00 fps]
11/30/20 00:05:54.285184 zma_m1[1129958].INF-zm_monitor.cpp/1338 [Driveway: 3000 - Analysing at 10.00 fps]
11/30/20 00:07:34.324030 zma_m1[1129958].INF-zm_monitor.cpp/1338 [Driveway: 4000 - Analysing at 10.00 fps]
❯ cat zm_debug.log.1129966
11/30/20 00:00:52.535340 zma_m2[1129966].DB1-zm_logger.cpp/235 [LogOpts: level=DB1 effective=DB1, screen=OFF, database=WAR, logfile=DB1->/var/log/zm/zm_debug.log.1129966, syslog=WAR]
11/30/20 00:00:52.535447 zma_m2[1129966].DB1-zm_utils.cpp/240 [Detected a x86\x86-64 processor with AVX]
11/30/20 00:00:52.535779 zma_m2[1129966].DB1-zm_ffmpeg_camera.cpp/195 [ffmpegcamera: width 352 height 240 linesize 1056 colours 3 image linesize 1056 imagesize 253440]
11/30/20 00:00:52.535816 zma_m2[1129966].DB1-zm_monitor.cpp/386 [encoder params # Lines beginning with # are a comment
#crf=23]
11/30/20 00:00:52.535850 zma_m2[1129966].DB1-zm_monitor.cpp/435 [mem.size(8) SharedData=616 TriggerData=560 VideoStoreData=4128 timestamps=800 images=50x253440 = 12672000 total=12678168]
11/30/20 00:00:52.535859 zma_m2[1129966].DB1-zm_storage.cpp/94 [No id passed to Storage constructor. Using default path /mnt/Data/zoneminder/events instead]
11/30/20 00:00:52.535866 zma_m2[1129966].DB1-zm_monitor.cpp/444 [Storage path: /mnt/Data/zoneminder/events]
11/30/20 00:00:52.535882 zma_m2[1129966].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.2 (12678168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:52.535893 zma_m2[1129966].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.2 (12678168 bytes) to unlocked memory]
11/30/20 00:00:52.535939 zma_m2[1129966].DB1-zm_monitor.cpp/499 [Waiting for capture daemon shared_data(1) last_write_index(50), last_write_time(0)]
11/30/20 00:00:53.536055 zma_m2[1129966].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.2 (12678168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:53.536093 zma_m2[1129966].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.2 (12678168 bytes) to unlocked memory]
11/30/20 00:00:53.536120 zma_m2[1129966].DB1-zm_monitor.cpp/499 [Waiting for capture daemon shared_data(1) last_write_index(50), last_write_time(0)]
11/30/20 00:00:54.536327 zma_m2[1129966].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.2 (12678168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:54.536399 zma_m2[1129966].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.2 (12678168 bytes) to unlocked memory]
11/30/20 00:00:54.536460 zma_m2[1129966].DB1-zm_monitor.cpp/499 [Waiting for capture daemon shared_data(1) last_write_index(50), last_write_time(0)]
11/30/20 00:00:55.536686 zma_m2[1129966].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.2 (12678168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:55.536722 zma_m2[1129966].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.2 (12678168 bytes) to unlocked memory]
11/30/20 00:00:55.536755 zma_m2[1129966].DB1-zm_monitor.cpp/499 [Waiting for capture daemon shared_data(1) last_write_index(50), last_write_time(0)]
11/30/20 00:00:56.536968 zma_m2[1129966].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.2 (12678168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:56.537036 zma_m2[1129966].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.2 (12678168 bytes) to unlocked memory]
11/30/20 00:00:56.537097 zma_m2[1129966].DB1-zm_monitor.cpp/499 [Waiting for capture daemon shared_data(1) last_write_index(50), last_write_time(0)]
11/30/20 00:00:57.537347 zma_m2[1129966].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.2 (12678168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:57.537419 zma_m2[1129966].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.2 (12678168 bytes) to unlocked memory]
11/30/20 00:00:57.537483 zma_m2[1129966].DB1-zm_monitor.cpp/499 [Waiting for capture daemon shared_data(1) last_write_index(50), last_write_time(0)]
11/30/20 00:00:58.537744 zma_m2[1129966].DB1-zm_monitor.cpp/597 [Unable to map file /dev/shm/zm.mmap.2 (12678168 bytes) to locked memory, trying unlocked]
11/30/20 00:00:58.537818 zma_m2[1129966].DB1-zm_monitor.cpp/600 [Mapped file /dev/shm/zm.mmap.2 (12678168 bytes) to unlocked memory]
11/30/20 00:00:58.538248 zma_m2[1129966].DB1-zm_monitor.cpp/1939 [Reloading linked monitors for monitor Driveway lowres, '(null)']
11/30/20 00:00:58.538293 zma_m2[1129966].DB1-zm_monitor.cpp/537 [Monitor Driveway lowres has function 3,
label format = '%N - %m/%d/%y %H:%M:%S', label X = 0, label Y = 0, label size = 1,
image buffer count = 50, warmup count = 25, pre-event count = 25, post-event count = 25, alarm frame count = 3,
11/30/20 00:00:58.539123 zma_m2[1129966].DB1-zm_zone.cpp/854 [Got 1 zones for monitor Driveway lowres]
11/30/20 00:00:58.540961 zma_m2[1129966].DB1-zm_monitor.cpp/2456 [Loaded monitor 2(Driveway lowres), 1 zones]
11/30/20 00:00:58.541044 zma_m2[1129966].INF-zma.cpp/136 [In mode 3/1, warming up]
11/30/20 00:04:13.227001 zma_m2[1129966].INF-zm_monitor.cpp/1338 [Driveway lowres: 1000 - Analysing at 5.13 fps]
11/30/20 00:06:36.907932 zma_m2[1129966].INF-zm_zone.cpp/211 [In overload mode, 10 frames of 10 remaining]
11/30/20 00:06:37.142368 zma_m2[1129966].INF-zm_zone.cpp/211 [In overload mode, 9 frames of 10 remaining]
11/30/20 00:06:37.310282 zma_m2[1129966].INF-zm_zone.cpp/211 [In overload mode, 8 frames of 10 remaining]
11/30/20 00:06:37.511992 zma_m2[1129966].INF-zm_zone.cpp/211 [In overload mode, 7 frames of 10 remaining]
11/30/20 00:06:37.680273 zma_m2[1129966].INF-zm_zone.cpp/211 [In overload mode, 6 frames of 10 remaining]
11/30/20 00:06:37.882251 zma_m2[1129966].INF-zm_zone.cpp/211 [In overload mode, 5 frames of 10 remaining]
11/30/20 00:06:38.083424 zma_m2[1129966].INF-zm_zone.cpp/211 [In overload mode, 4 frames of 10 remaining]
11/30/20 00:06:38.284936 zma_m2[1129966].INF-zm_zone.cpp/211 [In overload mode, 3 frames of 10 remaining]
11/30/20 00:06:38.486063 zma_m2[1129966].INF-zm_zone.cpp/211 [In overload mode, 2 frames of 10 remaining]
11/30/20 00:06:38.686950 zma_m2[1129966].INF-zm_zone.cpp/211 [In overload mode, 1 frames of 10 remaining]
11/30/20 00:06:38.889480 zma_m2[1129966].DB1-zm_zone.cpp/749 [All: Pixel Diff: 26, Alarm Pixels: 7564, Filter Pixels: 3690, Blob Pixels: 3297, Blobs: 8, Score: 8]
11/30/20 00:06:38.889534 zma_m2[1129966].INF-zm_monitor.cpp/1687 [Driveway lowres: 1728 - Gone into prealarm state]
11/30/20 00:06:39.160706 zma_m2[1129966].DB1-zm_zone.cpp/749 [All: Pixel Diff: 26, Alarm Pixels: 6864, Filter Pixels: 2829, Blob Pixels: 2392, Blobs: 5, Score: 5]
11/30/20 00:06:39.297773 zma_m2[1129966].DB1-zm_zone.cpp/749 [All: Pixel Diff: 26, Alarm Pixels: 5838, Filter Pixels: 2164, Blob Pixels: 1805, Blobs: 5, Score: 4]
11/30/20 00:06:39.297839 zma_m2[1129966].INF-zm_monitor.cpp/1603 [Driveway lowres: 1730 - Gone into alarm state PreAlarmCount: 2+this >= AlarmFrameCount:3 Cause:Motion All]
11/30/20 00:06:39.336290 zma_m2[1129966].DB1-zm_event.cpp/172 [Using storage area at /mnt/Data/zoneminder/events/2/2020-11-30/1100711]
11/30/20 00:06:39.336321 zma_m2[1129966].INF-zm_monitor.cpp/1654 [Driveway lowres: 1730 - Opening new event 1100711, alarm start]
11/30/20 00:06:39.336332 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 1]
11/30/20 00:06:39.337651 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 2]
11/30/20 00:06:39.338224 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 3]
11/30/20 00:06:39.338816 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 4]
11/30/20 00:06:39.339441 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 5]
11/30/20 00:06:39.340044 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 6]
11/30/20 00:06:39.340613 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 7]
11/30/20 00:06:39.341180 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 8]
11/30/20 00:06:39.341833 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 9]
11/30/20 00:06:39.342453 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 10]
11/30/20 00:06:39.343075 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 11]
11/30/20 00:06:39.343731 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 12]
11/30/20 00:06:39.344341 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 13]
11/30/20 00:06:39.344960 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 14]
11/30/20 00:06:39.345553 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 15]
11/30/20 00:06:39.346199 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 16]
11/30/20 00:06:39.346793 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 17]
11/30/20 00:06:39.347434 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 18]
11/30/20 00:06:39.348032 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 19]
11/30/20 00:06:39.348646 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 20]
11/30/20 00:06:39.349246 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 21]
11/30/20 00:06:39.349840 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 22]
11/30/20 00:06:39.350430 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 23]
11/30/20 00:06:39.351012 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 24]
11/30/20 00:06:39.351635 zma_m2[1129966].DB1-zm_event.cpp/516 [Writing pre-capture frame 25]
11/30/20 00:06:39.358117 zma_m2[1129966].DB1-zm_event.cpp/559 [INSERT 25/25 frames sql INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES
( 1100711, 1, 'Normal', from_unixtime(1606723593), 0.00, 0 ),
( 1100711, 2, 'Normal', from_unixtime(1606723594), 0.20, 0 ),
( 1100711, 3, 'Normal', from_unixtime(1606723594), 0.40, 0 ),
( 1100711, 4, 'Normal', from_unixtime(1606723594), 0.60, 0 ),
( 1100711, 5, 'Normal', from_unixtime(1606723594), 0.80, 0 ),
( 1100711, 6, 'Normal', from_unixtime(1606723594), 1.00, 0 ),
( 1100711, 7, 'Normal', from_unixtime(1606723595), 1.25, 0 ),
( 1100711, 8, 'Normal', from_unixtime(1606723595), 1.41, 0 ),
( 1100711, 9, 'Normal', from_unixtime(1606723595), 1.60, 0 ),
( 1100711, 10, 'Normal', from_unixtime(1606723595), 1.81, 0 ),
( 1100711, 11, 'Normal', from_unixtime(1606723595), 2.00, 0 ),
( 1100711, 12, 'Normal', from_unixtime(1606723596), 2.21, 0 ),
( 1100711, 13, 'Normal', from_unixtime(1606723596), 2.41, 0 ),
( 1100711, 14, 'Normal', from_unixtime(1606723596), 2.66, 0 ),
( 1100711, 15, 'Normal', from_unixtime(1606723596), 2.82, 0 ),
( 1100711, 16, 'Normal', from_unixtime(1606723596), 3.01, 0 ),
( 1100711, 17, 'Normal', from_unixtime(1606723597), 3.26, 0 ),
( 1100711, 18, 'Normal', from_unixtime(1606723597), 3.41, 0 ),
( 1100711, 19, 'Normal', from_unixtime(1606723597), 3.61, 0 ),
( 1100711, 20, 'Normal', from_unixtime(1606723597), 3.81, 0 ),
( 1100711, 21, 'Normal', from_unixtime(1606723597), 4.00, 0 ),
( 1100711, 22, 'Normal', from_unixtime(1606723598), 4.21, 0 ),
( 1100711, 23, 'Normal', from_unixtime(1606723598), 4.41, 0 ),
( 1100711, 24, 'Normal', from_unixtime(1606723598), 4.61, 0 ),
( 1100711, 25, 'Normal', from_unixtime(1606723598), 4.81, 0 )]
11/30/20 00:06:39.358137 zma_m2[1129966].DB1-zm_monitor.cpp/1681 [alarm frame count so SavePreAlarmFrames]
11/30/20 00:06:39.358147 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 26 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00026-capture.jpg]
11/30/20 00:06:39.360022 zma_m2[1129966].DB1-zm_event.cpp/666 [Writing analysis frame 26]
11/30/20 00:06:39.360666 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723598.879402 = 5.0]
11/30/20 00:06:39.360678 zma_m2[1129966].DB1-zm_event.cpp/698 [Adding 1 frames to DB because write_to_db:1 or frames > analysis fps 5.128205 or BULK(0)]
11/30/20 00:06:39.360692 zma_m2[1129966].DB1-zm_event.cpp/573 [Inserting 1 frames]
11/30/20 00:06:39.364081 zma_m2[1129966].DB1-zm_event.cpp/598 [INSERT FRAMES: sql was INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES
( 1100711, 26, 'Alarm', from_unixtime( 1606723598 ), 5.00, 8 )]
11/30/20 00:06:39.368181 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 27 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00027-capture.jpg]
11/30/20 00:06:39.369214 zma_m2[1129966].DB1-zm_event.cpp/666 [Writing analysis frame 27]
11/30/20 00:06:39.370175 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723599.141487 = 5.27]
11/30/20 00:06:39.370193 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 1 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:39.372930 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 28 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00028-capture.jpg]
11/30/20 00:06:39.373597 zma_m2[1129966].DB1-zm_event.cpp/666 [Writing analysis frame 28]
11/30/20 00:06:39.374243 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723599.287335 = 5.42]
11/30/20 00:06:39.374253 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 2 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:39.510873 zma_m2[1129966].DB1-zm_zone.cpp/749 [All: Pixel Diff: 25, Alarm Pixels: 4819, Filter Pixels: 1465, Blob Pixels: 1168, Blobs: 10, Score: 2]
11/30/20 00:06:39.515381 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 29 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00029-capture.jpg]
11/30/20 00:06:39.516308 zma_m2[1129966].DB1-zm_event.cpp/666 [Writing analysis frame 29]
11/30/20 00:06:39.517115 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723599.487636 = 5.62]
11/30/20 00:06:39.517140 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 3 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:39.719975 zma_m2[1129966].DB1-zm_zone.cpp/749 [All: Pixel Diff: 25, Alarm Pixels: 3948, Filter Pixels: 904, Blob Pixels: 587, Blobs: 6, Score: 1]
11/30/20 00:06:39.724138 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 30 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00030-capture.jpg]
11/30/20 00:06:39.725431 zma_m2[1129966].DB1-zm_event.cpp/666 [Writing analysis frame 30]
11/30/20 00:06:39.726373 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723599.691130 = 5.82]
11/30/20 00:06:39.726392 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 4 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:39.894851 zma_m2[1129966].DB1-zm_zone.cpp/749 [All: Pixel Diff: 25, Alarm Pixels: 3158, Filter Pixels: 498, Blob Pixels: 318, Blobs: 3, Score: 1]
11/30/20 00:06:39.899072 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 31 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00031-capture.jpg]
11/30/20 00:06:39.899780 zma_m2[1129966].DB1-zm_event.cpp/666 [Writing analysis frame 31]
11/30/20 00:06:39.900416 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723599.887800 = 6.1]
11/30/20 00:06:39.900426 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 5 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:40.102469 zma_m2[1129966].DB1-zm_zone.cpp/749 [All: Pixel Diff: 26, Alarm Pixels: 2539, Filter Pixels: 324, Blob Pixels: 175, Blobs: 2, Score: 1]
11/30/20 00:06:40.106286 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 32 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00032-capture.jpg]
11/30/20 00:06:40.107039 zma_m2[1129966].DB1-zm_event.cpp/666 [Writing analysis frame 32]
11/30/20 00:06:40.107782 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723600.91721 = 6.22]
11/30/20 00:06:40.107796 zma_m2[1129966].DB1-zm_event.cpp/698 [Adding 6 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK(0)]
11/30/20 00:06:40.107810 zma_m2[1129966].DB1-zm_event.cpp/573 [Inserting 6 frames]
11/30/20 00:06:40.112154 zma_m2[1129966].DB1-zm_event.cpp/598 [INSERT FRAMES: sql was INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES
( 1100711, 27, 'Alarm', from_unixtime( 1606723599 ), 5.27, 5 ),
( 1100711, 28, 'Alarm', from_unixtime( 1606723599 ), 5.42, 4 ),
( 1100711, 29, 'Alarm', from_unixtime( 1606723599 ), 5.62, 2 ),
( 1100711, 30, 'Alarm', from_unixtime( 1606723599 ), 5.82, 1 ),
( 1100711, 31, 'Alarm', from_unixtime( 1606723599 ), 6.01, 1 ),
( 1100711, 32, 'Alarm', from_unixtime( 1606723600 ), 6.22, 1 )]
11/30/20 00:06:40.320127 zma_m2[1129966].DB1-zm_zone.cpp/749 [All: Pixel Diff: 26, Alarm Pixels: 1946, Filter Pixels: 249, Blob Pixels: 136, Blobs: 2, Score: 1]
11/30/20 00:06:40.324776 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 33 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00033-capture.jpg]
11/30/20 00:06:40.325558 zma_m2[1129966].DB1-zm_event.cpp/666 [Writing analysis frame 33]
11/30/20 00:06:40.326247 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723600.287810 = 6.42]
11/30/20 00:06:40.326260 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 1 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:40.495881 zma_m2[1129966].DB1-zm_zone.cpp/749 [All: Pixel Diff: 27, Alarm Pixels: 1459, Filter Pixels: 158, Blob Pixels: 37, Blobs: 1, Score: 1]
11/30/20 00:06:40.500124 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 34 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00034-capture.jpg]
11/30/20 00:06:40.500715 zma_m2[1129966].DB1-zm_event.cpp/666 [Writing analysis frame 34]
11/30/20 00:06:40.501211 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723600.487716 = 6.62]
11/30/20 00:06:40.501219 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 2 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:40.703078 zma_m2[1129966].INF-zm_monitor.cpp/1697 [Driveway lowres: 1737 - Gone into alert state]
11/30/20 00:06:40.703120 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 35 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00035-capture.jpg]
11/30/20 00:06:40.703679 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723600.688388 = 6.82]
11/30/20 00:06:40.703689 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 3 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:40.906615 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1738)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723600) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:40.906702 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 36 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00036-capture.jpg]
11/30/20 00:06:40.908007 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723600.889443 = 7.1]
11/30/20 00:06:40.908029 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 4 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:41.210904 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1739)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723601) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:41.210975 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 37 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00037-capture.jpg]
11/30/20 00:06:41.212642 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723601.183818 = 7.32]
11/30/20 00:06:41.212694 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 5 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:41.314983 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1740)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723601) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:41.315083 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 38 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00038-capture.jpg]
11/30/20 00:06:41.316588 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723601.286083 = 7.42]
11/30/20 00:06:41.316616 zma_m2[1129966].DB1-zm_event.cpp/698 [Adding 6 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK(0)]
11/30/20 00:06:41.316655 zma_m2[1129966].DB1-zm_event.cpp/573 [Inserting 6 frames]
11/30/20 00:06:41.321288 zma_m2[1129966].DB1-zm_event.cpp/598 [INSERT FRAMES: sql was INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES
( 1100711, 33, 'Alarm', from_unixtime( 1606723600 ), 6.42, 1 ),
( 1100711, 34, 'Alarm', from_unixtime( 1606723600 ), 6.62, 1 ),
( 1100711, 35, 'Normal', from_unixtime( 1606723600 ), 6.82, 0 ),
( 1100711, 36, 'Normal', from_unixtime( 1606723600 ), 7.01, 0 ),
( 1100711, 37, 'Normal', from_unixtime( 1606723601 ), 7.32, 0 ),
( 1100711, 38, 'Normal', from_unixtime( 1606723601 ), 7.42, 0 )]
11/30/20 00:06:41.492039 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1741)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723601) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:41.492084 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 39 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00039-capture.jpg]
11/30/20 00:06:41.492621 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723601.486787 = 7.62]
11/30/20 00:06:41.492631 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 1 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:41.693944 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1742)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723601) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:41.693990 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 40 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00040-capture.jpg]
11/30/20 00:06:41.694654 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723601.686628 = 7.82]
11/30/20 00:06:41.694678 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 2 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:41.896078 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1743)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723601) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:41.896133 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 41 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00041-capture.jpg]
11/30/20 00:06:41.896854 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723601.886705 = 8.1]
11/30/20 00:06:41.896867 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 3 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:42.098131 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1744)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723602) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:42.098182 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 42 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00042-capture.jpg]
11/30/20 00:06:42.098874 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723602.86095 = 8.22]
11/30/20 00:06:42.098885 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 4 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:42.300374 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1745)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723602) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:42.300429 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 43 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00043-capture.jpg]
11/30/20 00:06:42.301174 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723602.283668 = 8.42]
11/30/20 00:06:42.301186 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 5 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:42.502615 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1746)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723602) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:42.502674 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 44 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00044-capture.jpg]
11/30/20 00:06:42.503702 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723602.493704 = 8.63]
11/30/20 00:06:42.503720 zma_m2[1129966].DB1-zm_event.cpp/698 [Adding 6 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK(0)]
11/30/20 00:06:42.503739 zma_m2[1129966].DB1-zm_event.cpp/573 [Inserting 6 frames]
11/30/20 00:06:42.508011 zma_m2[1129966].DB1-zm_event.cpp/598 [INSERT FRAMES: sql was INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES
( 1100711, 39, 'Normal', from_unixtime( 1606723601 ), 7.62, 0 ),
( 1100711, 40, 'Normal', from_unixtime( 1606723601 ), 7.82, 0 ),
( 1100711, 41, 'Normal', from_unixtime( 1606723601 ), 8.01, 0 ),
( 1100711, 42, 'Normal', from_unixtime( 1606723602 ), 8.22, 0 ),
( 1100711, 43, 'Normal', from_unixtime( 1606723602 ), 8.42, 0 ),
( 1100711, 44, 'Normal', from_unixtime( 1606723602 ), 8.63, 0 )]
11/30/20 00:06:42.713604 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1747)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723602) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:42.713687 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 45 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00045-capture.jpg]
11/30/20 00:06:42.715159 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723602.682739 = 8.82]
11/30/20 00:06:42.715185 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 1 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:42.883714 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1748)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723602) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:42.883796 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 46 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00046-capture.jpg]
11/30/20 00:06:42.885288 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723602.880083 = 9.0]
11/30/20 00:06:42.885314 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 2 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:43.154256 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1749)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723603) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:43.154324 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 47 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00047-capture.jpg]
11/30/20 00:06:43.155372 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723603.145632 = 9.28]
11/30/20 00:06:43.155392 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 3 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:43.290668 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1750)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723603) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:43.290751 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 48 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00048-capture.jpg]
11/30/20 00:06:43.291980 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723603.287007 = 9.42]
11/30/20 00:06:43.291999 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 4 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:43.494117 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1751)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723603) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:43.494227 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 49 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00049-capture.jpg]
11/30/20 00:06:43.495730 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723603.483566 = 9.62]
11/30/20 00:06:43.495758 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 5 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:43.697836 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1752)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723603) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:43.697916 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 50 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00050-capture.jpg]
11/30/20 00:06:43.699404 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723603.683273 = 9.82]
11/30/20 00:06:43.699423 zma_m2[1129966].DB1-zm_event.cpp/698 [Adding 6 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK(0)]
11/30/20 00:06:43.699442 zma_m2[1129966].DB1-zm_event.cpp/573 [Inserting 6 frames]
11/30/20 00:06:43.703275 zma_m2[1129966].DB1-zm_event.cpp/598 [INSERT FRAMES: sql was INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES
( 1100711, 45, 'Normal', from_unixtime( 1606723602 ), 8.82, 0 ),
( 1100711, 46, 'Normal', from_unixtime( 1606723602 ), 9.00, 0 ),
( 1100711, 47, 'Normal', from_unixtime( 1606723603 ), 9.28, 0 ),
( 1100711, 48, 'Normal', from_unixtime( 1606723603 ), 9.42, 0 ),
( 1100711, 49, 'Normal', from_unixtime( 1606723603 ), 9.62, 0 ),
( 1100711, 50, 'Normal', from_unixtime( 1606723603 ), 9.82, 0 )]
11/30/20 00:06:43.909105 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1753)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723603) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:43.909188 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 51 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00051-capture.jpg]
11/30/20 00:06:43.910659 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723603.885477 = 10.1]
11/30/20 00:06:43.910685 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 1 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:44.112901 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1754)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723604) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:44.112995 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 52 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00052-capture.jpg]
11/30/20 00:06:44.114489 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723604.85425 = 10.22]
11/30/20 00:06:44.114515 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 2 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:44.316620 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1755)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723604) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:44.316700 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 53 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00053-capture.jpg]
11/30/20 00:06:44.318171 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723604.284987 = 10.42]
11/30/20 00:06:44.318197 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 3 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:44.485985 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1756)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723604) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:44.486051 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 54 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00054-capture.jpg]
11/30/20 00:06:44.486729 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723604.485045 = 10.62]
11/30/20 00:06:44.486740 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 4 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:44.688397 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1757)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723604) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:44.688467 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 55 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00055-capture.jpg]
11/30/20 00:06:44.689807 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723604.683122 = 10.82]
11/30/20 00:06:44.689830 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 5 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:44.890873 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1758)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723604) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:44.890919 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 56 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00056-capture.jpg]
11/30/20 00:06:44.891584 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723604.881893 = 11.0]
11/30/20 00:06:44.891598 zma_m2[1129966].DB1-zm_event.cpp/698 [Adding 6 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK(0)]
11/30/20 00:06:44.891610 zma_m2[1129966].DB1-zm_event.cpp/573 [Inserting 6 frames]
11/30/20 00:06:44.895823 zma_m2[1129966].DB1-zm_event.cpp/598 [INSERT FRAMES: sql was INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES
( 1100711, 51, 'Normal', from_unixtime( 1606723603 ), 10.01, 0 ),
( 1100711, 52, 'Normal', from_unixtime( 1606723604 ), 10.22, 0 ),
( 1100711, 53, 'Normal', from_unixtime( 1606723604 ), 10.42, 0 ),
( 1100711, 54, 'Normal', from_unixtime( 1606723604 ), 10.62, 0 ),
( 1100711, 55, 'Normal', from_unixtime( 1606723604 ), 10.82, 0 ),
( 1100711, 56, 'Normal', from_unixtime( 1606723604 ), 11.00, 0 )]
11/30/20 00:06:45.168207 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1759)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723605) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:45.168284 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 57 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00057-capture.jpg]
11/30/20 00:06:45.169110 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723605.158957 = 11.29]
11/30/20 00:06:45.169137 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 1 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:45.304275 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1760)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723605) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:45.304361 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 58 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00058-capture.jpg]
11/30/20 00:06:45.305824 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723605.287351 = 11.42]
11/30/20 00:06:45.305849 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 2 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:45.507835 zma_m2[1129966].DB1-zm_monitor.cpp/1716 [Not leaving ALERT beacuse image_count(1761)-last_alarm_count(1736) > post_event_count(25) and timestamp.tv_sec(1606723605) - recording.tv_src(1606723593) >= min_section_length(10)]
11/30/20 00:06:45.507944 zma_m2[1129966].DB1-zm_event.cpp/637 [Writing capture frame 59 to /mnt/Data/zoneminder/events/2/2020-11-30/1100711/00059-capture.jpg]
11/30/20 00:06:45.509429 zma_m2[1129966].DB1-zm_event.cpp/680 [Frame delta is 1606723593.872324 - 1606723605.477776 = 11.61]
11/30/20 00:06:45.509455 zma_m2[1129966].DB1-zm_event.cpp/724 [Not Adding 3 frames to DB because write_to_db:0 or frames > analysis fps 5.128205 or BULK]
11/30/20 00:06:45.711500 zma_m2[1129966].INF-zm_monitor.cpp/1704 [Driveway lowres: 1762 - Left alarm state (1100711) - 59(9) images]
11/30/20 00:06:45.711571 zma_m2[1129966].INF-zm_monitor.cpp/1709 [Driveway lowres: 1762 - Closing event 1100711, alarm end]
11/30/20 00:06:45.711595 zma_m2[1129966].DB1-zm_event.cpp/573 [Inserting 3 frames]
11/30/20 00:06:45.718414 zma_m2[1129966].DB1-zm_event.cpp/598 [INSERT FRAMES: sql was INSERT INTO `Frames` (`EventId`, `FrameId`, `Type`, `TimeStamp`, `Delta`, `Score`) VALUES
( 1100711, 57, 'Normal', from_unixtime( 1606723605 ), 11.29, 0 ),
( 1100711, 58, 'Normal', from_unixtime( 1606723605 ), 11.42, 0 ),
( 1100711, 59, 'Normal', from_unixtime( 1606723605 ), 11.61, 0 )]
11/30/20 00:06:45.718466 zma_m2[1129966].DB1-zm_event.cpp/271 [Updating frames delta by 0 sec 0 usec]
11/30/20 00:07:33.310726 zma_m2[1129966].INF-zm_monitor.cpp/1338 [Driveway lowres: 2000 - Analysing at 5.00 fps]
Any news on this issue?
I've same problem:
MONITOR-HighRes: Linked to MONITOR-LowRes, Nodect Mode
MONITOR-LowRes: No-Linked, Modect Mode
On events, only the MONITOR-LowRes is recording events. Nothing happens on MONITOR-HighRes...
Thanks, Simon
Version installed: 1.35.14~20201129162543-focal
I've same problem:
Thanks, Simon
Just to keep this up to date, I'm now running 1.35.15~20201203183158-focal and linked monitors aren't working with this release either.
I just added this issue to the github bug tracker: https://github.com/ZoneMinder/zoneminder/issues/3091
Something peculiar going on...
I'm currently on 1.35.15~20201204114937-focal and I've had some events triggered on my high resolution monitors - although only a small subset of those recorded on the low resolution monitors e.g. the events I get every day when the cameras switch from the night to day viewing.
These are the first events that have been triggered on the high resolution monitors since my re-install using the master PPA (on opening the thread).
