Usb camera monitor can't be added to the latest Zoneminder -master 1.35.6~20200827192711-focal [solved ]
bkjaya1952
Post by bkjaya1952 »
Today, I have tested the latest Zoneminder-master 1.35.6~20200827192711-focal released 8 hrs back.
USB Camera monitor can't be added as the Source button and Storage button are not working.
Screenshot from 2020-08-28 13-34-01.png (52.06 KiB) Viewed 2063 times
Error Log
DVB Hardware
Re: Usb camera monitor can't be added to the latest Zoneminder -master 1.35.6~20200827192711-focal
Post by DVB Hardware »
See previous post ALERT UI
knight-of-ni wrote: Thu Aug 27, 2020 9:34 pm Just a heads up that I have just begun layout changes to the monitor view.
What you see today is by no means the final result. Everything should work, but buttons, links, and alignment are not in their final state.
bkjaya1952
Thank you very much ! Now it is working :D :D :D
Screenshot from 2020-08-28 22-29-08.png (389.25 KiB) Viewed 2016 times
After Mr knight-of-ni's Fix https://github.com/ZoneMinder/zoneminde ... b16c160b68 USB camera monitor can be added
Screenshot from 2020-08-28 22-33-50.png (206.09 KiB) Viewed 2016 times
Mr knight-of-ni's Fix was applied to the bkjaya1952/docker-zoneminder-php7.4-mysql8 at https://hub.docker.com/r/bkjaya1952/zon ... ker-latest
