Documentaion seems wrong
Posted: Fri Jul 17, 2020 12:29 am
https://zoneminder.readthedocs.io/en/la ... edhat.html
I'm following this doc but things aren't making any sense.
I installed a minimal version of Centos 8, installed the repo's and finally installed zoneminder.
The doc says there is a README file in /usr/share/doc/zoneminder but there is not.
I *assume* the file is actually this one. /usr/share/doc/zoneminder-common/README
However, this file is talking about making symlinks and doing things based on having Apache or Nginx.
I installed neither web server yet because the doc said a very minimal OS to start.
So, now that I've run 'sudo dnf install zoneminder' and it completed, where are these critical steps I'm needing to follow?
I assume I have to install a web server, mariadb server, php and a whole lot of other things then configure at least mariadb for access.
This is all guessing because the doc seems wrong.
Does anyone know of a current, up to date doc for installing 1.34 on Centos 8 from the step I'm at now?
