Documentaion seems wrong
Forum for questions and support relating to 1.35.x development only.
BobLaske
Post by BobLaske » Fri Jul 17, 2020 12:29 am
https://zoneminder.readthedocs.io/en/la ... edhat.html
I'm following this doc but things aren't making any sense.
I installed a minimal version of Centos 8, installed the repo's and finally installed zoneminder.
The doc says there is a README file in /usr/share/doc/zoneminder but there is not.
I *assume* the file is actually this one. /usr/share/doc/zoneminder-common/README
However, this file is talking about making symlinks and doing things based on having Apache or Nginx.
I installed neither web server yet because the doc said a very minimal OS to start.
So, now that I've run 'sudo dnf install zoneminder' and it completed, where are these critical steps I'm needing to follow?
I assume I have to install a web server, mariadb server, php and a whole lot of other things then configure at least mariadb for access.
This is all guessing because the doc seems wrong.
Does anyone know of a current, up to date doc for installing 1.34 on Centos 8 from the step I'm at now?
Re: Documentaion seems wrong
Post by knight-of-ni » Fri Jul 17, 2020 1:33 am
If you have started here: https://zoneminder.readthedocs.io/en/la ... zoneminder
Then all you have to do is follow the steps in the README, just like it says.
When you ran dnf install zoneminder, it pulled in zoneminder-common and zoneminder-httpd, which pulled in apache webserver.
Yeah, the documentation should be updated to reflect the change in location of the README.
BobLaske
Post by BobLaske » Fri Jul 17, 2020 2:05 am
I started at the top of this doc.
So you're saying just follow the steps in the file I did find then;
Ok, will do. Thanks.
For anyone who comes across this, the last steps are here.
more /usr/share/doc/zoneminder-common/README.httpd
or if using nginx;
more /usr/share/doc/zoneminder-common/README.nginx
Post by knight-of-ni » Fri Jul 17, 2020 2:12 am
Yes, but if you intend to install zoneminder, rather than build zoneminder, you want to start at this specific part of the guide:
https://zoneminder.readthedocs.io/en/st ... zoneminder
I guess I should ask since you posted in the 1.35.x development forum, do you want to install the latest zoneminder release or do you want to install a nightly development build?
BobLaske
Post by BobLaske » Fri Jul 17, 2020 2:37 am
I used the yum method so I assume that's the nightly build. I didn't check but usually the latest is built rather than installed I think is what you're saying. Therefore, that explains why my install is only 1.34.16. I have to find out what changes are in 1.35.
Guess I'll have to start over. Thanks.
Post by knight-of-ni » Fri Jul 17, 2020 12:22 pm
1.35.x is our development branch. It is intended only for beta testing or to develop new software.
If you are looking for a stable system to record video you rely on, then I'd recommend you stick with our latest release, which is 1.34.16 currently.
BobLaske
Post by BobLaske » Fri Jul 17, 2020 2:59 pm
Yes, that's what I'm doing.
Thanks very much for the quick help.
Users browsing this forum: bkjaya1952 and 1 guest
