Unable to navigate to tabs in camera settings
Khurram
Post by Khurram »
I am been unable to navigate to any tab for camera settings except the first one (General). Clicking on Source, ONVIF, Storage etc does nothing, the browser remains on the General tab. I have tried this in firefox, chrome and IE as well. Same is true if I try to add a new monitor. I updated to 1.35.6 (through Synaptic) but it has made no difference. Running Ubuntu 18.04 LTS.
Re: Unable to navigate to tabs in camera settings
There seems to be quite a bit of work going on with the web interface in 1.35.x. If you still have the old tabls, there's a newer version with links down the lefthand side for General, Source etc. Might be worth try to get to the latest build.
Khurram
Post by Khurram »
Magic919 wrote: Thu Sep 03, 2020 9:57 am There seems to be quite a bit of work going on with the web interface in 1.35.x. If you still have the old tabls, there's a newer version with links down the lefthand side for General, Source etc. Might be worth try to get to the latest build.
You mean the nightly build? Is it recommended for a production system?
I grab mine from Git, but your method will differ.
1.35.x is not recommended for production systems. That's what the 1.34 versions are for.
Khurram
Post by Khurram »
Magic919 wrote: Thu Sep 03, 2020 11:58 am I grab mine from Git, but your method will differ.
I installed it from Synaptic. I checked the apt/sources and it seems I added the master branch sometime in the past. I have now changed it the bionic branch. But version 1.34.x does not show up in Synaptic; it show 1.36.x as installed. How do I downgrade to 1.34.x?
1.35.6~20200905091552-focal tabs now works. The Bionic version should work too. Should not matter how you do the upgrade as long as your PPA is set to the master branch.
