I have been doing battle with this task for a while and I'm being thwarted.
I'm able to set up a Debian machine with dlandon/zoneminder and it works a charm.
As soon as I try to install zm with the same settings on TrueNAS-Scale I can't access the WebUI
It appears to be running on TrueNAS but without external access
I was wondering if anybody had been successful?
Many thanks
Install ZM on TrueNAS-SCALE-21.04-ALPHA.1
Re: Install ZM on TrueNAS-SCALE-21.04-ALPHA.1
Just adding support to getting some assistance on this. I've had the same issue when trying to use the SCALE GUI. It appears to create the docker instance, but there's no access allowed.
Has anyone gone through this successfully?
